July 29th, 2015, 06:48 PM | #1 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
Kickstand Tab Removal?
What tools did you use to remove the tab from the frame? I have a 4'' angle grinder but that seems a bit crude to use. I'm not familiar with this type of job.
July 29th, 2015, 06:56 PM | #2 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
What you have. Or a air-powered muffler cutoff tool with a 3" disk.
How are you going to keep the bike upright the 99.9% of the time you're not riding it? |
July 29th, 2015, 07:40 PM | #3 |
Motorcycle Nurse?
Rear Stand, this is a dedicated trackie
July 29th, 2015, 09:02 PM | #4 |
Join Date: Aug 2009 Motorcycle(s): 2014 Ninja 300, 2008 ZX6, 2011 Ninja 1000 Posts: 622
Recipricating saw handles it in about a minute. Just be careful of the fairing tab right behind it. Once you take it off, then you can use the angle grinder to smooth things out. Then hit it with some black spray paint and you are done.
July 29th, 2015, 09:47 PM | #5 |
Motorcycle Nurse?
I got it off with the grinder but good god that took at least 30 minutes.
July 29th, 2015, 10:44 PM | #7 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
I used an angle grinder. Easy, took 2 minutes maybe.
CVMA #531 |
July 30th, 2015, 01:02 AM | #8 |
Join Date: Feb 2015 Motorcycle(s): 286, 296, 599, 799 Posts: 436
angle grinder with a cut off disc, then smooth the edges with a flap disc.
toss all your stone grinding wheels in the trash! |
July 30th, 2015, 06:00 AM | #9 |
Motorcycle Nurse?
Yeah I used a stone grinding wheel...
Did I cut off enough to be in the clear? |
July 30th, 2015, 06:14 AM | #10 | |
Join Date: Dec 2014 Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100 Posts: 185
I also drilled out the rearset pegs a bit and use a MX stand, instead of having to lug a rear stand around with me to the track Last futzed with by GregS; July 30th, 2015 at 09:42 AM. |
July 30th, 2015, 12:48 PM | #11 |
no.
There is a line across the frame at the top of the tab. Cut just below that line. There should be no mounting holes for the kickstand left.
CVMA #531 |
August 8th, 2015, 03:57 AM | #12 |
racer on a budget
Join Date: Oct 2009 Motorcycle(s): 2009 Ninja 250, 2006 ZX6R Posts: 55
I used a reciprocating saw with a blade for cutting metal -- then a year later I saw that Brandon Paasch's 250 still had the tab, just removed the kickstand. Since he basically lays that thing on the ground thru turns, I figured the tab doesn't actually need to be removed...
'06 Kawasaki ZX6R '09 Kawasaki Ninja 250 My rider profile |
August 8th, 2015, 10:42 AM | #13 | |
August 8th, 2015, 12:15 PM | #14 |
August 8th, 2015, 01:08 PM | #15 |
racer on a budget
Yikes - I stand corrected. I guess I'm glad I cut it off then
August 10th, 2015, 07:44 AM | #16 |
For the 250, definitely cut it off if you plan on racing it. For the 300, you can leave it since there are no clearance issues with this bike.
August 27th, 2015, 07:28 PM | #17 |
On the topic of kickstands, is cutting or modifying the kickstand required to be able to put the kickstand down with Hot bodies track belly pan? I see there is a cut out already for the kickstand however I feel like the kickstand spring and would hit.
August 27th, 2015, 09:47 PM | #18 |
Motorcycle Nurse?
If we're talking about the 300, I believe you're safe without modifications to the tab.
August 27th, 2015, 09:50 PM | #19 |
Track Clown
MOTM - Sep '15
i used a dremil with a cut off wheel.
August 28th, 2015, 05:50 AM | #20 | |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
It's not so much the spring but the tab itself won't allow the bodywork to line up properly. |
Removal of flames | JudyG | 1986 - 2007 Ninja 250R Farkles | 14 | April 18th, 2015 12:41 PM |
Kickstand switch removal | cookiebug79 | 1986 - 2007 Ninja 250R Tech Talk | 9 | April 3rd, 2013 06:37 PM |
Airbox removal + Kleen air removal? | MikeBudd | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 16th, 2012 04:57 PM |
[topix.net] - Awesome Pull Tab Sculptures | Ninjette Newsbot | Motorcycling News | 0 | February 18th, 2011 10:00 AM |
Kickstand safety kill switch removal? | paterick4o8 | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 17th, 2009 12:05 PM |
