August 26th, 2011, 11:55 AM | #1 |
Join Date: Sep 2010 Motorcycle(s): 2001 Kawasaki Ninja 250R Posts: 271
Motorcycle lift
Do you guys think this lift http://www.harborfreight.com/automot...lift-2792.html, is worth it, to do some basic maintanence on our bikes, like at least an oil change?
August 26th, 2011, 12:02 PM | #2 |
No, those are more for cruiser/tourers than for sportbikes. The 250 doesn't really have anything on the bottom as a brace so you have to support point to lift it up from. A rear stand is a better investment if you want convenience.
August 26th, 2011, 12:12 PM | #3 |
you won't even need a rear stand. Pregens have a centerstand installed on the bike that does just fine for most maintenance. if you NEED to get the front off the ground, put it on the center stand and then jack the front up with a car jack and a block of wood under the engine block, just be careful, as this is not the most stable method and it tips easily.
http://faq.ninja250.org/wiki/Support...hile_Servicing |
August 26th, 2011, 12:14 PM | #4 |
Haha great point. Didn't realize what sub-forum I was in.
August 26th, 2011, 12:35 PM | #5 |
no worries welcome pregenvillle
August 26th, 2011, 12:43 PM | #6 |
can't you put it on the center stand and simply put weight on the rear to get the front off the ground?
August 26th, 2011, 12:54 PM | #7 |
Thanks Guys, you saved me a hundred bucks.
August 26th, 2011, 12:56 PM | #8 |
yeah you can. it doesn't take much weight. I just usually lift the front with a jack because then I can have 4 points of contact with the ground. the back wheel, both sides of the center stand, and the jack. plus then there's no worry about the weights slipping off and the front suddenly falling (which would have been an issue last winter when I took off my forks to redo the seals for example)
August 26th, 2011, 12:57 PM | #9 |
glad to help!
http://faq.ninja250.org/wiki/I_am_ha...ts_centerstand this will explain how to use the stand better than I can |
August 26th, 2011, 01:45 PM | #10 |
Join Date: Jul 2011 Motorcycle(s): 2003 Yamaha R6 Posts: 113
August 26th, 2011, 02:02 PM | #11 |
Join Date: Dec 2008 Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick" Posts: A lot.
A method that I've used to get the front end off the ground is a strap to the roof joists in the garage. Since you're only applying enough force to get the bike to pivot on the center-stand, it's fairly easy to do.
< ATGATT > Sweat you can wipe off, Road rash you can't. HEY!! Unregistered!! Does your bike have a name? |
Motorcycle Lift DIY | indnracn2 | General Motorcycling Discussion | 6 | May 13th, 2014 09:48 PM |
using a motorcycle lift on the 250 | stryder | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 20th, 2010 09:00 AM |
