September 6th, 2010, 09:46 PM | #1 |
which size needle goes where?
ok so i shimmed my needles again and well this time i didnt keep track of which needle came form which cylinder
my question is ...does the longer needle go in left cylinder or in the right cylinder lleft being the one on clutch side and right on brake side .. bike runs fine i just want to make sure i did it right |
September 6th, 2010, 09:54 PM | #2 |
I think they are the same length, but have different tapers. they part number is lightly engraved on the needles themselves.
as for which needle goes into which carb.... http://www.ninjette.org/forums/showthread.php?t=9467 |
September 7th, 2010, 10:36 AM | #3 |
thanks kelly you sir are a savior i pulled one needle today to confirm that it was the right part number for that side..and...............TIS WAS RIGHT!
lol |
September 7th, 2010, 10:46 AM | #4 |
This brings up another question for the carb guru's along the same lines as the topic question.
Stock the carbs come with needles tapered differently for each carb. Do you recommend having both needles of the same taper or is the engine designed for this? Thanks in advance. |
September 7th, 2010, 10:50 AM | #5 |
I'm not 100% sure, but I believe there were others that installed the needles reversed and the bike ran like crap when they started it up. Can't say for sure though as when they went to switch the needles, they may have done something else to correct a mistake that was really causing their problem.
That your bike was running nice and smooth should have been indication that you had things correct. Glad you took the time to check and have peace of mind. btw, how do you like the result of shimming? |
September 7th, 2010, 11:03 AM | #6 | |
I think the pregens have matching needles, unlike the newgens. I think it has something to do w/ emissions control that the factory needed to do to hit a target level which was one of the (major?) factors that prompted the redesign of the bike. Keep in mind the two carbs in the newgen are identical except for those needles and the mixture screw settings. while matching needles may be desirable, if you're going to go through all that trouble (you'll need to buy a needle... which one??, switch it in, readjust the mixture screws), IMHO you would be better off installing aftermarket needles from one of the aftermarket jet kit companies which would afford you proven R&D that they have done, plus an easy, wider range of adjustability through the clip grooves in them. |
September 7th, 2010, 11:45 AM | #7 |
Thanks KKim. Great explanation.
September 7th, 2010, 01:57 PM | #8 | |
i have good knowledge on the carb needles they have different tapers but are componsated by different mixture adjustments, hence the reason for when u get aftermarket needles u need to mess a good amount with the mixture screws because they werent equal to begin with much less setup for tyhe new needles |
2008+ Ninja 250 Carburetor Screw size, allen screw size! | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 2nd, 2015 11:49 AM |
Stock Needle Size? | RobDog | 2008 - 2012 Ninja 250R Tech Talk | 1 | January 30th, 2015 04:00 PM |
[RoadRUNNER] - 2015 KTM RC390: Fun Size is the Best Size | Ninjette Newsbot | Motorcycling News | 0 | September 9th, 2014 03:01 AM |
Keihin Needle Jet size | ztrack157 | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 29th, 2009 11:01 AM |
WTT: Size S Synergy Heated Gloves for Size M like kind | headshrink | Items Wanted | 0 | March 26th, 2009 01:45 PM |
