Old February 20th, 2013, 01:40 PM   #1
joseg1981
Motorcycle(s): 250 kawasaki
Front suspension
In debating on what to use as far a front setup! Any suggestion from the fast guys out there will be appreciate.
joseg1981 is offline   Reply With Quote
Old February 20th, 2013, 01:44 PM   #2
depends... i see you are in florida so you might want to consider a springer front end. if you like going fast, forks are pretty good. swingarms look great in front. i especially like the BMW style telelever arm. looks so sexy and is probably one of the higher performing frontend setups. might have a hard time mounting it on the little ninja 250 though!
Old February 20th, 2013, 01:58 PM   #3
joseg1981
Suspension
Trying to built a race bike for the 250 class.. so no forks modification !!just internals I'm 5 '7 and weight about 165
I went with a rpm 2 way shock for the rear but I don't have any idea for the front
Old February 20th, 2013, 02:02 PM   #4
the fast guys here run springs with preload adjuster caps, and emulators for damping valving. ohlins (and some other italian and chinese rip-offs) make full cartridge drop ins with external damping and preload control (on the fork caps so no external modification means it passes most supersport rules) those cost about $800 but are going to give you the best superstock racing suspension on the market
Old February 20th, 2013, 02:20 PM   #5
dino74
dino74's Avatar
These require removal of the damper rod but some class rules say you must use the original damper rods(modified or unmodified).
CVMA #55
Old February 21st, 2013, 03:46 AM   #6
psych0hans
psych0hans's Avatar
Fork oil, new springs, emulators and preload adjusters... Please chip in if I missed something... If you don't want good valves you get some big piston something's which do the same work... I forget who makes them...
Old February 22nd, 2013, 09:03 AM   #7
smokinsingle
L8APEX
smokinsingle's Avatar
Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org!
http://www.ninjette.org/forums/showthread.php?t=116973 See here now...
www.joemillersmoderngarage.com www.starr-cycle.com
***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
smokinsingle is offline   Reply With Quote
Old February 24th, 2013, 07:45 PM   #8
bruce71198
bruce71198's Avatar
Ah the great front fork set up debate. I think you can ask 5 fast guys this question and get 5 completely different answers. I've been doing this long enough to set up my forks quick and easy and be pretty comfortable with the results right out of the box. And not spending a whole bunch of money in doing so. It's not that I won't spend the money on the gold valves or cartridges, it's more a case of what I'm familiar with. The fact is whatever you decide to use you will need to take some time to tune them to your liking, so take your pick.
Old February 24th, 2013, 09:50 PM   #9
Galaxieman
Galaxieman's Avatar
Motorcycle(s): 2008 Ninja 250, 2009 Concours 14
The only 'must have' is springs which are matched to your weight. Exact level of stiffness is somewhat debatable, but for anybody bigger than Danny Pedrosa (which includes most humans), the stockers don't cut it. If you get the preload right with the correct spacer right out of the box, you don't actually need adjusters, but they don't hurt to help give yourself some leeway for 'cheeseburger' events.
That said, valving and oil is an art approaching witchcraft. I don't claim to know any more about it than this: I put 10-weight oil in with my new springs, and it's 'good enough for government work'. I know I've got riding technique improvements to make before the damping being 99% right instead of 90% right will make any difference in lap times.
Igitur qui desiderat pacem, praeparat bellum...
Galaxieman is offline   Reply With Quote
Old February 24th, 2013, 10:12 PM   #10
Galaxieman
Galaxieman's Avatar
Damn double-post... I thought it went into the ether when I got the "page does not exist" warning from the server...
Old February 24th, 2013, 10:26 PM   #11
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
ok, so I am about 180-185 with gear, can someone help me with picking out springs?
TEAM ALFALFA
www.apexassassins.com
Old February 24th, 2013, 11:19 PM   #12
Peanut_EOD
Peanut_EOD's Avatar
Motorcycle(s): Green 2013 ZX-6R
Send them to Tige at CycleMall.
http://www.simplysurrealphotography....es/peanut2.png
Peanut_EOD is offline   Reply With Quote
Old February 25th, 2013, 12:20 PM   #13
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
Go to Racetech and use their spring rate calculator for the bike. That will tell you the springs you need. You can buy them there or go with Sonic Springs for slightly cheaper.
I went with Gold Valve Emulators and like them. Dean (dino74) helped me install them along with doing the mods needed on the damper rod.
It all depends on your budget. Other than springs to match your weight, you can easily get away with just a different fork oil weight or go ballz out as mentioned above.
If you're not mechanically inclined, send to someone who will do it for you. Tige from Cyclemall is a good person to take them to also. (as mentioned above)
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old February 26th, 2013, 08:32 PM   #14
joseg1981
fork suspension set up
well i went with the
.75 springs from sonic]
emulators from racetech
preload adjusters from slingshot
ill starts with this and see how it goes..now im thinking on use 15 w for oil idk yet i wait till the parts get bhere and them i decide im 170 with gear
Old February 27th, 2013, 05:42 AM   #15
bruce71198
bruce71198's Avatar
Have you thought about the rear suspension also?
Old February 27th, 2013, 11:11 AM   #16
joseg1981
Front suspension
Yeah I got a 2 way adjustable rpm shock
Upgraded front suspension, front end tuck Ginganinja 1986 - 2007 Ninja 250R Tech Talk 12 October 30th, 2014 10:27 AM
Front suspension Bigballsofpaint Ninjettes At Speed 58 July 12th, 2014 09:42 AM
Front suspension question gasguzziler 1986 - 2007 Ninja 250R Tech Talk 18 May 7th, 2014 12:05 PM
Front suspension maintenance? kittyslasher 2008 - 2012 Ninja 250R Tech Talk 7 April 9th, 2014 12:41 PM
Front suspension upgrade Rollingmenace 1986 - 2007 Ninja 250R Tech Talk 3 October 4th, 2013 07:42 AM
