March 29th, 2013, 03:47 PM | #1 |
Rear wheel alignment
So I will be taking off my rear wheel tomorrow to get a new tire put on and I need to figure out how to realign everything. I know the hash marks are not very accurate so I tried measuring from the swing arm bolts to the axle bolts. Its kind of hard to do with the exhaust in the way. I guess a piece of string would work better than a tape measure :/
Is that accurate enough? How exact does it have to be? I know that people have trouble keeping everything aligned when they tighten the axle bolt, what exactly is the best way to go about this? Measure, tighten the axle bolt, remeasure and loosen the alginment nuts or is it necessary to always loosen the axle bolt? |
March 29th, 2013, 05:51 PM | #2 |
Read this threrad:
http://www.ninjette.org/forums/showthread.php?t=13833 If you keep forward pressure on the rear wheel as you tighten the axle bolt, everything will stay as adjusted.
March 29th, 2013, 07:47 PM | #3 |
You can be way off and not even know it. We eyeball at the track. But..... do your due diligence here to get the max life from your tire and chain. Because at the track we have very nice suspension* setups and don't really care about tire life.
*Suspension can eat up alot of things like vibrations, alignment issues, unbalanced tires and even warped wheels.
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; March 30th, 2013 at 07:24 AM. |
March 30th, 2013, 06:57 AM | #4 | |
MOTM - Mar '13, Jun '14
March 30th, 2013, 07:19 AM | #5 |
March 30th, 2013, 08:44 AM | #6 |
lol. It really bums me out that there are so many diy's/how to's but none of the pictures work
March 30th, 2013, 10:36 AM | #7 |
So here is my rear tire. It definitely has chicken strips from the previous owner; very little tread in the center and tons on the sides.
Its pretty dusty in my garage, hence the huge contrast in shade; flash doesnt help either. Anyways, I was going to take the tire to get it changed out today but do you think it is necessary? As long as I dont ride in the rain, I feel like it would be fine for a little bit (a few hundred miles). Or should I get it changed out right away? |
March 30th, 2013, 12:51 PM | #8 |
The tire is in terrible shape, way past the wear bars in the center. But more than that, it's so flat spotted that the bike must feel pretty awful. A new tire will make it feel like a new bike. If the back looks that bad, what does the front look like?
March 30th, 2013, 01:08 PM | #9 |
dammit. I wish I could have gotten a reply a bit sooner, now I will have to wait to get a tire installed
Front has similar wear (sides are pretty clean) but there is still quite a bit of tread left. |
March 30th, 2013, 01:12 PM | #10 |
Get two new tires and you will enjoy riding this summer so much better (and safer).
March 30th, 2013, 05:50 PM | #11 |
March 30th, 2013, 06:18 PM | #12 | |
I think I might as well pick up a new front as well since they are on sale at motorcycle superstore. Probably wouldnt throw it on for a while though. |
April 2nd, 2013, 09:44 PM | #13 |
Got the new rear on today, but I havent been able to ride since it took me forever to get the damn wheel aligned.
I built a tool like in that thread (metal pipe, clamps, etc) and it seems accurate enough. I spent 3 hours doing the damn string method though...god it is awful. I feel that the string method is just as accurate as the tool method; not 100% but close enough. My problem with the string method is that there are too many variables. The string on the back of the tire can end up in between tread, the point where it hits the front area of the tire is always different (can be just barely touching, might be almost touching, might be touching a bit more than "barely"), then measuring the distance between the strings and the front wheel can be slightly off, and the front wheel might not even be completely straightened. The string method is way to tedious and I felt like I was able to get equal measurements just by slightly adjusting tension on the string and varying the amount that it was touching the tire :/ There has to be a better way. The tool is much quicker and easier but it still only gives a result that is "close enough" |
April 3rd, 2013, 07:01 AM | #14 | |
http://www.youtube.com/watch?v=MkhH3nl0glc
April 3rd, 2013, 07:54 AM | #15 |
May not be better, but there are other ways:
http://www.realclassic.co.uk/techfil...alignment.html http://www.proaligner.com/howitworks1a.html http://www.1off-design.co.uk/wheel_alignment.php http://geoffjames.blogspot.com/2010/...-handling.html
April 3rd, 2013, 11:43 AM | #16 | |
The proaligner looks good but how the hell does it work? |
April 3rd, 2013, 11:49 AM | #17 |
April 3rd, 2013, 11:53 AM | #18 |
Just found that. Kind of weird, so do you sit it on the rear wheel and then lay down and look from the front of the wheel to the ruler? I feel like that is kind of hard to see, especially with fairings in the way
April 3rd, 2013, 11:54 AM | #19 |
It's a distant cousin to the string method. Visually seeing whether the two tires are in line, with a guide.
April 3rd, 2013, 12:01 PM | #20 | |
April 3rd, 2013, 12:10 PM | #21 | |
This way looks easiest but It wont work with the bike on the rear stand. I guess if I could get someone to hold the bike up straight it would work. I might have to fabricate something out of some stainless steel tubing I have lying around |
April 3rd, 2013, 12:43 PM | #23 | ||
Pipes will always have some deformation. More about the Pro-aligner: http://hans.fugal.net/blog/tag/proaligner/ Quote:
You could use the side stand if your bike has one; all you have to do is to incline the ruler.
April 7th, 2013, 09:51 AM | #24 |
covered in awesome sauce
Join Date: Aug 2011 Motorcycle(s): 09 Ninja 250r racebike, 09 Triumph Street Triple R Posts: 31
Like many members, I always eyeball it. More importantly, I always change front and rear tires at the same time to preserve handling.
DIY- Chain Adjustment and Rear Wheel Alignment | kkim | General Motorcycling Discussion | 76 | January 14th, 2015 12:56 AM |
Rear-wheel feels like it's kicking out of alignment | Sykes92 | Riding Skills | 28 | March 15th, 2014 05:11 AM |
Chain slack and rear wheel alignment | alex.s | Videos | 5 | February 24th, 2012 12:30 PM |
Rear Wheel Alignment | Gorilla25 | 2008 - 2012 Ninja 250R Tech Talk | 16 | September 27th, 2011 11:38 AM |
rear wheel alignment tool | quanttrom | 2008 - 2012 Ninja 250R Tech Talk | 11 | September 3rd, 2011 10:03 PM |
