June 10th, 2014, 02:47 PM | #1 |
Biker Noob
Join Date: Apr 2014 Motorcycle(s): 2004 Honda Shadow 750 Aero Posts: 176
How do I remove this
Pic below
Riding as I stole it. |
June 10th, 2014, 02:51 PM | #2 |
MOTM - Sep '18, Feb '16
Flatten the metal pieces that are bent up around the edge and use a 1/2 inch impact gun. I can't remember the socket size. But it's on tight.
June 10th, 2014, 03:29 PM | #3 |
June 10th, 2014, 03:31 PM | #4 |
Join Date: Nov 2009 Motorcycle(s): 300, WeeStrom Posts: A lot.
94 lbs tight if i recall
June 10th, 2014, 03:54 PM | #5 |
Low tech method that works ever time, a 2x4 in the rear wheel and a breaker bar.
Good luck and a rag saves some paint, use your noggin.
June 10th, 2014, 04:14 PM | #6 |
Join Date: Dec 2013 Motorcycle(s): 2011 250R SE Posts: 326
June 10th, 2014, 04:23 PM | #7 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
^Yerp. 27mm. I remember because I had to go on a wild goose chase for that darn socket.
June 10th, 2014, 06:58 PM | #8 |
Board Member
Another way to remove the carbs.... | Soujyu | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 26th, 2013 12:36 PM |
How to remove a decal ? | bikermunda | 2008 - 2012 Ninja 250R Farkles | 23 | March 26th, 2013 05:43 AM |
To remove or not to remove?? | extremez31 | General Motorcycling Discussion | 13 | April 18th, 2012 07:54 AM |
Trying to remove the airbox.... | jboyd12 | 2008 - 2012 Ninja 250R Tech Talk | 9 | April 5th, 2012 11:29 PM |
How do you remove the grip? | CThunder-blue | 2008 - 2012 Ninja 250R Farkles | 29 | August 16th, 2011 07:35 PM |
