Old October 18th, 2012, 05:54 PM   #81
codestp202
Guest
Posts: n/a
I will be submitting said video to the police. I'll for sure have my gopro attached to me when we go.
Old October 18th, 2012, 06:08 PM   #82
Oh, no worries, that footage is "over a year old"
oh, i WILL have a camera by then, and it WILL be a GoPro because they're awesome with tons of mounting options. I also found a suit that should fit me right, and is in a good price range, thanks to alex.s. I just need to bite the bullet and spend the money on the suit + back protector. I'm still checking ebay religiously though, just in case
Old October 18th, 2012, 06:15 PM   #83
codestp202
Guest
Posts: n/a
The new hero 3 just came out, so hopefully it will drive the prices down on all the other cameras. Wait, what does that mean if its over a year old?
Old October 18th, 2012, 06:24 PM   #84
Statute of limitations for stuff like this is a year. I think. Whatever, not worried about it.
Old October 18th, 2012, 06:33 PM   #85
codestp202
Guest
Posts: n/a
Oh Gotcha!
Old October 19th, 2012, 07:08 AM   #86
codestp202
Guest
Posts: n/a
My full suit comes today! Pics will ensue!
Old October 19th, 2012, 07:30 AM   #87
nycsteve
Biker
nycsteve's Avatar
Motorcycle(s): 2010 Ninja 250 SE
Can I Join? I'm planning some long ass trips for next year and think it would be cool to ride to Ohio for a track day/weekend!
S*** Happens!
Design Stuff | Tumblr
James 1:2-4
nycsteve is offline   Reply With Quote
Old October 19th, 2012, 07:41 AM   #88
codestp202
Guest
Posts: n/a
Sure man, the more people the better! We can have a crazy ninjette.org track day!
Old October 19th, 2012, 07:53 AM   #89
Let's bust out of this thread.
http://www.ninjette.org/forums/showthread.php?t=117290
Old August 28th, 2013, 01:21 PM   #90
BRad704
Big Dreams, Small Wallet
BRad704's Avatar
Motorcycle(s): 08 Ninja 250R (Sold), 93 VFR750F (In Pieces)
Well that was a fun read...
I was trying to find a good list of stuff that has to be safety wired, and ended up reading 3 pages of man-snugglin'. But dang if I couldn't stop reading!
~BRad
BRad704 is offline   Reply With Quote
Old August 29th, 2013, 11:01 AM   #91
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
This guy was hauling at nyst over wheelie hill.
Old August 29th, 2013, 02:48 PM   #92
lol Did you find your list? If not, check here.
Old August 30th, 2013, 09:10 AM   #93
BRad704
BRad704's Avatar
I started through that thread the other day, but it wasn't what I was looking for. Turned into a huge convo about geometry specs.
I know I had a list saved somewhere that had bullet points for everything. ie, Safety wire on - this bolt, this bolt, this bolt... Radiator flush for water wetter... etc
~BRad
Old August 30th, 2013, 09:30 AM   #94
Well lemme see if can remember everything, but not all are required depending on trackday/race org.
Da Saftety Wire List
Oil (The big 3 for most track day orgs in the higher level groups)
Oil Fill
Oil Drain
Oil Filter
Brakes
Front and rear brake banjo bolts
Caliper mount bolts
Brake pad alignment and slide bolts
Pads within spec
Levers function properly
Throttle
Snaps back to closed
Grips are securely glued or safety wired
Coolant
Coolant flush bolt
Coolant fill cap
Flush/Fill with water wetter
Wheels/Tires
Front and rear axle castle nuts (pinch bolts)
Rear axle adjusters
Tape over wheel weights
80% or better tread (YMMV some orgs are very lenient)
Exhaust
Exhaust hanger bolts
Exhaust springs
Switches
Functional kill switch
Not required but highly recommended;
Chain master link - clip style
Front sprocket nut
I am sure I am forgetting something.
Last futzed with by csmith12; August 30th, 2013 at 11:54 AM. Reason: spelling and forgot item
Old August 30th, 2013, 09:35 AM   #95
BRad704
BRad704's Avatar
Thank you thank you!
~BRad
Old August 30th, 2013, 09:36 AM   #96
If your racing, they will most likely tech your helmet as well. 5yr born on date, any older and you fail!
Old August 30th, 2013, 09:41 AM   #97
Also....
Nothing says "I wanna fail tech" better than going through with a dirty bike and/or rusty a** chain. Keep her clean.
Old August 30th, 2013, 09:42 AM   #98
BRad704
BRad704's Avatar
March 2012 there.
~BRad
Old August 30th, 2013, 11:28 AM   #99
Also....
Or a tight chain? Lol, guilty of both. Mine was pretty grotey last time.
Old August 30th, 2013, 11:53 AM   #100
holy **** that ****er got air over the wheelie bump.
Also....
lol. i should record my tech inspections sometime. you would laugh.
Old August 30th, 2013, 06:30 PM   #101
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
Turn on that GoPro! That'd be funny as **** to hear that conversation...your bike making it through tech!
Postwhores are COOL! ~Allyson
Old August 30th, 2013, 06:34 PM   #102
Dew et! Not only for the fun factor but to show others how easy it really is.
Wreck to rider Nick nova/ninja/boni Pictures 53 May 28th, 2014 08:12 AM
Wreck a ninja get a R6 KylerT General Motorcycling Discussion 29 January 29th, 2013 04:18 PM
Almost wreck nickjpass Videos 19 October 20th, 2011 10:13 AM
Escaped a wreck yesterday FerociousNINJA Riding Skills 18 June 6th, 2010 08:31 PM
car wreck- sister. zartan Off-Topic 25 December 18th, 2009 12:03 AM
