July 12th, 2012, 06:57 AM | #1 |
Top Speed Help!!!!
So i bought my 08 250 about a month ago and I love it, I ride it everywhere! But theres one issue my top speed seems very low. I get to 80 and it will not budge any faster. I have read in different forums that must people can easily get to 90 and can make their way to 105. i weigh 145 lbs soaking wet so I know its not me weight. I recently cleaned the air filter, did 2 oil changes (overfilled the first time), got a new front tire, and used one treatment of Seafoam.After all that it runs a whole lot better but she still wont budge one mph over 80
I really dont want to take the bike to the shop, but im running out of ideas that it could be. Would spark plugs effect the top end? should I get my carbs cleaned? Thanks in advanced! |
July 12th, 2012, 07:14 AM | #2 |
Join Date: Jul 2011 Motorcycle(s): 2009 Ninja 250R Posts: 76
Check the sprockets and find out how many teeth are there.
July 12th, 2012, 07:15 AM | #3 |
Tuck in further. Pull the snorkel; the main jet is rich. Go down a slight hill.
Don't worry so much about top speed, its a 250. Even jetted and with a full exhaust, I only got to 103 actual speed at mid Ohio, and I'm 135 and tucked in completely. Edit: that straight is also a slight downhill, but who's keeping track? Posted via Mobile Device Last futzed with by choneofakind; July 12th, 2012 at 08:48 AM. |
July 12th, 2012, 07:29 AM | #4 |
thanks guys, Im not worried about top speed, but i was pushing it one day and it only went to 80 just trying to make sure nothing is wrong. Im alot more happy doing 50 on back roads. How many teeth should the rear sprocket have?
July 12th, 2012, 07:40 AM | #5 | |
That said, if your bike is stopped at a true 80 mph and won't go any faster on level ground with no wind, it does sound like it might be down a bit on power. Air filter, jetting, aligned rear wheel, lubed chain, wheel bearings, and riding position would all be things I'd look into to see how they might affect your performance.
July 12th, 2012, 07:50 AM | #6 |
What rpm and what gear (6th i presume) when you hit this "80" top speed? That should let us know if your motor is under-performing.
July 12th, 2012, 07:50 AM | #7 |
thanks Alex
July 12th, 2012, 07:52 AM | #8 |
i usually shift up to 6th at around 70 mph
July 12th, 2012, 07:57 AM | #9 |
Stock gearing is 14front and 45rear.
July 12th, 2012, 07:59 AM | #10 |
45 rear, im guessing the front is stock as well but I cant see it
July 12th, 2012, 08:16 AM | #11 |
40 on the road
Join Date: Oct 2010 Motorcycle(s): 2008 Ninja 250, 2012 Ninja 650, 2006 Bonneville, 1990 Sportster Posts: 67
There can be enormous difference in the jetting when these roll off the assembly line. Our '08 has pulled red line in every gear since new. Never any hesitation off the line. No flat spots. A great runner from day one and a joy to ride. One of our two '11 250s would not rev above 10K in 6th and was hard pressed to pull a verifiable 80. The other was modestly better but the '08 ate both of their lunches until carburetor issues were sorted out.
When both '11s were properly jetted and mixture screws set, life became much better. Many riders here have done the work themselves at little expense with great results. If you're not comfortable doing the work you may be able to find a ninjette.org member near you who is willing and able to help (many good folks on this site), or, if you have a reliable dealer near you - we've got a superb one; Hollinks Motorsports, Spencerport, NY - check them out for a written estimate. |
July 12th, 2012, 08:55 AM | #12 |
Also, if you're going for top speed, try winding up 5th to about 12500. That should get you over the 80mph hump. Then shift to 6th (which should be in the power band at that point) and see how far it'll go.
I only say this because at 80, 5th will be higher in the power band than 6th. Even if going at it in a lower gear doesn't get you any speed over 80, it will at least get you to where it stops accelerating quicker so you aren't waiting so long. Posted via Mobile Device |
July 12th, 2012, 09:18 PM | #13 |
nice, ill start calling around tomorrow, to compare prices on a carb clean and maybe rejet. Thats the last easy thing I can think of
July 12th, 2012, 10:19 PM | #14 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
Got mine to about 110 indicated (idk actual) coming down a mountain from north carolina today.
July 13th, 2012, 04:19 AM | #15 |
Join Date: Mar 2012 Motorcycle(s): 08 Ninja 250R (FI) Posts: 169
with my 187lbs i got it to exacty 160km/h (100 mph) by speedometer.
and another thing... has EU different stock sprockets? cus i have 43 rear?? |
July 13th, 2012, 04:45 AM | #16 | |
Pull your snorkel (this will get the main jet a little bit closer to right) Shim the needles to richen the midrange. Then go rip it through every gear and see how it pulls. You've seen my 0-60 thread; open it up all the way to 12500 or 13000 in every gear. Don't shift to 6th before you get to 80! Lol. what elevation are you at? Posted via Mobile Device |
July 13th, 2012, 05:48 PM | #17 |
i have no clue on elevation lol, im in Lancaster Pa though. Ill check your 0-60, I have no clue how to pull the snorel or rejet but Ill do a little digging I rather do things myself if Im able thanks choneofakind
July 13th, 2012, 06:36 PM | #18 |
ahhh i see what you mean, after dong a little research I see that might do the trick. I'll probably give it a try next week
July 17th, 2012, 05:12 PM | #19 |
Let us know how that goes. I think you should be able to break 80 in 5th easy.
As for pulling the snorkel and shimming, there's a great DIY for each. Use the search bar and it should be pretty quick to find. |
July 17th, 2012, 06:36 PM | #20 |
Join Date: Sep 2011 Motorcycle(s): Cruiser, street, and track Posts: 59
I've been to 100.5 GPS on the Nascar straight at Texas World Speedway
July 17th, 2012, 06:51 PM | #21 |
Join Date: Jun 2012 Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F Posts: 534
Not sure what it was, but tonight I got my pre-gen to indicate 110 MPH. I'm 6'1" and 175lbs.
Check tire pressures, chain, wheel bearings, brakes for dragging, things rubbing the tire. If all that is okay take a look at the spark plugs. They'll tell you what you need to do with the jetting. |
July 17th, 2012, 07:59 PM | #22 | |
Jigglin' your Jiglets
MOTM - Apr '13
July 18th, 2012, 02:37 PM | #23 |
Mine's as accurate as a Cadillac's digital speedometer is. I have no idea how accurate that is either, but that's all I have to compare it to. That's all I've got and indicating 110 MPH. Take it with a grain of salt. It sure felt north of 100.
I will admit it was an ever so slight down-hill. It was also over 100 degrees that day, so maybe my tires gained some pressure which decreased rolling resistance. On a no wind, sunny summer day on completely flat ground I can get it to indicate 100 fairly easily. 105 if I decide to wait a minute or so and tuck in REALLY well. |
July 18th, 2012, 02:44 PM | #25 | |
July 18th, 2012, 02:59 PM | #26 |
I agree with alex. My pre-gen is 100% bone stock (no modifications WHATSOEVER to the bike) and it runs lean from the factory. I'm not sure how the new-gen is, but I can only imagine it could need richening up. Even with the stock intake and exhaust on my bike I'm considering going up a size on the main. My plugs look a bit too white for my liking after a high speed ride with lots of WFO action.
July 18th, 2012, 04:41 PM | #27 | ||
The main jets are the only part of the jetting that Kawasaki got right on the pregen. The needles need a washer and the mix screws need to be tuned. |
July 18th, 2012, 04:43 PM | #28 | |
July 18th, 2012, 05:20 PM | #29 |
if the main jet is just a little bit dirty it will seem like its just the wrong size and act lean. topping out at 80 just isnt right, either the sprockets are setup for cruising or his main line is running lean... or maybe the brakes are dragging. you might put it up on stands and verify the wheels spin freely
July 18th, 2012, 05:27 PM | #30 | |
80 mph as top speed means engine is unable to develop standard HP's.
July 18th, 2012, 07:57 PM | #32 |
This reminds me my 6000 mile service is coming up soon. I've been wringing the piss out of my engine. I've got 5200 on it now and these last two days it has seemed a bit crankier at start up. Valve adjustment time!
July 19th, 2012, 04:33 AM | #33 |
Good point on the valves.
Even if the sprockets are really tall, downshifting would work. A cleaning might be in order though. I guess I ruled that out just based on the fact that it doesn't seem to have been sitting. Posted via Mobile Device |
August 5th, 2012, 05:32 PM | #34 | |
August 5th, 2012, 05:40 PM | #35 |
You are welcome!
I hope that adjustment will make your baby fly at 100 mph!!
August 6th, 2012, 04:39 AM | #36 |
Careful, warp speed comes soon after 100!
Black Rabbit, have you looked into adjusting the valves yourself? There's plenty of writeups and info here about that. Idk how mechanically inclined/comfortable you are with the idea of cracking open the valve cover and doing some work yourself, but it will save you about $300ish Posted via Mobile Device |
August 6th, 2012, 05:49 AM | #37 | |
August 6th, 2012, 06:23 AM | #38 |
Wartown, USA
Something's not right if its only getting to 80mph indicated. On mine, at 90mph indicated, it is still trying to accelerate albeit at a slower pace. Mine has 20,000 miles on it. I'm 6'3" and 185lbs.
Did you break it in using Kawasaki's flawed "don't go over 40mph" thing or did you vary the speeds when you broke it in. I'm still of the opinion that following that 40mph limit that Kawasaki recommends ruins the bikes true potential by never really breaking in the engine. The other question is how big are you? If you are big in stature, and wearing loose clothing that acts like a parachute, this might be a reason you are unable to get it to go faster. I'd check simple things like working on your aerodynamics before diving head first into the mechanicals. |
August 6th, 2012, 06:33 AM | #39 | |
August 6th, 2012, 06:48 AM | #40 |
I've never done a newgen valve adjustment, but I've had my cams off for head work and as long as you know how to get the cams timed right (they're marked, its nearly fool-proof) it isn't bad. Is there someone with a 250 near you who needs to do their valves? go help them to learn how it goes.
Top Speed? | Mike K | 1986 - 2007 Ninja 250R Tech Talk | 16 | September 2nd, 2014 03:51 PM |
Top Speed | higear223 | 2008 - 2012 Ninja 250R Tech Talk | 14 | August 3rd, 2014 09:59 AM |
Top speed? | uKER | 2013 - 2017 Ninja 300 General Discussion | 27 | July 20th, 2013 11:33 AM |
Top Speed | Davey | 2008 - 2012 Ninja 250R Tech Talk | 12 | July 23rd, 2011 08:12 AM |
Top Speed? | peter330 | 2008 - 2012 Ninja 250R Tech Talk | 30 | May 29th, 2010 03:02 AM |
