May 1st, 2015, 04:14 PM | #1 |
Join Date: Mar 2014 Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE Posts: 59
Rear seat cowl installed: 2012 250R SE
Nice addition! Also put a fine quality self-adhesive chronograph from Wally Mart on the triple clamp.
May 1st, 2015, 05:12 PM | #2 |
May 1st, 2015, 07:39 PM | #3 |
Join Date: Apr 2015 Motorcycle(s): 11 Ninja 250R se Posts: 46
It looks good, how do you like it and was it the 99 dollar ones on Amazon?
A little rebellion now and then ... is a medicine necessary for the sound health of government. -Thomas Jefferson |
May 1st, 2015, 11:02 PM | #4 |
Thanks! It's a Kawasaki genuine accessory that I ordered through a dealer.
Claimed to boost top speed by about 10 mph. Last futzed with by C-Bass; May 2nd, 2015 at 09:08 AM. |
May 3rd, 2015, 07:17 PM | #5 |
Join Date: Jan 2015 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 121
I wish we had a more flush-sitting cover available.. I have the OEM version as well, and while it does look nice, it would look a LOT nicer if it sat flush..
I also noticed that at speed, if I keep a microfiber cloth in that area, it WILL get sucked out through the gapping.. I've lost two of those suckers that way.. Hahahah.. |
May 5th, 2015, 02:09 PM | #6 | |
Join Date: Aug 2011 Motorcycle(s): '09 Ninja 250R Posts: 260
It would be more secure, you could make the fit as flush as you want it, and stuff wouldn't get sucked out through the gap. |
May 6th, 2015, 05:26 AM | #7 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
The only issue I have is the back grommet always falling out and getting lost. I am modifying mine now to use the same why the rear seat cowl works, slides under the bar. There is a thread or how to about fixing the gap in the front, the issue is the center lock bar in the front is to long so when clips into the key lock it holds the rest higher.
Spoiler for topic:
Fender Eliminator, Corbin Seat, Rear Seat Cowl Installed | k-os | Pictures | 9 | February 10th, 2009 08:56 AM |
