February 4th, 2013, 11:22 AM | #1 |
Join Date: Feb 2012 Motorcycle(s): Kawasaki Ninja 250R FI 2009, Hyosung GT650R 2008 FI Posts: 27
Strange sound while riding on Ninja 250R
I think nobody in the world ever faced this situation.
I was heading back home from work at night on my Ninja 250R FI 2009 with 50K on it. The engine was warmed up before I left the parking lot. The weather is cold. After reaching the 60-80 kph the weird sound/noise surprised me. I noticed when I push the clutch the engine continue to run on idle speed regularly although the noise goes with the speed, as the speed lowers below 60-50 kph the sound/noise dissapears. What can it be guys? I'm seeking for help, it just bothers me. I didn't notice any damage to the engine or whatsoever. I spoke with the mechanic and he didn't have any clue O_O Please hear and listen, comments or any ideas would be appreciated a lot. Help me to understand and to solve this issue please. Thanks a bunch!!
Ninjettes |
February 4th, 2013, 11:31 AM | #2 |
February 4th, 2013, 11:36 AM | #3 |
LOL it has chain. Yeah this squealing sound is very annoying. Like it's crying out for help before death
Ninjettes |
February 4th, 2013, 11:40 AM | #4 |
MOTM - Sep '14
Speedo cable maybe?
February 4th, 2013, 11:43 AM | #5 |
It is related to the final drive, since it is independent from the rpm's of the engine.
It could be any of the bearings (rear wheel or output shaft) or a neglected chain. Could be also related to the front wheel (bearing or speedometer cable). Put the bike on a central stand and rotate each wheel by hand has fast as possible (watch for that chain).
February 4th, 2013, 11:57 AM | #6 |
Sounds like the speedo to me.
February 4th, 2013, 01:14 PM | #7 | ||||
allanoue
A drilling/spinning sound that touches some surface somewhere that's I think it is. Motofool Quote:
Ninjettes |
February 4th, 2013, 01:17 PM | #8 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
Sounds like someone put a portable air raid siren on your bike.
February 4th, 2013, 01:30 PM | #9 |
Bass Master General
It's your speedo cable, don't believe me? Give your gauge cluster a good whack while riding and hear the sound blip in tone as you hit the cluster, the cable vibrates, causing the cluster internals to vibrate acting like an amplifier.
I had the exact same problem. |
February 4th, 2013, 01:31 PM | #10 |
funny or not it had an alarm a year ago. Until I decided to screw the bolt to its place which at the end I ****ed my fuel pump. I had to remove the alarm from the bike at all. I didn't know how and where to look for it so some mechanic did it. Could be he left the "horn" on, all the time. lol but the sound is very rare.
Ninjettes |
February 4th, 2013, 01:37 PM | #11 |
Your bike sounds like the speedo in this video. A little lube may fix your problem. basically the shaft on the inside of the cable is rubbing metal to metal.
February 4th, 2013, 01:38 PM | #12 | |
The easiest test is to disconnect the cable from the front wheel, secure it to the chassis and ride the bike.
February 5th, 2013, 03:30 AM | #13 | |
Another mystery has been solved thanks to NINJETTE.org you are great!
Ninjettes |
February 5th, 2013, 03:32 AM | #14 |
Bass Master General
February 5th, 2013, 03:34 AM | #15 |
Ninjettes |
February 8th, 2013, 07:49 PM | #16 | |
Join Date: Nov 2012 Motorcycle(s): 2012 ninja 250 Posts: 3
February 8th, 2013, 08:59 PM | #17 |
You should unscrew the cable at the wheel and pull out the inner shaft carefully (note which end goes where), coat the entire cable with moly grease (found at auto parts stores) and re-install, making sure the ends seat the right way. You may have to turn it a little to go back in.
February 8th, 2013, 09:30 PM | #18 | |
February 9th, 2013, 02:39 AM | #19 |
Bass Master General
February 9th, 2013, 10:07 AM | #20 | ||
February 9th, 2013, 10:37 AM | #21 | |
Bass Master General
It still happens to me though, occasional. |
February 9th, 2013, 02:55 PM | #22 | |
Also check this thread. http://www.ninjette.org/forums/showt...nt+axle+squeal |
new sound on my ninja 250r | kimolottie_06 | General Motorcycling Discussion | 7 | July 11th, 2012 03:30 PM |
strange static sound after 5.5k rev? | arnoldc6 | 2008 - 2012 Ninja 250R Tech Talk | 13 | July 11th, 2012 01:07 PM |
Strange sound | Old Lemon | 2008 - 2012 Ninja 250R Tech Talk | 18 | June 8th, 2012 01:51 PM |
2011 Ninja 250R Strange Gear Shifting | Greyfox | General Motorcycling Discussion | 3 | January 30th, 2012 07:13 AM |
Strange sound at 70+ mph | DirtyBoy | 2008 - 2012 Ninja 250R Tech Talk | 9 | February 2nd, 2009 12:33 AM |
