Old October 22nd, 2015, 09:55 PM   #1
AchyGrappler
Motorbike Obsessed
AchyGrappler's Avatar
Motorcycle(s): 2004 Kawasaki EX250, 2004 Yamaha FZ1, 2006 Honda CRF 450 Flat Track Race Bike
Current owner - hopeful racer
Hello all. After a buddy's misfortune and some craigslist tomfoolery I have become the proud owner of a recalcitrant 2004 Ninjette. I am working on a hanging throttle condition while trying to prep the bike for racing at Chuckwalla this season. I have been a lurker for a while to help with troubleshooting the problem so thanks for all of the information so far.
AchyGrappler is offline   Reply With Quote
Old October 22nd, 2015, 10:10 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
AchyGrappler! Glad you found us...
Old October 22nd, 2015, 10:18 PM   #3
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
Welcome!!
Hanging throttle eh? dirty carbs, pull em and clean em. @ducatiman does some good work with those things, shoot him a pm, and don't be afraid to take them out, its realllllly easy, its something about your bike you should get to know.
Burn Rubber, not your Soul.
xXecuterXx2 is offline   Reply With Quote
Old October 23rd, 2015, 06:27 AM   #4
cuong-nutz
cuong-nutz's Avatar
You must flesh out this misfortune of your buddy's and tomfoolerishness.
Hanging throttle-- Bike was dropped--throttletube grip is rubbing against the bar end or bar is bent under the throttle tube and now allowing the throttle to close back in snappy fashion.
Bike running lean can cause the throttle to hang. Also make sure your idle is set right as well.
HalfFast Racing Team
Old October 23rd, 2015, 07:48 AM   #5
Welcome!
Old October 23rd, 2015, 08:14 AM   #6
cbinker
cbinker's Avatar
mmm another ninjette at chuckwalla!
TEAM ALFALFA
www.apexassassins.com
Old October 23rd, 2015, 11:38 AM   #7
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
Where in SoCal are you? I'm in Torrance!
You'll want to do the 17inch wheel conversion. I'll fight you for a front end. But I'm also willing to help you get the bike sorted if you need it.
Welcome to the forums!
cookiebug79 is offline   Reply With Quote
Old October 23rd, 2015, 12:54 PM   #8
AchyGrappler
Motorbike Obsessed
I'm in Oxnard, but I head to Torrance a couple times a year to hit up the Japanese markets. Right now I'm just getting the basics set up while trying to fix the hanging throttle.
As for that, I have done the following:
1) Replaced the spark plugs, carb holders, air box boots
2) disassembled the carbs and ultrasonically cleaned the small parts, cleaned the bodies in a homemade parts washer, complete blow out with a compressor
3) adjusted the valves
4) made numerous tests of mix screw adjustments 1/2 turn at a time
Still hangs. I want to replace all of the hoses on the carbs, but got two screws that won't free up so that I can split the bank.
Kind of stuck on that for now. I really need to fix this issue before continuing on with the race bike preps.
My race Ninja build and more motorcycle content. My Motorbike Obsessions
Old October 23rd, 2015, 01:09 PM   #9
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Just remember racing is dangerous (and fun), costly (and fun), addictive (and fun), exciting (and fun), life changing (and fun), deadly (and fun), educational (and fun), rewarding (and fun), and memorable (all the fun). Other than that there's not much to it!
Old October 23rd, 2015, 01:55 PM   #10
cookiebug79
n00b with the b00bs
Before you put the carbs in an ultrasonic cleaner, did you pound out the plugs to the idle screw under the carbs and remove the idle jet, spring, washer, and o-ring?
There's nothing splitting the bank will do to help the throttle hanging, so don't put a lot of effort into that.
Old October 23rd, 2015, 03:17 PM   #11
AchyGrappler
Motorbike Obsessed
I'm looking forward to the fun (and expense and danger and excitement and reward and all of it) with great expectation.
Yep, plugs are out and I've been doing test and adjust as I have replaced parts always resetting back to 2.5 turns out to start the next series of tests.
Old October 23rd, 2015, 04:08 PM   #12
cookiebug79
n00b with the b00bs
Ok, just checking you didn't ultrasonically clean the carb bodies with the o-ring in the idle circuit.
It sounds like the spring is bound on top of your diaphragm.
If you leave the carbs together and blow air in the crescent shaped section of the air intake, does the slide move up and down freely?
Old October 23rd, 2015, 05:23 PM   #13
AchyGrappler
Motorbike Obsessed
I did the opposite. I put a shop vac on the inlet side and worked the butterfly to verify that the slides move and they did.
The only reason I'm going to try to pull the bank apart is to replace the hoses and check for something I can't see.
Old October 26th, 2015, 12:54 PM   #14
Hello and welcome
Old October 26th, 2015, 02:38 PM   #15
snot
sammich maker
snot's Avatar
MOTM - Apr '15
welcome
[roadracingworld.com] - FBI: Former Racer Owen Weichel And Former Racer/Team Owner/Po Ninjette Newsbot Motorcycling News 0 August 30th, 2013 10:00 AM
[superbikeplanet.com] - FBI Indicts Former Racer, Race Team Owner Ninjette Newsbot Motorcycling News 0 August 30th, 2013 08:50 AM
[roadracingworld.com] - Former Road Racer Chris Carr And Current Road Racer JD Beach Ninjette Newsbot Motorcycling News 0 October 25th, 2012 11:50 AM
Hopeful new owner MLecl0001 New Members 8 April 8th, 2012 07:38 AM
[roadracingworld.com] - How Former Road Racer Chris Carr And Current Road Racer James Ninjette Newsbot Motorcycling News 0 August 18th, 2009 10:30 AM
