September 2nd, 2014, 02:09 PM | #1 |
Jersey Devil
Join Date: Oct 2012 Motorcycle(s): '06 Ninja 250 Posts: 469
Horn and Brake Light not working
Neither my horn or brake lights work after bleeding my brakes and I have no idea why. The fuses look fine.
Any ideas? Blinkers work, headlight work, bike starts, all that. But no horn sounds and no tail light for front or back brakes. Also the fan hasn't been coming on. In all honesty I have no idea how long the brake lights haven't worked, it all could've gone at the same time and I never noticed until I actually checked after bleeding.
~Riding like a grandma because I wanna ride as a grandma~ |
September 2nd, 2014, 02:56 PM | #2 |
The problems might be related, but they might not. If neither front or rear brake switch is activating the light, I'd start looking at the light itself rather than the sensors. Are you sure the bulb is good?
September 3rd, 2014, 08:23 AM | #3 |
Join Date: Apr 2009 Motorcycle(s): 2000 250 sold; 2005 636 sold. BIKELESS IN ATLANTA Posts: 753
If the fuses are fine, it's time to start checking your wiring. I would start with checking power to horn and brake light. I don't have the wiring diagram in front of me, but that is your next step.
September 3rd, 2014, 01:54 PM | #4 | |
Jersey Devil
so yeah, looking at everything. If I can get the horn to work but the tail light to not, then it's more likely the bulb as well.
September 3rd, 2014, 02:17 PM | #5 |
Easiest way is to use a test light to check for power at the positive wire (on the horn or at the light socket) when you activate the button/switch.
That gives you a good place to start. |
September 3rd, 2014, 02:43 PM | #6 |
I'd check your ignition plug and rectifier plug too.
September 4th, 2014, 01:31 PM | #7 |
Jersey Devil
It would seem my brake light was just a loose wire. :|
Derped there. My tester light seems to only work when it wants unless there is only power to all the wires sometimes.
September 5th, 2014, 09:35 AM | #8 |
Congrats on the first issue. Someone will verify this, but some components won't work (maybe receive power) until the bike has been started.
September 5th, 2014, 09:46 PM | #9 | |
Jersey Devil
with the light being the main safety issue in mind, I'm tabling the electric issue for now in favor of the fact that I just had to drop $100 on a new battery. $100 could have gone towards a very, very needed valve adjustment.
September 6th, 2014, 05:10 AM | #10 |
sammich maker
MOTM - Apr '15
Did you check the grounds or switches for the horn or fan?
September 6th, 2014, 10:54 AM | #11 |
September 6th, 2014, 04:39 PM | #12 |
September 6th, 2014, 04:41 PM | #13 | |
September 6th, 2014, 04:44 PM | #14 |
sammich maker
MOTM - Apr '15
September 6th, 2014, 04:51 PM | #15 |
sammich maker
MOTM - Apr '15
September 6th, 2014, 08:37 PM | #16 |
Jersey Devil
i've got the wiring diagram but electrical systems may as well be magic to me. I need to read up on it or have someone show me eventually.
I appreciate the help, though!
September 7th, 2014, 07:38 AM | #17 |
sammich maker
MOTM - Apr '15
To follow it, start with the beginning or end pick a wire and follow it on the bike. It is intimidating at first but once you are looking at the bike and working one at a time its not so bad. Hopefully someone close to you can help. You could also use a tester to test continuity of the wires.
brake light and signals not working :( | cuz | 2008 - 2012 Ninja 250R Tech Talk | 16 | August 28th, 2012 07:52 PM |
Tail Light + Brake Light Not Working (Bulb Replaced) | JayZE302 | 2008 - 2012 Ninja 250R Tech Talk | 11 | August 8th, 2012 05:03 PM |
Brake light not working when I use the back brake? | ladyrocket | 2008 - 2012 Ninja 250R Tech Talk | 7 | November 9th, 2011 01:36 PM |
Horn Not Working | Liist | 2008 - 2012 Ninja 250R Tech Talk | 2 | October 30th, 2011 11:01 AM |
Front brake light not working, help please. | miks | 2008 - 2012 Ninja 250R Tech Talk | 20 | October 5th, 2010 08:01 PM |
