August 12th, 2015, 05:12 PM | #41 |
Fast-Guy wannabe
MOTM - Jan '13
Because every lot of steel has slightly different characteristics and thus a different rate. That's why most springs in suspension for example are rated then marked individually.
August 12th, 2015, 07:28 PM | #42 | |
there is no such thing.
August 13th, 2015, 11:14 AM | #43 | |
Join Date: Jul 2015 Motorcycle(s): 07 Ninja 01 Sportster Posts: 56
k = Gd4/[8nD3] {note: the 4 and the 3 are powers} Where: k = constant, pounds of load per inch of deflection G = modulus of rigidity of spring material, pounds per square inch d = wire diameter, inches n = number of active coils, which is the number of coils subjected to flexure (always less than the total number of coils) D = mean coil diameter, inches = Outer Diameter - Wire Diameter G is calculated from the spring materials Elastic moduls and Poisson Ratio n G = E/(2(1 + v) |
August 13th, 2015, 11:54 AM | #44 |
Join Date: Sep 2013 Motorcycle(s): Ducati 1198s, Triumph D675, Suzuki SV1000s, `08 Ninja 250, `11 Ninja 250, Suzuki GS750 Posts: 368
I bought 15 or so of these a few years back in a group buy to save on shipping, have one still brand new in package if any one is interested pm me.
Did make a noticeable difference, stopped popping out of gear.
MCRA.com |
August 13th, 2015, 09:16 PM | #45 |
Ride report for Kawasaki 92081-112 SPRING --- SPRING, SPRING, NEUTRAL,POSITIONING
Okay I can say it felt better, more firm, positive shifts, while a very little bit more effort to change gears. So there's a definite difference between the stock Ninjette vs 92081-112 . I'm still waiting on my new digital caliper for measurements. For now just by feel, it's a difference in a good way, so I'd say it worth the money for this spring (http://www.partzilla.com/parts/detai...92081-112.html)
August 13th, 2015, 09:28 PM | #46 | |
Freedom for Germany
August 13th, 2015, 09:33 PM | #47 |
No problem, hopefully this is a cheaper alternative to the $30.00 USD Blue Magic Spring for $2.82+shipping from Partzilla.
August 13th, 2015, 09:51 PM | #48 |
If anybody has a Factory Pro Blue Magic Spring, I would be interested in buying it, for comparing the two, or if someone can take measurements.
August 17th, 2015, 05:58 AM | #49 |
Fast-Guy wannabe
MOTM - Jan '13
OEM spring after 75,000 miles is 1.125 in length, .312OD and 0.040" wire gage thickness.
If it's tempered steel like it should be for motors then your looking at about 20.9 inch/lbs in rate. I can double the rate with the same size spring but 0.048 wire gage. |
August 17th, 2015, 10:10 PM | #50 |
Okay time for some numbers, as in measurements
1998 Ninjette OEM 92144-1580 SPRING Length=27mm/1.06" I.D.=5.7mm/0.22" O.D.=7.9mm/.31" Wire diameter=0.7mm/0.02" 92081-112 SPRING Length=30.9mm/1.21" I.D.=5.7mm/0.22" O.D.=7.9mm/0.31" Wire diameter=0.8mm/0.03" So there you have it, as I said I did the finger pinch test, and the 92081-112 SPRING is a lot notably stiffer. So if anyone out has a Factory Pro Blue Magic Spring please take some measurements, or sell me one really really cheap.
August 17th, 2015, 11:32 PM | #51 |
Dang my attention to motorcycle maintenance has atrophied. Work has been... {insert excuse here}
After installing more aggressive cams, I haven't had a chance to perfectly dial in the mixture screws, let alone sync the carbs. After replacing the rear sprocket and installing non-o-ring chain, I rode around the block once or twice and realized that my chain instantly loosened up a bit, making the shifts loose and disconnecting the feel from the rear wheel and engine. Properly tensioning drive chain and adjusting mixture screws (probably also need a bigger pilot jet for the new cams) should tighten the feel back with the original spring and shifting. Still have that little blue bastard sitting in storage waiting for me to play with it... Maybe I should just mail it to you and write off my hopes for getting this bike dialed in due to current work load. Haven't been much help as of yet, my apologies. Bear with me. All things, in proper time.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
August 17th, 2015, 11:56 PM | #52 | ||
@corksil hey perfectly understandable, life happens. If you want to send that spring my way, PM me.
And here's some tips on tuning the idle mixture screws, and syncing the carburetors. Also I suggest PM @ducatiman for for carburetor needs. Quote:
August 18th, 2015, 04:58 AM | #53 |
Fast-Guy wannabe
MOTM - Jan '13
I guess I should have mentioned the spring I measured was out of my 2009 250. From the sounds of it, you guys could also just pop in a newer gen 250 OEM spring and heat nearly twice the load seeing as the wire thickness is double.
August 18th, 2015, 10:11 AM | #54 | |
I did purchase a Blue Magic Spring from a forum member, so when I get it I'll update with the measurements, and ride test.
August 18th, 2015, 10:21 AM | #55 | |
So I checked the part# for 2009 Ninjette spring, and here's what Partzilla had to say
August 18th, 2015, 10:43 AM | #56 | |
Fast-Guy wannabe
MOTM - Jan '13
Can I assume your measuring with metrics and calculating you inch equivalents? Ether way what your measuring seem much lighter then what I have in my bike. I bought my bike with 1500 miles on it from the original owner but he didn't mess around with any engine mods so I doubt he'd have changed the spring. |
August 18th, 2015, 10:49 AM | #57 | |
But the 92081-112 SPRING is definitely thicker, longer, and stiffer, even if my measurements are off, the difference between the two are measurable.
August 18th, 2015, 04:49 PM | #58 |
Join Date: Feb 2015 Motorcycle(s): 286, 296, 599, 799 Posts: 436
a freshly openend blue magic spring, whicjh isn't really blue by the way.
Measures; free length 35.5mm OD 7.8mm ID 5.5mm wire dia 1.12 |
August 18th, 2015, 05:06 PM | #59 |
Fast-Guy wannabe
MOTM - Jan '13
August 20th, 2015, 12:11 PM | #60 |
Fast-Guy wannabe
MOTM - Jan '13
Ok so who wants springs
They only came in packs of 5 so I have .40" thick to match my OEM 2009 spring and .48" which is about twice as stiff. I'll just cut them to length and make as many as I want. |
August 20th, 2015, 12:25 PM | #61 |
Okay I'm in on the 48
August 20th, 2015, 02:01 PM | #62 |
Fast-Guy wannabe
MOTM - Jan '13
Initial impression shifting with the .048" at 1.25" long is damn this thing is stiff. Let's just say you couldn't use anything but proper riding boots to pull up on the shifter because your going to need the leather and armor with how much pressure your going to need to get it to shift. The trans on my bike has always left much to be desired in the smoothness department so I'm not sure how well this is going to jive with its clunkiness. Going to test ride it home in a little bit.
August 20th, 2015, 06:13 PM | #63 |
Fast-Guy wannabe
MOTM - Jan '13
Ok so I don't like the 0.048 spring at 1.25" and I doubt shortening it .125" is going to help much. It just to damn hard to push the shift lever for my liking. I do have aftermarket rearsets and I've shortened the throw of the shift lever which reduces leverage but make for a shorter movement to shift. Maybe someone with stock rearsets wouldn't find it so hard to shift. I'm going to cut a 1.125" spring out of the 0.040" coil and compare the feel to my OEM spring. If I do mail these to anyone I'll probably include a few so you can test which one you like the best. It's a quick job to change the spring but it a tight fit for your hand so it best done when the motor isn't hot.
August 21st, 2015, 08:44 AM | #64 |
Measurements of Factory Pro Blue Magic Shift Spring
Okay it arrived today, thank you @DCMoney so on to the measurements, Length=35.1MM I.D.=5.4mm O.D.=7.9 Wire diameter=0.9MM Pinch test, noticeable a little bit stiffer compared to the 92081-112 SPRING. Will do a ride report after my ride tonight, so stay tuned..... Picture below: Left=92081-112 SPRING Right=Factory Pro Blue Magic Shift Spring
August 22nd, 2015, 08:52 AM | #65 |
Factory Pro Blue Magic Shift Spring Ride Report:
Well it's definitely stiffer than the 92081-112 SPRING, perhaps too stiff for my liking. It does for sure make a positive shifts, but in traffic it's a bit of a PITA. I know what you thinking, man up well that's not the case, it a matter of riding comfort. Personally I'm going back to the 92081-112 SPRING, it was noticeable stiffer, but not overly stiff. My final word on this subject is if your looking to stiffen up the shifts, then the 92081-112 SPRING is the cheap answer.
August 22nd, 2015, 05:15 PM | #66 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Thanks for the good, honest assessment.
August 22nd, 2015, 06:47 PM | #67 |
My pleasure, I'm sure for most riders the 92081-112 SPRING, will be enough of a difference, but yet not overkill.
It helps tighten things up just enough, IMHO the Blue Magic Spring is a bit too much for the everyday rider, I can see it for track use.
August 22nd, 2015, 07:34 PM | #68 |
Freedom for Germany
Thanks again, Scott
August 22nd, 2015, 09:04 PM | #69 |
Fighting Texas Aggie '05
did we ever decide if the factory "upgrade" spring was stiffer than the OEM newgen spring? I read back a few posts but there was some measurement "questions" that muddied the water a bit.
August 22nd, 2015, 10:46 PM | #70 | |
Try to contact @rojoracing53 he might send you some of his springs to try out, or order the upgrade OEM spring and give it a try yourself, it's only a few dollars.
August 23rd, 2015, 02:57 PM | #71 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
I bought one on ebay and it is exactly the same as the new gen.
i was hoping it was longer or a thicker wire, but that was not the case. |
August 23rd, 2015, 03:04 PM | #72 |
Looks like I might be right about the spring being for the PreGen
August 25th, 2015, 12:01 AM | #73 |
Can anyone post a schematic diagram of the spring in question and it's placement on the engine?
August 25th, 2015, 12:39 AM | #74 | |
The spring is # 92144 Hope this helps, if not let me know
November 19th, 2015, 07:29 AM | #75 |
Join Date: Nov 2015 Motorcycle(s): DR350, Ninja 250 Posts: 69
Hi all,
First post for me. Had an EX250 long, long ago as a first bike. Recently purchased another one which will get tires & battery this weekend, then serve as a commuter next week. Few things I wanted to clear up in this thread... For what it's worth, I'm an applied physics phd grad student, so take that however you will. Hooke's Law generally describes spring force (F), which scales F = kx, where k is the spring rate, and x is the displacement from the natural length of the spring. (Since coil springs are torsional springs, we really need to talk about the angular form of Hooke's law, where torque T = k*theta, k being the constant, and theta representing the angular displacement... but F = kx will work for now.) I see the pre-load misconception quite often, and it does need some clarification. Whereas the rate of a preloaded spring does not change, the force applied is generally higher than that of a non-preloaded spring. Let's illustrate with a quick visual. You all recall the formula for a line, don't you? Good old Y = mx + b, where m is the slope, and b serves as the y intercept at x=0. Spring force generally scales the same way, and it's important to understand that while the rate doesn't change, you are essentially changing the y intercept for the spring. In reality, this does translate into a higher overall force applied, assuming the same displacement (stock spring vs preloaded spring w/ shim). Let the Y axis represent force, and the X axis represent some given spring displacement. When you pre-load a spring, you're essentially 'changing the zero'.. Yes, you will get higher force for a given displacement versus a non-preloaded spring, up to a limit, which is generally when the spring coils bind and it can no longer compress. Both springs will ideally exhibit maximum force prior to coil bind. Assuming the same spring with the same rate, one preloaded and one not, then they'll both exhibit the same force prior to coil bind. The real question is... do we ever approach coil bind? In reality, the shift springs in these bikes are probably not compressed to the limits of coil bind. Thus, for any given displacement, a preloaded spring will exhibit more force. Fork springs work the same way - there has been a poor misconception flying around the web lately that the rate doesn't change, and thus it does you no good. While no, the rate does not change, you are in fact starting the spring in an area where it will exert more force due to its preloaded nature. If a rider never came close to binding the coils but still wanted a stiffer spring, shimming or preloading would help. That said, when we ride we apply forces, not necessarily specific compression displacements to the spring, so the situation is a little more complex. TL/DR: A gentle preload WILL make a spring stiffer (exert more force) for a given displacement versus a spring which starts at its natural length. As long as we don't approach coil bind, this will hold true. Once the spring is totally compressed and the coils approach the binding point, then both springs would have exerted the same force. By preloading, we start off stiffer, but give ourselves less travel. If the springs would bottom out and coils bind, this does us no good. If the springs wouldn't normally reach coil bind, then preloading can yield stiffer operation. Lastly... If somebody can send me that spring, we have equipment in the lab that will easily measure spring rate, and give a nice data plot. Ironically, I worked as a lab TA this semester for a basic undergraduate physics course. Students measured the spring constants for a variety of springs. |
November 19th, 2015, 07:32 AM | #76 |
Welcome Patrick!
November 19th, 2015, 08:09 AM | #77 |
Thanks!
Started on an '05 250, and progressed through an SV650, XR250L, VFR800, DR350. Finally back to the just purchased Ninja, which currently shares the garage with the DR. Come hell or high water, it'll be on the road by the end of this weekend. |
November 19th, 2015, 09:01 AM | #78 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
Sorry @Kestrel; I can only remember 2 math formulas. I guess because they both influence so much of my life!
#1 is: How many motorcycles is the correct number to own= n+1 Where n= the number I currently own. #2 is really #1 (read through and you will soon understand): +1 / -1 It appears no one has formally documented this formula. Everyone knows about it, but no one really talks about it. I didn't really understand it until just recently. Turns out it resides in an unwritten handbook that only Significant Others hold as a tightly guarded secret. It explains more about motorcycling than we will probably ever truly comprehend. After lifting the veil of secrecy, I think it's time that we all know the true nature of this formula, and it's devastating impact on our sport. First rule of this mysterious formula is: the +1 can never be more than +1. It can't be +2, +3, +5 or even +10. Yes Stunters, that means you. Second rule: The -1 can be any minus number. It can be -100, but for practical application it appears the acceptable limit is -10. Now that we know the limitations of the +/- formula, here's how it applies using a few real world examples that we can all relate to: It's Saturday, you already have approval from your S.O. for a day-ride on Sunday, but you are secretly texting your riding buddies about extending the day to include a burrito dinner stop stateside (remember; I'm ) before coming home. You are in a dilemna, do you disclose the plan and risk the stink-eye (and everything else that goes along with it) and ruin the rest of the day, surely resulting in the day ending in a -10. Or, do you keep it to yourself and do something special for your S.O. today, get +1 (remember, +1 is the max each day), and use that +1 on Sunday when you text them that you will be out for dinner? How the rules apply: First, there is no carry-over from one day to the next. Each day you start at zero (or less). So get that into your thick head. You are better off to take all the minus points today, even at the risk that those carry over to the next day. Time itself will cause the ink to fade on some of these very large minus numbers. But don't be fooled, the ink never fades entirely. The magnitude of what you do to earn a +1 has no bearing whatsoever on this system. Telling your S.O. you love them out of the blue in a special moment, offering to detail their car for 2 hours, driving all the way to Gravity & Pope to return their $600 pair of boots, driving out to Merrit (twice) with the family to get the dog of their dreams, whisking them off to Maui for 10 days, etc. They are all only worth +1. Doing more than one in a given 24 hour period will net you, you guessed it, a max of +1. You need to plan accordingly, and spread your efforts out over time, and invest only where needed. Being +1 on the day is absolute VICTORY!. Unfortunately, the magnitude of what you do (or fail to do, or fail to do as expected) does have a bearing on the scale of the minus system. As noted above, -10 is teh accepted daily maximum. There are exceptions (no one will ever really know what these are), and unlike the plus system, these can carry over to the next day/week/month/year.......pretty much forever. This is why grovelling was invented. Couple Other Observations: I learned that +1's are not transferable between families, In other words, doing something special for a friend's S.O. has no impact on your own system. Even if the two S.O's are fully aware and joint acknowledge and accept the good deed, and even though they are fully capable of transferring the credit, they never will. The +1 will also never get credited to your friend. It's like throwing money away. The only value in these types of deeds is to get +1 with your friend's S.O., but the system is so complicated as it is, and this cross-family flow of currency is so corrupt, the exchange rates terrible, I highly recommend you refrain from this. If you do feel compelled, keep it simple, like tell them how nice their new shoes are, and keep it at that. Try and defer your efforts to get +1 to later in the day. Yes, you will have less time enjoy being +1, but the odds of you getting -1's thoughout the day are significantly higher, so using it early means you risk an immediate correction with a -1 that was already locked and loaded and waiting to be fired. This is a tough decision and I don't really know what the consensus is here. I usually wait until at least noon to try and get a gauge on the day then put my plan in place. If I am already -3 by lunch, pffft, forget it, I'll keep it until tomorrow. What's the difference between going to bed at -5 and -6? I have also found it best to do a few subtle tests to get a better feel on how well it might be received. This way I won't waste my one chance. +1's most certainly cannot be banked for long periods of time. They cannot be frozen like sperm to be re-used when convenient. Let's say you like to ride every Sunday for 6 months in the summer. That's 24 weekend days you are not with your S.O. and/or family. One would think that if the same consideration were given to your S.O. in the off season (ie: they take pole dancing lessons every Sunday for 6 months) that that somehow works out to be even. If you even remotely believe this, then you are completely lost, and you will need more help than anything that this thread can offer with the replies that ensue. Good Karma: In the old days I could plagiarize with impunity! Unfortunately now; I must give credit where credit is due: CoolDaddyGroove, a moderator on BCSportbike, posted the +1/-1 doctrine back in 2012. It has proven far less theoretical than E=m(c*c)! ....HEY! I know 3 math equations!!! p.s.: Welcome Patrick!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
November 19th, 2015, 09:15 AM | #79 | |
... But after that, you lost me! Though seriously - if somebody wants to volunteer to send me those springs, I'll get some nice quantifiable data so we can stop guessing. I suspect 92081-112 is the budget answer for most people, but it would still be nice to see the actual spring rate. Furthermore... It wouldn't be too difficult to figure out how far the springs are being compressed when installed, either. Approximate with a caliper, adjust for any offset of the 'plug' the spring sits within, and crunch the numbers. Because of the slight variation in spring length between the OEM, the other OEM option (112), and the Factory Spring, it does make a difference. Rate is one thing, but it doesn't mean much unless we know how much each spring is actually pushing at the installed position due to preload. |
November 19th, 2015, 10:05 AM | #80 |
Participant
Welcome, Patrick! And, finally, someone who understands the nature of springs, force, and spring rates. Good job!
With respect to # of motorcycles... 3 was one too many for me: 2 is just right. |
Factory Pro Detent Arm Shift Kit | Surferboy120 | 2013 - 2017 Ninja 300 Tech Talk | 62 | February 13th, 2019 07:41 PM |
FactoryPro Shift Spring -- anyone used? | abhijitz | Ninjettes At Speed | 2 | May 15th, 2014 05:35 PM |
[kropotkin thinks...] - Honda's Magic Gearbox: Worth A Few Hundredths A Shift | Ninjette Newsbot | Motorcycling News | 0 | March 19th, 2011 05:01 AM |
blue magic | blue magic | New Members | 12 | June 14th, 2010 11:50 AM |
