December 3rd, 2013, 06:18 PM | #1 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
My local dealer keeps nagging me to buy motorcycle specific oil, why?
I want to know if there actually is a reason behind this??? I just switch to Rotella T6 and needed a filter but they are the only motorcycle shop for like 30 miles. When I picked up the filter I think he was pressing me to buy motorcycle oil from them, or are some bikes finnicky when it comes to oil?
December 3rd, 2013, 06:21 PM | #2 | |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
I wouldn't put no plain Jane auto oil in it... Plenty of posts around on why not to do that. Plenty of posts and evidence that T6 works proper in our bikes cheaper than that other stuff
December 3rd, 2013, 08:09 PM | #3 |
So, where's the reverse?
It's his job to sell you stuff you don't really need and Christmas is around the corner. Everyone likes a fat bonus cheque.
December 3rd, 2013, 08:38 PM | #4 |
Rode with the Dinosaurs..
Join Date: Nov 2013 Motorcycle(s): '08 Ninja 250 Posts: 486
It's his job to ask you to buy things that you don't really need.
December 3rd, 2013, 10:33 PM | #5 |
I have run every kind of oil, and running expensive stuff sure does make you feel faster. It's like stickers and paint. It's faster in your head.
December 3rd, 2013, 10:48 PM | #6 |
It's faster through your wallet as well
December 3rd, 2013, 11:38 PM | #7 |
Of course he wants to sell you expensive oil... it's his job. T6 works fine
December 4th, 2013, 01:50 AM | #8 |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
Awesome thread....didn't realize T6 was a cheap alternative (actually, I never gave it much thought TBH). I shall be switching to that as well
"even a proper fitting helmet can 'get loose'" -csmith |
December 4th, 2013, 05:39 AM | #9 |
old git
Join Date: Mar 2009 Motorcycle(s): BMW K1300S Posts: 479
As long as the oil is for 4 stroke motorcycles it's OK , oil for cars has additives that are not compatible with a wet clutch and may cause problems.
Steve
Some mistakes are too much fun to make only once. |
December 4th, 2013, 05:53 AM | #10 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
What want to buy an oil filter and no oil? What you expect to run on hopes and dreams lol.
December 4th, 2013, 06:04 AM | #11 | |
DO NOT use any oil that has "Energy Conserving" printed on the API label: Stuff in the blue box above? No. The reason is that the friction-reducing additives that make it energy conserving will cause your clutch to slip. Cars don't have wet clutches... bikes do (except Ducatis). DO use oil that meets the required rating (I believe for the Ninjette it's SE or SF, or higher). DO use oil of the correct viscosity for the temperatures you'll face (i.e. don't use 20W-50 in the dead of winter... it's too thick). Aside from that, you'll be fine.
December 4th, 2013, 09:56 PM | #12 |
Join Date: Apr 2013 Motorcycle(s): 2013 600RR, 2009 250r Posts: 130
Not sure if you mean that he is trying to sell you his motorcycle oil or just saying that you need motorcycle specific oil.
If he is trying to sell you his oil, then yes, he is doing his job and chances are that it will be very close in price to anywhere else you would get motorcycle oil. If he is saying that you need motorcycle specific oil and not any type of auto oil then he is absolutely correct. You have a wet clutch that a car doesn't have. I guess that auto oil would be better than nothing, but they do make motorcycle oil for a reason. |
December 4th, 2013, 10:16 PM | #13 |
Motorcycle Nurse?
So which is better for the engine? Lots of people swear by the shell rotella t6 synthetic so I switched to it. Is that okay? That's turbo diesel oil
December 4th, 2013, 10:32 PM | #14 |
Which is better? Well that is the great debate and always will be.
You will be fine, many of us have logged hundreds of thousands of miles on t6 synthetic with many of those being track/race miles. Don't loose any sleep over it.
December 5th, 2013, 06:38 AM | #15 |
Pro Tip (frugal): Save a few empty quart bottles. When you change your oil, save a quart of the spent t6. Why? For lawn mowers, chain saw bar oil, ect... ect... I haven't bought oil for my Cub Cadet in years.
December 5th, 2013, 09:26 AM | #16 |
MOTM - Mar '13, Jun '14
That's Harley oil.
December 5th, 2013, 12:35 PM | #17 | |
IMHO, people go WAAAAY overboard with oil debates. In a very high output, very close tolerance engine that is pushed to the brink of destruction (e.g. an F1 engine), then it probably makes a real difference. If you're banging off the rev limiter all day long under race conditions, then it MIGHT make a real difference. In your bike, that you're probably going to get rid of before you've clocked all of 15,000 miles and which isn't exactly the most sophisticated machine on the planet... let's be honest. It really, REALLY does not matter. Have you EVER heard of ANYONE having an engine issue related to the oil they've used? EVER? Change your oil from time to time. Use the right weight and the right spec from a known and trusted company and use your energy worrying about something important instead. T6 is fine. Cheap, too.
December 5th, 2013, 02:14 PM | #18 |
Don't sweat it. T6 is JASO MA compliant. Perhaps to your dealership, it's not motorcycle specific oil since it's not in a rebranded bottle with a 25% mark up because it has a picture of a motorcycle on the front label.
December 5th, 2013, 05:09 PM | #19 |
certain non-motorcycle oils (the ones marketed towards 'high efficiency' crap and that promise better milage per gallon) have friction modifiers that **** with the clutch and make it slip too bad. so your implication that theres nothing different is crap. it just happens that some non-motorcycle specific oils don't have that **** in it and its fine.
December 5th, 2013, 05:42 PM | #20 | |
I'd bet that if Shell used the exact same T6 formula and jug but instead used different labeling that called it a motorcycle oil that the dealer wouldn't be telling the OP to use anything different. |
December 5th, 2013, 10:06 PM | #21 |
Before this turns into an oil argument thread... I think we can we all agree that dealer oils are overpriced and that t6 is fine for the /average/ motorcyclist.
[motorcycle.com] - Petition To End Motorcycle-Specific Checkpoints | Ninjette Newsbot | Motorcycling News | 0 | May 13th, 2014 10:30 AM |
[roadracingworld.com] - Local Dealer Supporting One AMA Pro XR1200 Team At Barber Mot | Ninjette Newsbot | Motorcycling News | 0 | June 17th, 2011 12:40 PM |
So there's this little voice nagging at me... | wtfh4xx | General Motorcycling Discussion | 28 | June 14th, 2011 12:55 PM |
$140 Oil Change Avoid this dealer in NYC. | keeyu | 2008 - 2012 Ninja 250R Tech Talk | 34 | October 6th, 2010 08:46 PM |
[roadracingworld.com] - Lucas Oil Founders Buy Historic Mansion In Indiana | Ninjette Newsbot | Motorcycling News | 0 | October 6th, 2010 03:50 PM |
