April 8th, 2014, 11:13 PM | #1 |
Front suspension maintenance?
I have a question about my suspension. My buddy says I need to have the suspension worked on because it's super lose. Hitting a speed bump causes it to bottom I guess. You here a clunk when hitting a bump. My manual says to inspect the suspension at 15000 miles how do I know if it's time to work on them? I can't find a this how you know it's time to do your ssuspension guide haha.
April 8th, 2014, 11:26 PM | #2 |
push it all the way down then let it bounce up. does it come up smoothely? or does it shoot back up like an undampened spring?
April 8th, 2014, 11:27 PM | #3 |
April 8th, 2014, 11:28 PM | #4 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
Your bikes suspension setup will generally depend on how much you weigh and your riding style. Your forks bottoming out might just be because of that. Get stiffer fork springs and fresh oil and you should be good to go.
As far as suspension Maintenence is concerned, some people on this site change their oil at least once every year... Seals wouldn't need replacing unless they are leaking, but considering the bike is 6 years old, you might as well do that as well for peace of mind. Good luck! |
April 8th, 2014, 11:35 PM | #6 |
April 9th, 2014, 06:38 AM | #7 |
A couple of things to consider also.
How fast was your buddy going when he hit the speed bump? How much does he weigh? Do the forks bottom out on you? I thought I had my forks bottom out on me once. I hit a nice bump where they were doing construction on the road. The pavement was uneven and i hit it kind of fast, and heard a clunk. Later i found out it wasn't the forks bottoming out, but my Fiamm Horn (which is bigger than stock) hit the top of the fender. I knew that by the scratch it left. I still couldn't get it to bottom out after that regardless of how I checked it. The one thing you need to do is check what the inspection and adjustment standards are, then do them. |
April 9th, 2014, 12:41 PM | #8 | |
Upgraded front suspension, front end tuck | Ginganinja | 1986 - 2007 Ninja 250R Tech Talk | 12 | October 30th, 2014 10:27 AM |
Front suspension | Bigballsofpaint | Ninjettes At Speed | 58 | July 12th, 2014 09:42 AM |
Front suspension question | gasguzziler | 1986 - 2007 Ninja 250R Tech Talk | 18 | May 7th, 2014 12:05 PM |
Front suspension upgrade | Rollingmenace | 1986 - 2007 Ninja 250R Tech Talk | 3 | October 4th, 2013 07:42 AM |
Front suspension | joseg1981 | Ninjettes At Speed | 15 | February 27th, 2013 11:11 AM |
