May 9th, 2014, 12:28 PM | #1 |
Join Date: Apr 2014 Motorcycle(s): '08 Ninja 250 Posts: 132
Should I grease forks before putting them on?
So it was a major pain in the ass getting the forks off. Should I grease the new ones to make them slide in easier?
May 9th, 2014, 12:35 PM | #2 |
Blind 250 Loving Whore
May 9th, 2014, 12:36 PM | #3 |
Lube always makes things easier, just clean up after yourself when your done.
.... i'm serious....
May 9th, 2014, 12:37 PM | #4 |
I'm putting new one's on.don't have any sand paper.
So it would be okay to grease the fork tubes? Or just inside of the triple where they slide through? |
May 9th, 2014, 12:40 PM | #5 |
I just don't see why you'd need to with brand new tubes. They should go in fine. Might have to turn them back and forth a little to get up in there.
May 9th, 2014, 12:41 PM | #6 |
why would you want your forks to slide around in the triples?
why are you taking your forks out often? if they are tight to get out, use a flat head and pry the clamps apart a little bit.
May 9th, 2014, 12:44 PM | #7 |
The old forks were bent. So I'm replacing them. I didn't know if grease would help or just cause a major headache
May 9th, 2014, 12:44 PM | #8 |
I've never had too much of a problem. I wouldn't want lube there.
May 9th, 2014, 12:55 PM | #9 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
if the old forks were bent, the clamps may be misaligned
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
May 9th, 2014, 03:12 PM | #10 |
Update: The new forks are on the bike, everything looks good. Bike fell off the front stand, luckily I had helping me out, so all was good. Ended up prying open the clamps with a flat head screwdriver. It was way easier and I'm just a wimp...
Thanks for all the replies! |
May 10th, 2014, 07:22 AM | #11 |
Join Date: Nov 2011 Motorcycle(s): Many Two Wheels .. Posts: 611
No dont grease or oil ... Just clean the inner surface thorughly with contact cleaner or alcohol.
Loosen the triples and then slide the forks in, measure desired height, tighten fork pinch bolts and at the end tighten triple head bolt. Mine is a fight to get in and i do it this way.
[ex-AFM #828 | SMUSA #828 | Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers + OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com |
Where to get Molybdenum Disulfide grease? | CZroe | General Motorcycling Discussion | 15 | June 2nd, 2013 11:48 AM |
moly-lithium grease | akcalhoun | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 5th, 2012 03:42 AM |
grease for lever replacement | BFisher244 | 1986 - 2007 Ninja 250R Tech Talk | 4 | May 29th, 2012 06:03 AM |
moly lube and grease | eddiekay | 2008 - 2012 Ninja 250R Tech Talk | 12 | January 30th, 2010 04:36 PM |
OK to use this grease? | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 18 | December 27th, 2008 03:33 PM |
