Old May 18th, 2012, 12:49 PM   #1
Malicious Logic
hates stupid people
Malicious Logic's Avatar
Motorcycle(s): 2005 ZX6R
Spool Install Question
I was trying to install the rear spools on my bike that came with my shogun kit but I think the right side may be screwed (no pun intended). On the left, the bolt that holds the spool to the swing arm went through no problem. On the right, it only gets maybe 1/4 of the way through before it starts getting really hard to tighten and then almost impossible. I'm thinking maybe the threading inside is stripped. Is there any hope for fixing this? Or am I going to have to pass on the spools?
My vlogging channel: Ma1iciousLogic
Malicious Logic is offline   Reply With Quote
Old May 18th, 2012, 02:02 PM   #2
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
The tapped hole may not be tapped all the way. Other people have ran into this. Pickup a tap the right size (M10 I believe) and try tapping through the hole.
k-os is offline   Reply With Quote
Old May 18th, 2012, 02:22 PM   #3
Malicious Logic
hates stupid people
Does that mean it might not be grooved all the way through? It looks like it just from looking inside but could be wrong. Guessing I'd need drill for that?
Old May 18th, 2012, 02:38 PM   #4
TS250
Motorcycle(s): 2008 NINJA 250, BLACK, 650 NINJA 2009, RED, F 650GS BMW 2012 YELLOW
The put the paint or powder coat and it makes the hole smaller.
TS250 is offline   Reply With Quote
Old May 18th, 2012, 03:06 PM   #5
It might be problems with the threads, but it the spools might also have the wrong thread pitch. More info in this thread:
http://www.ninjette.org/forums/showthread.php?t=31230
Old May 18th, 2012, 03:08 PM   #6
Ichiro
Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150
I had the same problem with the spools that came with my T-Rex rear stand. There was no way they would screw in more than a third of the way. I ended up buying spools from a different manufacturer and they screwed right in with no problem. Not sure what the problem was although some people insisted it was paint built up in the threads.
Ichiro is offline   Reply With Quote
Old May 18th, 2012, 03:10 PM   #7
Yup - in that case it probably was that difference in thread pitch (1.5 bad, 1.25 good)
Old May 18th, 2012, 03:26 PM   #8
Malicious Logic
hates stupid people
Hmmm...just went out there and tried to screw them in with my fingers and neither side would go in more than a few turns. Kinda makes me think it could be the TPI that was mentioned in the other thread. Does that mean I'll have to buy a new set of spools or is it possible to get just the bolts?
Old May 18th, 2012, 04:59 PM   #9
Another thread on the spool pitch here:
Mismatched swingarm spool thread pitch?
Old May 19th, 2012, 01:01 PM   #10
Malicious Logic
hates stupid people
That actually sound exactly like my problem. I'm guessing that the bolts won't be too pricey so I'm gonna run to home depot now and try to get 1 or 2 others to test.
Old May 19th, 2012, 01:56 PM   #11
Malicious Logic
hates stupid people
Just got back from home depot with a 1.5 and no luck. The 1.25 ones I have already go in more than that but not by much. Is the tap that was referenced above for clearing out paint? or resetting the threading?
Old May 19th, 2012, 02:09 PM   #12
Was paint in virgin holes for me. Took me 30 mins to screw in 2 spools. Slowly in and then then back back out a little at a time, cleaning it off as you go... That's how she likes it. Err.... will get the job done. hahahahah
Old May 20th, 2012, 05:13 AM   #13
NJ Ninjette
NJ Ninjette's Avatar
Motorcycle(s): 2012 Ninja 250R, 2007 Husky TE 250, 2002 KTM EXC 250r
NJ Ninjette is offline   Reply With Quote
Old May 20th, 2012, 04:01 PM   #14
Malicious Logic
hates stupid people
A little persistance and determination and this worked. I guess it was just paint after all. Just glad I finally have rear spools. Now I can put my rear stand to use and get to work on those frame sliders.
tire install question mauiwowie 2008 - 2012 Ninja 250R Tech Talk 8 April 18th, 2015 11:44 PM
tire install question mikedabike64 2008 - 2012 Ninja 250R Tech Talk 2 March 1st, 2014 08:05 PM
Spool size? spool bolt length? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 1 November 29th, 2013 08:48 PM
swingarm spool question contact148 2008 - 2012 Ninja 250R Farkles 10 April 16th, 2013 11:18 AM
Koso gauge install question randomwalk101 2008 - 2012 Ninja 250R Tech Talk 6 February 17th, 2012 01:54 PM
