February 8th, 2014, 04:32 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): '13 Ninja 300, '99 SV650 tracked Posts: 378
Gopro Mounting Placement and Mounts
I'm done smacking my helmet on my tank-mounted gopro. I usually only do front-facing, since there's rarely action behind me What and where? I'm considering the dude that sells the mirror-mount ones on WERA, anyone tried those? sticky-mount in the same place almost as good?
Discuss. .. (and yeah, I searched, thinking this had already been flogged, but not much. . . ) |
February 8th, 2014, 09:51 PM | #2 |
Ummmm... hahahahaha Seriously, I just did the sticky mount you describe today at the track. I will let you know how it holds up for you.
February 8th, 2014, 10:33 PM | #3 |
Butt cam. Flat mount on the tail, camera pointing forward. Never gets in the way and you get to watch yourself like a pro.
February 8th, 2014, 11:58 PM | #4 |
"scandal!"
February 9th, 2014, 12:10 AM | #5 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
February 9th, 2014, 07:07 AM | #6 |
You don't zoom in and look at just your butt. Silly! the camera will see all of you from there. It's a great way to see your BP and see exactly where you hit (or miss) apex.
February 10th, 2014, 02:18 PM | #7 |
Fogle mounted a GoPro on the upper fairing of my bike Joel. Worked pretty good. It's just to the left of the windscreen and safety wired to my stay. Gave pretty good footage. If you wanted to get crazy you can always buy some mounts from the company "Ram Mount". They have a ton of cool setups that would mount to forks, clip-ons, frame, etc.
http://www.rammount.com |
February 10th, 2014, 02:38 PM | #8 | |
CVMA/AFM #72
Join Date: Oct 2009 Motorcycle(s): 2009 Ninja 250r (Racebike), 2015 FZ-07(Tourer), 2001 KX65(LOL bike) Posts: A lot.
Has anyone found a good point on the bike to mount a camera for a view of their forks? (Like in this video: http://www.ninjette.org/forums/showthread.php?t=164796) I've seen this view point used with a lot of the big bike racers, and it's probably one of my favorites. Not sure if there's room anywhere on the ninja though :/ |
February 10th, 2014, 03:51 PM | #9 |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
I have my GoPro mounted on my triple. however part of my triple was cut too where the key ignition was.
I also mount my other camera, a Replay XD under my tail section facing backwards...works great showing riders behind you. Other places I mounted a Go pro was on my swing arm get get footage of my rearset, foot, and when I dragged knee...however I think where I am at now I may lean it far enough and drag the camera. I may retry using a Replay XD on this position because it has a much smaller form factor. I also mounted a Go Pro mount exactly where Josh and Shane did but I also want to see my RPMs.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
February 10th, 2014, 04:57 PM | #10 |
Join Date: Oct 2012 Motorcycle(s): '04 R1 and '08 Ninja 250 Posts: 222
Knock on wood, we have not had a failure of the mounts yet...
We have one on the windscreen mounted right below the Kawasaki sticker. One mount right in front of the right clip-on on the outside of the fairing so the go-pro can face back looking at the brake lever/throttle hand movement. The obligatory butt view that can also face backwards. One on each side of the mid-faring area to get a view of the front wheel or inside of leg when facing the camera to the back. The coolest one we have though was Draik's idea... it is on the left side passenger peg mounting point. This one we ran safety wire through to make sure it held on. It gives an awesome view of the rear tire/suspension travel/traffic behind him on the track.
Check out this Ninja 250 roadracing youth---> TheDraik77 <--- My son |
Mounting gopro on gas tank. | LT505 | General Motorcycling Discussion | 30 | June 25th, 2013 11:15 AM |
Mirror placement and your preferences | CThunder-blue | General Motorcycling Discussion | 18 | November 11th, 2012 07:29 PM |
Favorite GoPro mounting positions | wayanlam | Videos | 52 | October 15th, 2012 11:45 AM |
Finally found a mounting position from my GoPro that I like | robmilchling | Videos | 11 | April 11th, 2012 08:12 PM |
Base sticker placement? | Underkill | General Motorcycling Discussion | 10 | January 29th, 2010 11:31 PM |
