April 1st, 2014, 11:13 AM | #1 |
dirty boy
MOTM - Apr '14
blinker issue
So few weeks ago I installed undertail with integrated LEDs.
Wired everything up, bought a new blinker, l552a I think? As per a DIY. Everything worked great on multiple occasions when testing everything. Today was first time I got to ride bike since last November, road to work this morning and everything seemed great. Took a quick spin at lunch time and about 10 minutes in, I noticed my dash signal indicator wasn't lighting up and I could not hear other signals/blinker working or see them working either. I thought, blinker came unplugged/loose. Pulled over, took seat off and blinker is fine, but not working. (managed to break stupid screw driver in the bikes tool bag) Figured I will look at it closer when I get home, that's the plan. After that it would work on occasion but generally only blink once or twice then quite entirely again? When I parked the bike it worked again for a little then quit again? Any ideas, I will go through all the electrical under the seat ect... to see if I can find anything goofy
April 1st, 2014, 01:07 PM | #2 |
dirty boy
MOTM - Apr '14
just gonna order a blinker designed specifically for LEDs, should solve the problem.
April 1st, 2014, 01:11 PM | #3 |
Certified looney toon
MOTM Jul '13, Jul '14
Tridon EP 34 is the one that's been found to work on our bikes. It has three prongs so one needs to be grounded. But i had issues with the EL 12* when I converted my front blinkers to LEDs. The EP 34 has a nice steady blink.
Watch out for off brand ones, the Napa one had problems. *edit: fixed from saying the wrong relay.
<-- Linky Hey Unregistered! The code [you] shows the username currently logged in. IBA # 56020 AMA # 521481 Fun Rides! ][ My Videos ][ My Gear Hold yourself to the same rules you expect others to follow. Last futzed with by NevadaWolf; April 7th, 2014 at 09:12 AM. |
April 1st, 2014, 01:19 PM | #4 |
dirty boy
MOTM - Apr '14
thanks for the input
April 1st, 2014, 05:35 PM | #5 |
Did you swap out the blinker fluid??
Everyone forgets that part... |
April 1st, 2014, 07:04 PM | #6 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
loose/worn connections? near handle bars maybe?
April 7th, 2014, 09:08 AM | #7 | |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
April 7th, 2014, 09:11 AM | #8 | |
April 8th, 2014, 10:38 AM | #9 |
dirty boy
MOTM - Apr '14
bought an LED specific blinker relay of e-bay and all seems well. No issues to work this morning.
blinker issue | ninjafanatic86 | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 12th, 2015 10:19 AM |
Installing cyclegear led front blinker issue | CycleCam303 | 2008 - 2012 Ninja 250R Farkles | 3 | March 9th, 2013 06:37 PM |
I need help right now (blinker issue) | ninja_sleeper | 2008 - 2012 Ninja 250R Farkles | 14 | August 29th, 2011 11:56 AM |
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2010 07:50 AM |
Have a lean issue with my bike, issue with coasting enricher. | twiggy2cents | 1986 - 2007 Ninja 250R Tech Talk | 7 | February 24th, 2010 06:54 PM |
