Old August 23rd, 2012, 06:32 PM   #1
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
New Brake Fluid Question
picked up some brake fluid to install new SS brake lines but could only find this synthetic in DOT 4. Everything else was DOT 3. Is this fine to use?
http://shop.advanceautoparts.com/web...ontent=7080002
kevheads is offline   Reply With Quote
Old August 23rd, 2012, 07:31 PM   #2
capriccio
capriccio's Avatar
I used it. It worked.
capriccio is offline   Reply With Quote
Old August 23rd, 2012, 07:47 PM   #3
Flush and fill!
Old August 23rd, 2012, 08:41 PM   #4
DOT 4 resists high temperatures better than DOT 3, but they are both compatible.
See the difference:
http://en.wikipedia.org/wiki/Brake_fluid
Old August 24th, 2012, 05:44 AM   #5
DennyV
Motorcycle(s): 2010 Ninja 250
Dot 3, 4, 5.1 are all glycol based fluids and can be mixed with each other, the numbers just indicate boiling points. Dot 5 is a silicone racing fluid that cant be mixed with anything
DennyV is offline   Reply With Quote
Brake fluid Islandmax 1986 - 2007 Ninja 250R Tech Talk 11 June 22nd, 2013 04:28 PM
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 1 May 30th, 2013 08:13 PM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
How much brake fluid ? GiGs 2008 - 2012 Ninja 250R Tech Talk 5 December 31st, 2010 06:06 PM
Brake Fluid? ASecretNinja 1986 - 2007 Ninja 250R Tech Talk 4 January 20th, 2010 03:02 PM
