February 12th, 2009, 07:37 AM | #1 |
VooDooMaster
Join Date: Feb 2009 Motorcycle(s): 2008 Blue EX250, 2007 Yamaha Virago 250 Posts: 173
Light Bulbs
I'm thinkin, I need more light to see the road. So, I pick up these nifty high intensity bulbs to install on the blue beastie. Only to find out that I have to remove all the plastic to get to the headlight bulb sockets, at least the manitnenace manual says I have to take off all the plastic.
Has anybody replaced their front bulbs on a 2008 without taking of all the fairings??
VooDooMaster I love the smell of Blue Octane in the morning..... |
February 12th, 2009, 10:31 AM | #2 |
Join Date: Dec 2008 Motorcycle(s): 2008 Ninja 250R, CR125R Posts: 191
Nope, I took mine off. But look through the HID DIY write-up its the same thing.
February 12th, 2009, 11:47 AM | #3 |
if you take off the front side fairings, you should be able to reach up and change the bulbs from going in from beneath.
http://www.ninjette.org/forums/showthread.php?t=9933 |
February 12th, 2009, 06:20 PM | #4 |
Join Date: Dec 2008 Motorcycle(s): 2008 Ninja 250R Posts: 66
I have. All you have to do is reach in from underneath and feel around. Turning the wheel in the opposite direction of the bulb you are changing gives you a little extra room. It's kind of a PITA though but easier than removing a fairing.
49T sprkt/ EK gold chain/ Galfer pads and SS lines/120 frt 150 rr Pilot Powers/ GSX-R can/Desnorkled/ Raised needles/ Slider spools/ Cowl/ LED rear signals/ Fender eliminator/ Tinted lights / Emu seat |
February 13th, 2009, 12:17 AM | #5 |
Join Date: Jan 2009 Motorcycle(s): 2008 250R (Black) Posts: 298
its possible to change the bulbs without taking any fairings off.
February 13th, 2009, 05:21 AM | #6 |
Join Date: Dec 2008 Motorcycle(s): 2008 Black Kawasaki ninja 250r Posts: 40
YES lets be clear about this, cos i had exact same problem. you DONT! have to unmount anything to change bulbs. No fairing pieces needs to come off. i also bought some high intensity light bulbs, but was a bit confused because the manual said nothing about changing bulbs. but anyways, you just have to take your hand, and reach up from underneath the front piece that holds the headlight. first pull off the round rubber grommets that sits over where the bulbs are held. next swith the little metal buckle/pin aside and simply pull out the bulb. reverse the process with the new bulbs, and voila easy piecy!
"...black and undetectable by radar..." |
February 13th, 2009, 09:06 AM | #7 | |
VooDooMaster
Ze HID Bulbs
February 13th, 2009, 10:09 AM | #8 |
good luck and do post some pics
February 13th, 2009, 10:45 AM | #9 |
February 13th, 2009, 10:58 AM | #10 |
VooDooMaster
February 13th, 2009, 11:00 AM | #11 |
VooDooMaster
Bright Bulbs?
I went out to the PIAA webdite and bought a set of their H7 high intensity bulbs. Also can get a score of hits on EBAY for H7's.
VDM
February 13th, 2009, 11:13 AM | #12 |
Ninja World YAY
how some one post the DIY guide for installing the bulbs without removing the fairing
I am looking for some suggestions for high intensity bulbs or HID ? |
February 13th, 2009, 11:26 AM | #13 |
February 13th, 2009, 12:58 PM | #14 |
VooDooMaster
Bulbs
February 13th, 2009, 01:09 PM | #15 |
February 13th, 2009, 02:14 PM | #16 |
Ninja World YAY
i want to know more details about the brand and the model number of the bulbs this is avoid me buying something wrong
February 13th, 2009, 02:52 PM | #17 | |
Last futzed with by Sailariel; February 13th, 2009 at 03:20 PM. Reason: Bike |
February 13th, 2009, 03:26 PM | #18 |
Ninja World YAY
is it legal to have white light in california ?
February 13th, 2009, 04:30 PM | #19 | |
VooDooMaster
New Brighter Bulbs
I changed mine this morning, by taking off the right side fairing only, nothing more. One fairing off was all it took to see everything and to get my mediim size paws in there to work. Taking off any additional plastic is not going to help with the access at all. This job was so easy, even a "CAVEMAN COULD DO IT"! No pictures even needed on this one.
February 13th, 2009, 05:17 PM | #20 |
Ninja World YAY
February 13th, 2009, 05:25 PM | #21 |
for those installing ungraded bulbs, are you aware you can install a set (2 headlights) of HIDs for $60? There is no comparison between the light output of upgraded bulbs and HIDs.
February 13th, 2009, 05:38 PM | #22 |
VooDooMaster
Yup..did know that. Decided to forgo adding additional luggage and wiring. The higher intensity bulbs I slapped in have made an improvement for me, enough of an improvement to satisfy even me ( I am very anal about any changes to my production blue voodoo).
February 13th, 2009, 05:42 PM | #23 | |
VooDooMaster
February 13th, 2009, 11:11 PM | #24 |
Ninja World YAY
February 13th, 2009, 11:22 PM | #25 |
Look in the DIY section of the site. There is a thread with all the info you need on installing the HIDs and where to buy them from.
October 18th, 2009, 04:21 AM | #26 |
Are any of you thinking of selling your original light?
October 18th, 2009, 07:52 AM | #27 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
Check toward the end of the HID DIY. More info on bulbs, kits, etc.
November 28th, 2009, 11:48 AM | #28 |
KawiNewbie
Join Date: Oct 2009 Motorcycle(s): 2009 Ninja 250r Posts: 15
Did my first DIY today on my Ninjette. Highbeam buld went out and was not about to pay the ridiculous labor charge to get it done. Always inclined to learn and do as much as I can on my own, search forum, found this thread and bam! Done. Fairly easy. Had some trouble losening the metal pin but other than that went well. Thnx!
November 28th, 2009, 03:48 PM | #29 |
Since joining ninjette.org, the only part of the Factory Shop Manual I use is the section on torque specs. I use a torque wrench on every bolt, Allen head bolt, JIS Screw (#2 Drywall bit seems to work). What makes it so easy is that I found a 1/4" drive Torque Wrench at Nashbar.com for $59.99US. It comes in a nice case, complete with a set of metric Allen Head bits, and a conversion table for Inch Pounds and Newton Metres. The wrench unlike the 3/8"variety and 1/2" variety is diminuative in size, allowing you acess into many places heretofore inacessable. This is a high quality tool---trust me, all my tools are either Snap-on, Craftsman, or Park. I am too old for "busted knuckles". I am blessed to have a shop with good lighting and heat. I have also made room for my dinosaur 12 year old laptop in the shop. Its only purpose is to acess all the DIYs on this forum. Thanks to all the people contributing to this forum, I may yet become a motorcycle wrench like I was in the past. I am already pretty well established as a bicycle wrench. The DIY section on this forum is priceless.
November 28th, 2009, 08:02 PM | #30 |
Join Date: Sep 2009 Motorcycle(s): 08 ninja 250r modded, 73 honda cl200, 74 kawasaki 400 triple Posts: 255
i see these conversion kits on ebay....are these necessary...or just a way to get more money out of those of us who don't know you could just buy a bulb??? i could definately use more light as well
July 24th, 2010, 11:38 AM | #31 | |
Join Date: Jul 2010 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 6
Dash light bulbs | DR1300R | 2008 - 2012 Ninja 250R Tech Talk | 44 | April 10th, 2018 11:54 PM |
Enhanced H4 light bulbs advertised in Motorcyclist magazine | Motofool | Motorcycle-related | 0 | April 24th, 2013 12:13 PM |
My light bulbs are out! | Black knight | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 18th, 2013 09:50 PM |
headlight bulbs | gamma500 | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 29th, 2009 11:15 AM |
bulbs | mr.niftie | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 12th, 2009 07:18 PM |
