March 25th, 2013, 11:13 AM | #41 | |
Join Date: Mar 2013 Motorcycle(s): 2011 Ninja 250 Posts: 115
I am 6 foot and weigh between 155-175 usually. I actually am just modding to mod, I love to mess around with stuff and its a good way to learn what's inside the bike. |
March 25th, 2013, 01:00 PM | #42 |
My suggestion for freebies:
Then when you get a little more paper, go for fork springs/thicker fork oil if needed and good tires. Those will make the biggest difference to how the whole bike feels for the money you're spending. Then SS lines if you're feeling like you want a little more finesse on the brakes. Splurge for Vesrah sintered pads on the front next time you need to replace pads. You can tinker with anything, the question is just your level of comfort while doing so. Learn as you go. |
March 25th, 2013, 04:05 PM | #43 |
Join Date: Mar 2011 Motorcycle(s): 2007 ninja 250r Posts: 374
Best free mod you can do is become a better rider.
March 25th, 2013, 04:12 PM | #44 |
^^^ well yes! Like they say, it's not the bike it's the rider.
But I'm not going to tell someone not to tinker with their new toy if tinkering in their blood. That would be somewhat hypocritical of me. |
March 25th, 2013, 06:49 PM | #45 |
Join Date: Mar 2013 Motorcycle(s): 1999 Ninja 250R Posts: 59
cant seem to find a link but i know I saw a front fork preload spacer made from PVC and washers
March 25th, 2013, 08:38 PM | #46 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
spraypaint the windscreen black, just make sure you get proper spraypaint for plastic...
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound |
March 25th, 2013, 08:43 PM | #47 | |
http://faq.ninja250.org/wiki/Where_c...oad_spacers%3F Only use preload spacers if you need more preload. Preload is not a substitute for stiffer fork springs. That's one modification I won't recommend unless it's needed. |
March 25th, 2013, 09:05 PM | #48 | ||
Wiring turn signals to act as daytime runners I've also never heard of, another google search on the way. Never thought to adjust the rear shock, could probably be a bit stiffer now that I think about it lol. THanks man! mhmmmm. Quote:
Thanks guys! |
March 25th, 2013, 09:19 PM | #49 |
DRL's:
http://faq.ninja250.org/wiki/I_want_...pods_into_DRLs or the easier method: ...which I can't find. Let me keep searching tomorrow. Ziptie: http://www.ninjette.org/forums/showthread.php?t=26270 |
March 25th, 2013, 10:59 PM | #50 |
Awesome, thank you
March 26th, 2013, 07:17 AM | #51 |
Easier method for running ligths:
http://www.customled.com/products/ma...ic_blinker.htm If you don't already have wiring/solder/shrink tubing/soldering iron, the first method I listed will end up about as expensive as the pair of magic blinkers. I should have just used those to save space. |
March 26th, 2013, 08:05 AM | #52 | |
Certified looney toon
MOTM Jul '13, Jul '14
http://www.ninjette.org/forums/blog.php?b=1099
<-- Linky Hey Unregistered! The code [you] shows the username currently logged in. IBA # 56020 AMA # 521481 Fun Rides! ][ My Videos ][ My Gear Hold yourself to the same rules you expect others to follow. Last futzed with by NevadaWolf; March 26th, 2013 at 08:07 AM. Reason: Price change |
March 26th, 2013, 08:40 AM | #53 | ||
March 26th, 2013, 08:57 AM | #54 | |
BTW I wasn't sure how the blacked out windshield would work so I used Plasti-Dip to be able to remove it at a later date if I needed to. Just an idea if it's available.
March 26th, 2013, 08:59 AM | #55 |
buy pvc, cut new spacers for your forks, change the fork oil -- $15
buy quarter inch thick 1 inch wide steel strip, make new dogbones that are 0.5" shorter to give you a 1 inch raise in the rear - $5 if you want to get fancy, buy an ebay gsxr rear shock... probably wanna respring it. you'll need the bones even shorter for that one. i believe its 1" shorter so make the bones 1.5" shorter than stock - $30 pull the snorkel, rejet 1 size up with jets from jetsrus.com - $20 buy some ebay sv650 clipons and get rid of those weird street bars, then lower the forks 15mm in the triple. - $50 now your rake is set to 23.5 degrees with 3.75" trail. the same as a motogp bike. total cost: $120. result: an actually ride-able bike.
March 26th, 2013, 09:09 AM | #56 |
Just looked into the tire hugger anddddd, 150 bucks... Damnit. Was really looking forward to that one
March 27th, 2013, 02:32 PM | #57 |
Anyone want to buy me that cbr tire hugger and ship it to me in Canader?
March 27th, 2013, 02:36 PM | #58 |
Bass Master General
My favourite inexpensive upgrade would be the £20 Phillips x-treme vision 100% bulbs. They are a lot brighter, almost too much, the definition I get on the road highlights every crack and they light at night time is a perfectly neutral white.
Inexpensive performance gain? | Zackninja | 2013 - 2017 Ninja 300 Tech Talk | 21 | August 7th, 2014 11:19 AM |
Inexpensive rear stand? | kdogg2077 | General Motorcycling Discussion | 36 | July 8th, 2014 08:26 AM |
Inexpensive slip-on exhaust | peteypetepeep | Items Wanted | 4 | March 20th, 2014 05:49 PM |
Want an inexpensive mini battery | nick5446 | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 13th, 2013 05:25 AM |
Inexpensive Steering Damper | TheJimmyEnglish | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 11th, 2011 11:31 AM |
