#1 |
Learning to walk
Join Date: Jul 2015 Motorcycle(s): 06 Red Ninja 250 Posts: 48
Oil Change
I'm getting all my supplies ready to perform an oil change and have a question that I hope someone has had some experience with. It's regarding an oil filter I am looking at buying and I can't find a clear answer to it anywhere on the old "Google Machine". I found the Fram CH6012 oil filter at my local wally world and it's supposed to be compatible with my 06 ninjette. So, here's the question: the Fram oil filter clearly states it comes with both of the "O rings" but does it include the crush washer??? And if it doesn't is that a part I will need to go to a dealer for?
Thanks in advance!!!! |
#2 |
I'm pretty sure the answer to the first is no, and the answer to the second is definitely no.
You can get crush washers at an auto parts store or Cycle Gear. Do yourself a favor... order a bunch off of Amazon or eBay. Cheaper that way and you'll be set for life. It is not a crime to re-use a crush washer. Your bike won't explode or hemorrhage oil. I wouldn't do it more than once or make a habit of it, though.
#3 |
Learning to walk
Awesome! Thank you for the quick response! Sorry if this was a dumb question I am pretty inexperienced in all of this.
#4 |
Join Date: Nov 2014 Motorcycle(s): EX250, Suzuki Savage, 76 Goldwing restoration project, 71 CB350, 73 Yamaha GT1, Posts: 73
The 6012 does not have the crush washer but does have both O rings.
I just changed my oil this weekend and used one of those. |
#5 |
FYI the crush washer is 12mm very common at any parts store.
It's a good move to buy in bulk, so order some, along with the filters. Personally I went with a Flo Stainless Steel Reusable Oil Filter
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. ![]() |
#6 |
Learning to walk
@Ghostt is the flo stainless steel filter available in auto parts stores or cycle gear? Or is it an order online thing? I'm assuming that pic contains everything in the box?
#8 | |
Some examples, https://m.denniskirk.com/307362.sku?..._3VBoCdFzw_wcB http://www.ebay.com/itm/181661598423
#9 |
Learning to walk
Cool, I'll make sure to try that model next.
#10 |
I'm at 82K miles and am on my second crush washer. The only reason I'm on my second one is that I had to swap the motor at 55K and it came with another crush washer.
#11 |
Daily Ninjette Rider
Join Date: Jul 2014 Motorcycle(s): 2012 Ninja 250R, 2015 Vespa GTS 300 IE Super, 1989 Honda Elite 80 (SOLD) Posts: 402
I've reused crush washers several times over the years on bikes and cars, @adouglas said it best.
![]() ![]() Check out my music at http://www.proteusmusic.com |
#12 |
Learning to walk
@FrugalNinja250 and @Proteus Thank you for the reassurance. I just got my bike about a month ago, it has 16.5K miles on it. Obviously buying used means you have no idea how the previous owner cared for it but so far everything appears to be in decent shape. However, I couldn't find an answer anywhere on if it was frowned upon to reuse the crush washer. Now I can go ahead and do my oil change without stressing!
#13 |
Learning to walk
Update on the oil change: I got it all done and cleaned and replaced everything. I went through the process of filling with new oil slowly, starting the bike, letting it idle for a min, shutting it off and checking/refilling with oil until I got an accurate reading (which I left just below the upper mark on the window). After riding it into work this morning the oil level in the sight glass is showing higher than last night when I finished filling it. Is this normal with an oil change? Or should I be checking for anything?
#14 |
I would expect it to be slightly higher because it's hotter after reaching operating temp than when you tested it last time after brief idling.
It should be checked after turning the engine off and waiting 3 minutes for the oil to drain down from the top end and passages. If you wait longer it might be higher - lower if you check it immediately. Hotter oil will drain down faster also. |
#15 |
Learning to walk
I figured it would be something like that. I just wanted to make sure because I check the oil every time before I get on the bike. This morning before I left for work, it was at the same spot as last night, but then when I got to work it was higher. So basically it's due to the oil being hot and flowing quicker?
#16 | |
#17 |
Learning to walk
@Ghostt I did have that issue a while back that I wrote about on ninja250 where I had a strong gas smell in my garage. I thought I checked the petcock and everything pretty thoroughly then. The oil didn't smell like gas in the crankcase or in the oil pan that I drained the old stuff in. Is there a possibility that I have a shot float needle and being inexperienced I'm missing it? Is there a clear way to check for it other than what I've already done?
#18 | ||
Also if your in doubt about the petcock, I'd just get a new one, also given the age as well. Quote:
#19 | |
Just make sure it's not over the full mark when you check it fully hot (and after sitting for 3 min) and you are fine. Most Ninja 250s will use some oil when running higher RPMs (and that's most of the time), so check it often. |
#20 |
Learning to walk
I have not done the fuel filter. The last known maintenance on the bike before everything I've done was April '14. That was when the prev owner did the 15K service. It's now at 16,700. I may just play it safe and have it refurbed. IF there was gas getting into the oil, wouldn't that create a pretty big problem pretty quickly?
#21 | |
I seriously doubt that when they did the service they refurbished the carburetors. The float needles have a small viton/rubber tips. As the picture below shows the difference between old Vs new. This is a picture of mine, which lead to this posting "How to clean the crankcase, and airbox without disassembling" Gas and oil don't mix well for engine lubrication, also consider replacing the petcock, it does have a rubber diaphragm, which after time needs/should be replaced, along with O-rings etc..... If your planning to keep the Ninjette for awhile, all this I would say preventive maintenance.
#22 |
Learning to walk
Thank you for all the great info! I contacted ducatiman and I am most likely going to have him service my carb. I guess while I wait on that I can perform all this other stuff since the bike will be out of commission.
I'm not planning on keeping THIS bike very long, I am 95% sure I will be getting a '14 or '15 ninja 300 within the next 6 months. So, if I may ask, in your opinion is this all worth it or do I just let her live out her last few months? |
#23 | |
The 250 is an extremely good bike, and with a few inexpensive modifications it handles, and runs very good, and the best part is parts are dirt cheap.
#24 |
Learning to walk
I would like to get a 600, but I'm a smaller guy (5'7" 135lbs) and I absolutely love the displacement and weight of the 250/300. The handling and everything is perfect for me. My ultimate plan was to get a newer 300 in a few months, spend a few years on it, then move to a 600 or litre.
Who knows, maybe I'll keep this one (her name is Rizelda) as a project and to keep things fresh and one day hand it down to the first born.
#25 | |
#26 |
Learning to walk
Yeah, I'm partial to the newer style. Plus the little extra power, ABS and fuel injection. But beyond that I think it's the peace of mind. This 250 has 16K miles of unaccounted for use and maintenance. With a brand new bike I can start from scratch and if something goes wrong it's on me you know? I was originally going to buy a new 300 but saw this one on CL and got it for a sweet deal so I thought I would give it a shot.
The main reason I would take a 300 over a 600 6 months from now is just the difference in price.
#27 | |
Well to get back to your question, is it worth doing work to? As far as the bike's reliability goes I'd say yes, personally if I don't/can't trust a vehicle, then I either fix it, or sell it. Come sale time, it makes a nice selling point, but adds little or nothing to the resale value.
#28 |
Don't be in any hurry to "step-up". I think the 300 would be a good move for you, but give yourself some time on the 250 first. A 600 SS is a HUGE step up, not only in outright performance, but weight and insurance as well. Bigger isn't always better, and a 600 SS is a much different ride than what you are familiar with.
I've been riding for over 35 years, and have yet to want a liter bike. I've had a 750 SS, but prefer a more streetable (not as racer-ish) bike like the 250 or my SV650. The SV feels a bit on the heavy side after coming off of a 250. The power (torque) of the 650 is nice, but I rarely call on max power, and probably would be happy with a Ninja 300 myself. A riding buddy (also with over 30 years of experience) of mine just sold a newer Triumph Daytona 675 and bought a KTM RC390. He's got less than 1/2 the power he had before, but is much happier with the smaller/lighter KTM. |
#29 |
Learning to walk
Good point. I suppose I will want someone to be able to enjoy it after me.
I'll send the carbs off to ducatiman, and while I wait on those I'll replace the petcock and fuel pump. If I understood your advice correctly, that should cover all the bases as far as the gas getting in the oil right?
#30 |
Learning to walk
@jkv45 that is exactly what I feared about getting a 600 so soon. I'm used to riding HD's but always wanted a Ninja. I never made the switch because I feared the differences in style and having all the available power of a 600/litre bike. Then I found out about the 250/300, I don't think I'll move past a 300 for quite some time. I have had my 250 for about a month and not once have I used all the power. Plus, there have already been 3 occasions that if I had a 600 underneath me I would have at least some bumps and bruises. The forgiveness that these bikes have is absolutely incredible.
#31 | |
#32 |
Learning to walk
LOL. My bad, I meant fuel filter. I have a feeling I may be searching forever trying to locate the fuel pump.
#33 |
LOL, you'd be correct. Is there already a fuel filter on the bike?
#34 |
Learning to walk
I'm not sure actually.
#35 |
It's easy enough to spot, it's an inline the fuel line between the tank and the carburetors.
#36 |
Learning to walk
No fuel filter on this bike. I will definitely have to look into adding one.
#37 |
Definitely, motorcycle shop should have them.
#38 | |
The minute you move up to a bigger/heavier/more powerful cycle you quickly give some of that away. My son has been riding cycles since he was 4, and I still insisted he start street riding on a 250 - that was 3 years ago. He is still riding his original 250, and bought another as a project because he likes the light weight, quick handling, and high revving engine - so not everyone "outgrows" their 250. I'm getting some flack right now on another forum for suggesting the SV650 isn't the great starter bike everyone thinks it is, and suggesting that starting on a 250 is a much better idea. |
Is it normal for oil to increase a bit in the crankcase after an oil change? | cadd | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 15th, 2014 08:38 PM |
Synthetic oil at 300 mile oil change? | anacron | 2013 - 2017 Ninja 300 Tech Talk | 14 | July 29th, 2013 04:58 PM |
Oil drain plug gasket for oil change. | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 10th, 2012 01:00 PM |
Oil change | sam-c22 | 2008 - 2012 Ninja 250R Tech Talk | 9 | May 31st, 2012 11:41 PM |
change oil filter, without draining oil? | peter330 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 30th, 2010 01:08 PM |
