Old December 6th, 2022, 06:57 AM   #1
Shafer
Carburetor vacuum hoses
I'm in the process of changing my vacuum hoses on my carburetor.
I know fuel does not flow through the vacuum hoses but they smell like gas...
Do I need to find replacement hoses that are fuel rated?
Auto parts store sells windshield washer/ vacuum multi function hoses, can I use those or should I get a true vacuum hose because of hose collapse under vacuum?
If I don't need fuel rated hose what material should I get, I've seen polyurethane, silicone, and rubber available? Or will all of those work, just my preference?
Thanks for your help!
Old December 6th, 2022, 08:50 AM   #2
@ducatiman will have your answer, but in general I use the same type of hose for vacuum lines that I use for fuel lines, in the right size, of course.
I've been using Tygon® F-4040-A tubing. I got it here, but there are many suppliers: https://www.mcmaster.com/tygon-f-404...nd-lubricants/
Old December 6th, 2022, 01:33 PM   #3
a note exists in their description..... do not use with ethanol-based gasoline.
However, for vacuum applications, would likely be fine, as would auto parts vac line. Though correct sizing is important, not too loose, not too tight, in any appllcation.
Old December 6th, 2022, 01:53 PM   #4
That's strange that McMaster-Carr made that warning. Saint-Gobain makes it, and they don't have that warning on their site. The actually say that it's for "general automotive use", among other applications. I've been using it with pump gasoline (E10) for several years now, with no odd things happening.
I wonder what they mean by "ethanol based gasoline", since gasoline with 10% ethanol isn't ethanol based, it's gasoline based with some ethanol added. I wonder it they're referring to E85, which would qualify as ethanol based.
allseasonsparts.com sells it, and they say "Ethanol: Compatible with greater than 10% ethanol fuel".
This summary of Tygon products doesn't have the warning eithe: https://docs.rs-online.com/7820/0900766b81656fcc.pdf
I think I'll continue to use it as I have been and not worry about E10 compatibility.
Old December 6th, 2022, 02:18 PM   #5
I emailed Saint Gobain. I'll post if/when they answer me.
Old December 6th, 2022, 04:26 PM   #6
Shafer
Thanks for the replies and interest so far!
So what I think I'm hearing is yes the 3/32 and 5/32 carburetor vacuum hoses need to be rated for gas.
Old December 6th, 2022, 04:34 PM   #7
Shafer
Any product recommendations for the 3/32 a 5/32 hose that works well with the perfect fit?
Old December 8th, 2022, 08:25 AM   #8
I got the answer below from an engineer at Saint Gobain. In my experience, it will last for at least several years.
If you don't mind opaque black like the stock tubing, Viton might last longer. McMaster-Carr has Viton tubing in a variety of sizes: https://www.mcmaster.com/tubing/plas...e-name~viton-/
Jim,
Tygon F-4040-A is compatible with pump gasoline that contains ethanol. Although it is compatible, because it is a plasticized formulation you may eventually notice the tube get stiffer as the plasticizer extracts which could eventually lead to cracking. It is impossible to estimate how long that would be as it depends on the application and environment how long it would last before needing to be replaced.
Any other questions let me know.
Regards,
Zach Garnsey | Applications Engineer
Fluid Transfer, Saint-Gobain Life Sciences
330-283-7662 | Zachary.Garnsey@saint-gobain.com
2664 Gilchrist Rd. | Akron, Ohio 44305 | USA
Old December 8th, 2022, 10:20 AM   #9
^ fair enough, TJ
Old December 8th, 2022, 02:06 PM   #10
Shafer
Thanks guys I really appreciate the help!
Carburetor hoses problem Abeast_9 2008 - 2012 Ninja 250R Tech Talk 12 June 7th, 2021 01:10 PM
Help with new bike - vacuum hoses eric78 1986 - 2007 Ninja 250R Tech Talk 1 May 7th, 2014 09:16 PM
Where do these vacuum hoses go? blackss06 2008 - 2012 Ninja 250R Tech Talk 2 April 11th, 2014 03:42 AM
TIP: How to keep track of loose vacuum hoses and wires during a DIY. Army Aviator 2008 - 2012 Ninja 250R Tech Talk 8 March 31st, 2012 08:08 PM
Need help with vacuum hoses Jordan91 2008 - 2012 Ninja 250R Tech Talk 1 December 25th, 2010 09:57 PM
