Old April 21st, 2011, 05:59 PM   #1
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
Slolane's Touring Ninjette
After months of going back and fourth on what luggage to mount to my 250 and how to do it I decided to go ahead and mount some Givi E-21's to compliment my existing hard locking topcase. I debated on just having 2 top cases, the one I have now and a huge one for trips and such but decided against that in the end since I didn't want any boxes that I felt were too big. I had E-21's on my ZX14 and really liked them.
Having never done any bracket fabrication before please go easy on me. I started lurking on many forums that cover metal fabrication, welding and the like to get some ideas on how people build stuff and what techniques I may apply to this project, this was a very good approach as I am very happy with my first try.
I had some simple hand tools... drill, socket set, screwdriver, punch, clamps, a vice, hammer, and tape measure but I decided to get an angle grinder with cutting wheel to help speed the project along. Materials needed for this were: 3 aluminum strips, aluminum primer, crinkle black paint, a new torch and some mounting hardware. I will go further into this in a DIY later if all works out.
I decided I would use aluminum rather than steel even if it requires additional brackets/bracing, I now have my initial setup in place to test before paint/finishing so I can determine if it proves sufficient after some test runs. Once I'm sure this is exactly the way I want it I can do a short DIY write up with what I did.
Anyway, on to the pics...
I will add my other mods to this thread later.
slolane is offline   Reply With Quote
Old April 21st, 2011, 09:50 PM   #2
Yasko
Texas Newbie
Yasko's Avatar
Motorcycle(s): 07 Ninja EX250, 07 FZ6
That's so kool...
Yasko is offline   Reply With Quote
Old April 21st, 2011, 09:54 PM   #3
Old April 21st, 2011, 10:10 PM   #4
pugs24
pugs24's Avatar
Very cool setup. You don't live in Ellicot City, do you? Looks a lot like a neighborhood out that way.
pugs24 is offline   Reply With Quote
Old April 22nd, 2011, 07:50 AM   #5
slolane
Motorcyclist
slolane's Avatar
Thanks guys!
No, I'm in AACo.
Old April 22nd, 2011, 07:55 AM   #6
Snake
Snake's Avatar
They look great and they do not take away from the sporty look of the bike.
Old April 24th, 2011, 09:22 AM   #7
Megiddo
Motorcycle(s): 2009 Ninja 250
I am looking at possible doing the same thing. If you don't mind, could you post some pictures of the mounting system you created. I see the bracket coming from under the seat, but did you brace the cases under the rear seat to prevent them from moving toward the rear wheel? Any insight would be helpful. Thanks.
Megiddo is offline   Reply With Quote
Old April 24th, 2011, 09:36 AM   #8
bob706
bob706's Avatar
Awesome. Looking forward to your DIY.
Old April 24th, 2011, 09:40 AM   #9
setasai
setasai's Avatar
Sweet. Looking forward to your DIY. The ninja 250 is becoming a very versatile bike.
Old April 24th, 2011, 05:41 PM   #10
slolane
Motorcyclist
slolane's Avatar
Thanks guys I appreciate the comments.
I'm working on a DIY that I will post soon, since this is the first go at it I didn't want to get too far into a DIY if I had to backtrack and change a bracket or two but I'm going to try to get it posted tonight anyway.
Sure thing, I took many pictures along the way for the DIY, I will get started on that tonight. In the DIY I will describe the bracing I went with and why.
Old April 24th, 2011, 05:54 PM   #11
AMMOCAN
SLIME-R
AMMOCAN's Avatar
Motorcycle(s): *SOLD* '10 Kawasaki 250R SE A.K.A. SLIME-R *SOLD*
Very nice setup!
AMMOCAN is offline   Reply With Quote
Old April 24th, 2011, 06:15 PM   #12
setasai
setasai's Avatar
What do you use the sidecases for and how much were they back then? I've been flip flopping between the top case or side cases because I like the look of the sidecases but am not sure how much stuff would fit into it and how efficient it would be to be using them over a topcase. If you could offer some practical insight on them, that'd be fantastic, along with the DIY =)
Old April 24th, 2011, 08:58 PM   #13
slolane
Motorcyclist
slolane's Avatar
DIY posted HERE.
Old April 24th, 2011, 09:12 PM   #14
slolane
Motorcyclist
slolane's Avatar
(DIY posted in link above)
In my opinion the easiest and cheapest way to add luggage is a trunk like I did here. I decided I wanted both based on what I need to carry at different times and to be able to carry more. I'm not sure what you would need to carry but suggest getting 3 cardboard boxes that are the size of the cases you want, then you can test loading whatever you want to carry in them to see how easy it is to load and how well it packs. The good thing about the sidecases is that you could mount them differently to retain the rear seat and pegs for passengers.
Old April 24th, 2011, 10:00 PM   #15
setasai
setasai's Avatar
Hmmm I see. Thanks for the advice. I'll look into it the next time I get the chance. What do you plan on putting in the saddlehardcases? Do you think it would be efficient for groceries and take-out containers (say from a typical chinese takeout)?
Old April 25th, 2011, 06:04 AM   #16
slolane
Motorcyclist
slolane's Avatar
I split the stuff I usually have in my topcase into the two sidecases... disc lock, cable lock, bag of misc items (cough drops, power bars, advil, etc.), paper/pen, bungee net, rubber slotted strap with S hooks, tire repair kit, small air compressor, kickstand plate, rain gear, hat, zip ties, tool kit, tape, wire, rags, paper towels, windscreen cleaner, disposable camera, glasses, extra gloves.
That leaves each case about 1/2 full. I could move the items around in each case to accommodate groceries... take-out orders stacked tall such as Chinese would do better in the sidecases as they would prevent tipping based on their shape. This now leaves my topcase empty to carry groceries, laptop to work when commuting, lunch, etc.
Old April 29th, 2011, 11:35 PM   #17
Fly'in Ninja
Motorcycle(s): C-250R-ST
Thumbs up
great looking bike with the top and sides cases!!
Fly'in Ninja is offline   Reply With Quote
Old April 30th, 2011, 07:22 AM   #18
slolane
Motorcyclist
slolane's Avatar
Thanks man, much appreciated.
Old May 2nd, 2011, 03:06 PM   #19
Lou
Lou's Avatar
Motorcycle(s): GreenSE 09 250R
Wow that looks real good. Im also looking into putting some hard bags on my bike, that way i have plenty of weekend clothes when i visit SD. Does the bike feel/handle the same?
Lou is offline   Reply With Quote
Old May 2nd, 2011, 09:23 PM   #20
slolane
Motorcyclist
slolane's Avatar
Thanks
Yes, can't even tell the bags are on it. People talk about topcases/sidecases and the weight and all but it's very little difference if you can even tell. A passenger would be in the same place really and they are much heavier so unless your carrying bricks all should be good, LOL. Only time I can really tell is getting on and off, can't swing your leg over these cases, more like a punch kick. I have ridden with them a few days now and really like em.
Old May 3rd, 2011, 08:01 PM   #21
ScorpionNinja
ScorpionNinja's Avatar
Tip: For added Safety, you could add Strips of Reflective "Black" Vinyl in certain areas on all 3 Cases, for Nighttime riding!
Very cool Mod man!
Old May 4th, 2011, 08:12 PM   #22
grandelatte
Go Pack Go!
grandelatte's Avatar
Motorcycle(s): 09 250R, 07 XL1200L
Great work!
09 Ninja 250R (commuter)
07 XL1200L (weekend fun)
02 SV650S (totaled by an idiot cager) & others
grandelatte is offline   Reply With Quote
Old May 5th, 2011, 12:35 PM   #23
slolane
Motorcyclist
slolane's Avatar
Originally Posted by grandelatte View Post
Great work!
Thanks
Here is the updated pic with mounts and top case trim painted black...
Old May 5th, 2011, 01:30 PM   #24
Buffalony
Buffalony's Avatar
This looks really good. looks like a Projobber. I think you found your calling
could you please post a picture of the hardware you fabbed up to accomplish this mount. I just want to see how it was done.
Congrats
Old May 6th, 2011, 12:44 PM   #25
KGar
Mid Life Crisis
KGar's Avatar
Motorcycle(s): 2010 Ninja 250r (Passion Red); 1999 BMW K1200RS (Marrakesh Red)
Thanks
Great job makes me want to take a road trip!
Kleen Air removed, Cali emissions removed, drilled slides, 15/43 JT's, 150/60 Rear
KGar is offline   Reply With Quote
Old May 6th, 2011, 08:33 PM   #26
slolane
Motorcyclist
slolane's Avatar
Congrats
Thanks!!
As for the hardware, check out my DIY... DIY: Hard locking saddlebags (luggage), it's all posted up there. Anything else just let me know.
Yup... I'm going to do a couple trips this year and a camping trip or two, can't wait!!!
[onewheeldrive.net] - 2013 Ducati Multistrada 1200 S Touring ? Touring Mode and Retur Ninjette Newsbot Motorcycling News 0 August 1st, 2013 11:30 PM
[RoadRUNNER] - Touring Tip: Setting Touring Priorities To Maximize Your Enjoyment Ninjette Newsbot Motorcycling News 0 June 17th, 2013 01:50 PM
Blog Post: 2-up ninjette touring akima General Motorcycling Discussion 2 May 12th, 2012 05:29 PM
Slolane's 2011 White 250 SE slolane Pictures 33 April 10th, 2011 07:46 PM
CT to Indianapolis - touring on the Ninjette adouglas Ride Reports 29 September 13th, 2009 07:55 PM
