#1 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
What lube should a use for the choke slide?
My choke slide mechanism is sticking sometimes in the mornings which I am sure makes my neighbors very happy. What lube would you recommend?
#3 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
WD-40, spray lithium lube, even thin all-purpose oil would be best... However, if it's binding, it's not just about lubing, it's also about cleaning. There is gunk in there... Get yourself a cable lubricator and hose down the inside with WD-40 and compressed air... then lubricate.
and get to the other end on the carbs to catch the extra fluid on the other side, otherwise you'll create a mess around your carbs, and nobody likes a dirty carb. ![]()
![]() My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
#4 |
You've got a few areas to evaluate and consider...the handlebar lever mechanism, the cable, the choke bar on the carbs (which slides on plastic washers and utilizes a return spring) and the actual brass plungers (enrichener slides, if you will)
what lube and corrective action depend on the specific area causing the problem. Leave the handlebar mechanism dry cable lube (obvious) white lithium grease on the plastic washers clean and polish the brass plungers |
#5 |
cadd cadd cadd
MOTM - May '15
Anyone used Triflow before? I use this religiously on my bicycles. Never had a rusted brake or derailleur cable. I used to commute via bicycle. Keeping the bikes in tip top operating order was a top priority.
Wondering if anyone use Triflow for motorcycle cables.
Riding it like I financed it. ![]() |
#6 |
^ been around in MC shops for years, sold it in the mid-70's when working at a dealer. Customers loved it, contains teflon, worked good in many applications. Became repeat customers.
![]() 2 out of 2 members found this post helpful. |
#7 |
i prefer to use KY when i'm choking someone. the warming stuff is good too.
#8 |
ChocolateMilk Addict
Join Date: Mar 2015 Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock" Posts: 329
#9 | ||
Chain Lube | seth hall | General Motorcycling Discussion | 15 | August 23rd, 2014 01:07 PM |
Chain Lube! | Obey Reaper | General Motorcycling Discussion | 20 | July 20th, 2014 07:07 AM |
did i get the right chain lube? | RogerPapaMike | 1986 - 2007 Ninja 250R Tech Talk | 15 | July 5th, 2014 08:44 AM |
Chain lube! | corksil | General Motorcycling Discussion | 27 | June 20th, 2014 06:27 PM |
Lube for ignition? | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 9 | March 5th, 2010 05:35 PM |
