July 11th, 2013, 10:32 AM | #1 |
Join Date: Jun 2012 Motorcycle(s): 2012 Green 250 Posts: 58
GoPro Hero
Found one on Craigslist today that I can buy for 50 dollars. Is it worth it or should I pay 150 more for a 3?
http://indianapolis.craigslist.org/ele/3926841835.html |
July 11th, 2013, 10:44 AM | #2 |
If it's the first gen hero, skip it.
July 11th, 2013, 10:46 AM | #3 |
Yes it is the first one. Have you tried it? Were there known problems with them?
July 11th, 2013, 10:48 AM | #4 |
No problems really, just it's not gunna be the quality you really want. I have one and compared to the HD stuff, it's not up to par. But it will take a fair video non the less.
July 11th, 2013, 10:55 AM | #5 |
Ok thanks. I think I will pass and try and get a 2 or 3.
July 11th, 2013, 11:10 AM | #6 |
the 2 is all around better, but night time recording was its true advantage.
July 11th, 2013, 10:29 PM | #7 |
Join Date: Jun 2013 Motorcycle(s): N650 (and others) Posts: 408
The 3 has terrible reviews on Amazon, but my friend has one and says the latest firmware seems to work pretty well except for one detail -- don't poke at it for a few seconds after powering it on, else it'll probably freeze / lock-up.
July 11th, 2013, 11:22 PM | #8 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
I have a 3 black with no issues. Just gotta get the firmware in there.
Note: a 3 Silver is basically the same as a 2. So always get a 2 used over a 3 silver if you can.
CVMA #531 |
July 11th, 2013, 11:34 PM | #9 | |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
jerky playback, sometimes not recording I deduced it to be that the hero 3 you need to use 32GB cards. The 64GB cards give it issues. Im going to be trying a couple Replay XDs to see if they are more reliable. My GoPro HD1 and GoPro HD2 are much more reliable than my GoPro Hero 3 black. Pretty annoyed with my Hero 3 right now
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
July 11th, 2013, 11:56 PM | #10 |
Did you properly install the firmware? You have to manually download and place it on the SD card in their own files.
CVMA #531 |
July 12th, 2013, 12:02 PM | #11 | |
Im pretty sure the issue is the memory cards. They don't like 64GB. What size memory card are you using Max and what formats are you recording at?
July 12th, 2013, 01:06 PM | #12 |
I have a 32GB recording at 1080/60
CVMA #531 |
July 12th, 2013, 01:33 PM | #13 |
Jigglin' your Jiglets
MOTM - Apr '13
Do you like my videos? Most are filmed with my hero 1s. When uploading to youtube the difference between them is negligible. The hardcore fail of the 1 is dark shots. If no dark shots then $50 is a damn fine deal
July 12th, 2013, 03:02 PM | #14 |
Join Date: May 2013 Motorcycle(s): 10 Ninja 250 Posts: 172
im buying one this weekend or next weekend as well. You can get them on CL with a bunch of mounting stuff (Gopro 2) for about $150-$200.
Ive done my research and unless you want the 3 really bad, its go big or go home. Meaning get the black edition. The Silver and White edition are basically like the 2 except improved under water picture. As well as built in wifi. And smaller and cooler. |
GoPro Hero 3 deals? | Reyno2ac | Off-Topic | 4 | March 9th, 2013 08:19 PM |
GoPro Hero 1 Motorsport - Used | EMSRacer07 | Miscellaneous | 6 | November 17th, 2012 01:29 AM |
GoPro Hero 2 Warning | Scattcatt | Off-Topic | 4 | November 6th, 2012 08:02 PM |
GoPro Hero 3... | Byakkotai | General Motorcycling Discussion | 35 | October 25th, 2012 09:15 AM |
So, I just picked up a GoPro Hero HD.... | Soujyu | Videos | 13 | March 26th, 2011 01:31 PM |
