May 29th, 2016, 02:25 PM | #1 |
Just sittin on my stool..
Join Date: May 2016 Motorcycle(s): 2012 Ninja 250 Posts: 429
you guys were right (short levers)
Ealier this week I asked advice on adjusting the clutch or switching the lever. You guys told me to switch the lever, so I did. You guys were right!!
So I installed my adjustable short lever on my clutch side and tested it out in the parking lot! MUCH BETTER FEEL. I was about to change my brake lever too, but then it started thundering so I covered my bike back up. The size difference is quite noticeable, fits my hand MUCH better and much easier to pull too! believe it or not my entire hand fits on the lever lol! |
May 29th, 2016, 02:29 PM | #2 | |
The collective wisdom of www.ninjette.org is always as right as helpful. Next step to solid progress: http://faq.ninja250.org/wiki/How_do_...the_shifter%3F
May 29th, 2016, 02:50 PM | #3 | |
WOW! great advice... like always! you guys are amazing! seriously! just a size comparison of my hand and how tiny it really is XD |
May 29th, 2016, 04:52 PM | #4 |
May 29th, 2016, 05:39 PM | #5 |
Just curious, what was this for?
May 29th, 2016, 05:43 PM | #6 |
May 29th, 2016, 05:44 PM | #7 |
Well yes. The reason for this thread
May 29th, 2016, 05:46 PM | #8 |
May 29th, 2016, 05:48 PM | #9 |
May 29th, 2016, 05:52 PM | #10 |
May 29th, 2016, 05:53 PM | #11 |
May 29th, 2016, 05:55 PM | #12 |
May 29th, 2016, 05:57 PM | #13 | |
I might need them; my hands are small as well! |
May 29th, 2016, 05:58 PM | #14 |
sammich maker
MOTM - Apr '15
Short levers are used by many riders.... But in short they are adjustable to give a better feel and fit.
https://www.brocksperformance.com/VZ...0035+C450.aspx |
May 29th, 2016, 07:45 PM | #15 |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
Not all shorty levers are adjustable. In MX they make aftermarket shorty levers ,much like the stock ninjette levers but shorted, so when you pull them in they go all they way to the bar and don't hit your other two fingers. They also don't break when you drop the bike as much.
Because Unregistered sucks at riding. |
May 29th, 2016, 07:52 PM | #16 |
sammich maker
MOTM - Apr '15
^^ better explanation
May 29th, 2016, 09:48 PM | #17 | |
Just plain short - When your riding preference is to brake or clutch with just 2 fingers or your hand is small. Adjustable - The adjustable part is the numbers 1-6 as pictured above. Which setting you choose will move the lever closer or farther away from the bar so the friction zone or braking pressure is more relative to your grip preference. (not all adjustable levers have numbers 1-6, some are just a knob) It's mostly best to stick with the stock length while your just learning to ride as you can use all 4 fingers on the lever (although adjustable may be the prefered to put the lever within easy reach). As skill, confidence and preferences are learned, you can elected to replace the levers with short/adjustable levers. There are also "foldable" levers, that are less prone to breaking when the bike goes down. Popular with track riders/racers. I hope that answers your questions completely, if not.... lemme know.
May 30th, 2016, 03:27 AM | #18 | |
May 30th, 2016, 05:29 AM | #19 |
MOTM - July '15
I have the hands of a great ape and the comfort requirements of a rock. Short levers have always been a strange concept to me. I think I might pick up a pair just to see if I like 'em. I normally do my index and middle finger on the clutch and middle, ring and pinky fingers covering the brake.
May 30th, 2016, 07:28 AM | #20 | |
Many riders have the levers rotated way too far up, which makes you reach upward and puts strain on your wrist. |
May 30th, 2016, 07:38 AM | #21 | |
EX500 full of EX250 parts
Personally, I much prefer the feel of not having all my fingers on the lever. For ~$25 a set, it's pretty cheap and easy to try out other levers. https://www.ninjette.org/forums/showthread.php?t=197412
May 30th, 2016, 07:44 AM | #22 | |
May 30th, 2016, 08:07 AM | #23 |
Huh. I don't know. I'm confused a bit now.
So I keep all my fingers around the clutch, because it's hard to do with only a couple fingers. After riding, even for just a half hour, my left arm (fingers to elbow) kills from working the clutch. Normal or no? You can only imagine how that arm was feeling after a weekend of riding (doing the MSF) |
May 30th, 2016, 08:19 AM | #24 | |
May 30th, 2016, 08:52 AM | #25 | |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
The video shows two clutch lever positions depending on your riding position. You are not a racer so there is no reason to set the controls for a tucked position. You should set (rotate) your clutch & brake levers so that when you are sitting in your usual riding position: you don't have to bend or flex your wrist to extend your fingers from the grip to the lever. Watch though and be aware you don't want to rotate the lever so much that it interferes with your fairing! It's unlikely that will occur but if it does then perhaps get an instructor to check on your position. As well; you may be putting too much weight on your wrists while riding. You will always increase the pressure when stopping or slowing but normally you should be very light on the bars and using your knees and core muscles to hold you upright and not be leaning on the bar. A good exercise is to flap your elbows. We call it "doing the chicken". Its hard to lean on the bar if you're flapping so it's a great reminder to relax and not lean on the bars! Keep in mind: the best athletes are always "loose". They limber up, they shake it loose and they concentrate on relaxed breathing. It's a lot harder to knock someone off balance if they are relaxed and flexible, easy if they are tense. Motorcycling is like that too; the bike knows what to do. You want to be relaxed and not fight it! If the bike isn't doing what you want it to do then you are either fighting it (generally; too tense) or there may be a geometry (suspension and/or chassis) reason that can be adjusted but at a newer rider level; it's usually rider input errors that are causing the problem(s) including such things as discomfort. Relax, look where you want to go and ride at a pace and in a situation that you are comfortable riding in: ride your own ride. Note: I like two fingers on both my clutch and brake. They're always on the levers. Your MfS course teaches to keep your fingers on the grip. The racing God #49; Valintino Rossi keeps his fingers on his grips and uses all 4 fingers when clutching and braking. You're in good company if you keep fingers on the grip. But it's important to set the levers so you easily reach them when needed!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
May 30th, 2016, 10:11 AM | #26 |
I thought my hands were hurting from pulling in & letting go of the clutch.
Is that normal that it would be sore from that? |
May 30th, 2016, 10:39 AM | #27 |
Certified looney toon
MOTM Jul '13, Jul '14
No, it shouldn't be that sore from doing clutch work.
You might need to build up grip stretch (there are great little squishy things that rock climbers use) or you might need to adjust your lever so it's easier for you to pull. If you are stretching out your fingers to reach the clutch, then it could cause strain on your hand. An adjustable lever (long or short) will bring the lever closer so it's less of a reach for you. I have short adjustable levers on both of my bikes because I prefer using two fingers and have a short reach (stubby little fingers). A note about hand pain; If you are doing the "chicken wing" thing (keeps your arms from locking) and can wiggle your fingers around (keeps you from having a death grip on the bar) but are still experiencing pain, you might be using your palm to support all of your upper body weight. My hands would go numb easily after a short ride and be painful for hours after a long ride before I figured that out. The best advice is to do some core strengthening exercises (provided kindly by @Whiskey here) or what I found best for me was this advice: I put my bike up on the rear stand and did this, figuring out how my body sat with no hands to support itself and then just rested my hands on the bars. Helped me immensely!
May 30th, 2016, 10:47 AM | #28 | |
I'm sure if I rode more, it'd be better since I'm working the muscles more. I don't ride everyday. And I don't think I'm putting my weight on the handlebars, considering the Rebel had me sitting straight up so there'd be no reason to lean on the handlebars, right? |
May 30th, 2016, 11:11 AM | #29 |
With the Rebel, you can't lean on the bars, just due to the layout. When you switch to a sportbike, your body is inherently leaning toward the bars (though the little Ninjas aren't as bent over as bigger sportbikes). It's easy to treat it like you're doing a pushup, and support your body weight with your arms. You should be squeezing the tank with your legs and using your core muscles to support your torso. You shouldn't have to shift your weight at all to move your hand off the bar.
May 30th, 2016, 01:25 PM | #30 | |
I've also seen guys do pointer and ring on the lever and middle and pinky on the bars, none of my friends do that, but I've seen it. I've also seen custom clutch levers for this finger position that can pull the lever to the grip. I've yet to hear about middle, ring, and pinky being used on the lever, and I've never seen anybody have separate grips, except when they had pointer, middle, and ring on the clutch, and pointer, middle on the brake.
May 30th, 2016, 01:31 PM | #31 | |
The length if the point you are pulling from to the pivot point is directly related to the force needed to pull. With longer levers you have more freedom of where you can place the pivot point, and therefore, you can change your leverage ratio. However, with my grip and handlebar setup most of the time I can move the master cylinder as far away from the grip as it will go and still have extra lever on shorty levers. This is due to me preferring a very narrow grip and only using my first two fingers on the levers. Also, most bar bends/ clipons that I have bought have had very limited master cylinder placement.
May 30th, 2016, 01:35 PM | #32 | |
When riding a small CC MX bike the clutch work would roast my forearms. However, I've never had a problem on a street bike or my 250, because you don't need to work the clutch (nearly as much). I used to do forearm exercises just for armpump. Now with my current bike selection, if I get armpump I have something ill adjusted, or I'm gripping the bike wrong.
May 30th, 2016, 01:44 PM | #33 | |
n00bie to wannabie
MOTM - Nov '15
May 30th, 2016, 01:47 PM | #34 |
You can slide the master cylinder/ clutch perch left or right on the clipon / bar on the ninjette to change the leverage. This is pretty much the only way to change the leverage of a lever.
May 30th, 2016, 01:58 PM | #35 | |
n00bie to wannabie
MOTM - Nov '15
Anyhoo...all else being equal: someone that uses all four fingers on a stock lever has more leverage therefore more force than someone using either 2 or 4fingers on a shorty lever. This is all semantics in relation to InvisiBills comments.
May 30th, 2016, 02:10 PM | #36 | |
May 30th, 2016, 02:34 PM | #37 | |
n00bie to wannabie
MOTM - Nov '15
SLOWn60....Out!
May 30th, 2016, 02:44 PM | #38 | |
MOTM - July '15
As for the right hand, I use three fingers because I found that, while practicing emergency stops, it was more effective to use three fingers, and just the index finger and thumb are easily enough for throttle control on most roads. If I'm in a situation where throttle control is a higher priority, then I'll keep my whole hand on the throttle. I'm pretty sure I'm not the only one to ride with an "Okay" with their right hand, though. |
May 30th, 2016, 03:23 PM | #39 |
n00bie to wannabie
MOTM - Nov '15
No less than Valantino Rossi
May 30th, 2016, 03:46 PM | #40 |
Eh it was probably a one time thing then. I was working the clutch a lot because we had to change gears a lot and practice going slow and whatnot.
And like someone said, it's pretty hard to lean on the handlebars on the rebel because of how you're sitting so I know I'm not doing that. I just have to work out more that's probably it. |
Jackets for short skinny guys? | rawbert625 | Motorcycle Gear | 10 | August 24th, 2012 10:52 AM |
Where do you short guys get your gear? | AgentCircus | Motorcycle Gear | 9 | July 22nd, 2010 02:37 PM |
[SoupKast] - SoupKast by Honda Episode 82: Laguna USGP: Fast Guys, Short Guys and Idi | Ninjette Newsbot | Motorcycling News | 0 | July 15th, 2009 11:00 PM |
[SoupKast] - SoupKast by Honda Episode 82: Laguna USGP: Fast Guys, Short Guys and Idi | Ninjette Newsbot | Motorcycling News | 0 | July 14th, 2009 10:40 PM |
