Old October 13th, 2013, 01:12 PM   #1
simook
Mixture screw turns.
This is probably just one of those situations where I'm just over-thinking the technicality of what a "turn" consists of. For the life of me I can't find any reference on google or in any of my mechanical books.
So to help convey what I assume a turn is, here's a quick graphic.
http://imgur.com/dT5jJ68
Right?
simook is offline   Reply With Quote
Old October 13th, 2013, 01:43 PM   #2
Yes sir, one complete revolution.
Old October 13th, 2013, 01:45 PM   #3
simook
Thank you!
Old October 13th, 2013, 01:46 PM   #4
Old October 13th, 2013, 02:00 PM   #5
I like to put a clear mark on the screwdriver handle in relation to the position of the blade to give you some reference when setting the screws.
Old October 13th, 2013, 02:26 PM   #6
simook
Good idea, I was only thinking of using a sharpie to mark the screw.
Old October 13th, 2013, 06:45 PM   #7
The screw is not visible when the carbs are installed - so it's nice to have some reference.
Start by turning the screw all the way in and seating it lightly, then note where the mark on the screwdriver is - that's your reference "0" point.
Old October 13th, 2013, 07:26 PM   #8
simook
Gotcha. That makes more sense if the carbs are still installed.
Stock mixture screw settings ferret09 2008 - 2012 Ninja 250R Tech Talk 6 September 12th, 2023 11:00 PM
what is the best idle screw mixture vmax 2008 - 2012 Ninja 250R Tech Talk 9 July 1st, 2017 10:45 AM
Idle Mixture Screw Problem gogoKawi 2008 - 2012 Ninja 250R Tech Talk 6 April 23rd, 2013 07:07 PM
Adjusting the Idle Mixture Screw conrya5 2008 - 2012 Ninja 250R Tech Talk 22 March 18th, 2013 05:03 AM
Idle Mixture adjustment screw Q indr 2008 - 2012 Ninja 250R Tech Talk 1 December 2nd, 2010 09:36 PM
