September 17th, 2017, 12:54 PM | #1 |
Join Date: Jul 2017 Motorcycle(s): 2007 Ninja 250 Posts: 17
Pilot jets and idle mixture screws won't screw in
So i was cleaning my carbs and went to screw the pilot jets and idle mixture screws back in and for some reason they just won't grab and go in. Both the female and male threads are in perfect shape. Any thoughts?
September 17th, 2017, 01:07 PM | #2 |
Thats odd....are you putting them back in their correct locations?
September 17th, 2017, 01:33 PM | #3 |
Yup. I double and triple checked with all the carb photos on the faq. And I tried both screws on both holes. It's bizarre.
September 17th, 2017, 06:21 PM | #4 |
Post some pictures if you can.
I was thinking you may have had something mixed-up as well. |
September 18th, 2017, 09:22 AM | #5 |
so what now, rusty?
September 18th, 2017, 09:42 AM | #6 |
I figured it out. I am not a smart man. That's all I'll say the rest I'm taking to the grave.
September 18th, 2017, 11:07 AM | #7 |
September 18th, 2017, 11:11 AM | #8 |
September 18th, 2017, 01:06 PM | #9 |
September 18th, 2017, 07:50 PM | #10 |
but in the big scheme of things....
A:you did it B: you learned for next time *********************************************************** My learning experience for today....re doing a Harley Davidson (made by Keihin) 40mm CV "pumper" carb.....very similar to EX. For the accelerator pump Keihin used a diaphragm very similar to that used in the decel valve on your EX carbs. And a big, fat float valve...again so similar...but huge in diameter. The pump diaphragm is decomposing...the float valve tip has a wear ring and the whole tip is tilted...so both parts are shot. The pilot mixture screw was frozen (I freed it) and everything is generally mucked and in need of refresh. Sound familiar? a mid 2000 era Sportster sitting dormant for years. The owner picked it up for next to nothing. ...I'll order the required parts and easily knock this thing off. Reminds me to snap some before and after pics. And I, too, have learned for next time.
September 19th, 2017, 03:44 PM | #11 | |
what is the best idle screw mixture | vmax | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 1st, 2017 10:45 AM |
Question about idle mixture screw and low idle flux | daverdfw | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 2nd, 2016 10:36 PM |
Idle Mixture Screw Problem | gogoKawi | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 23rd, 2013 07:07 PM |
Adjusting the Idle Mixture Screw | conrya5 | 2008 - 2012 Ninja 250R Tech Talk | 22 | March 18th, 2013 05:03 AM |
Idle Mixture adjustment screw Q | indr | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 2nd, 2010 09:36 PM |
