April 5th, 2013, 02:03 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2009 ninja 250 Posts: 15
How to properly start a ninja? Dies on me
Hey guys I just bought a 2009 ninja 250 . And I'm having a hard time starting the bike correctly. I don't know how long do I have to wait for! Please help me I don't want to mess up my bike
April 5th, 2013, 02:04 PM | #2 |
Join Date: Mar 2012 Motorcycle(s): 2008 Ninja 250R Posts: 257
what exactly is it doing when you try to start it? That'll help us diagnose the problem a little better.
April 5th, 2013, 02:04 PM | #3 |
April 5th, 2013, 02:08 PM | #4 |
I don't touch the idle. Because that's at around 1300 to 1500! I'm just confused to know how long do I let the choke on and when I should play around with it. Sorry for the neebie questions. I just don't want to mess my bike up.
April 5th, 2013, 02:10 PM | #5 |
Oh lol sorry. I figured there was something wrong while you tried starting it. That link should answer your questions then. Very helpful
April 5th, 2013, 02:20 PM | #6 |
When I start the bike with full choke it goes to about 5k is that normal the bike is rejetted with jardine full exhuast. And when I rev the bike in nutreul it sometimes hesitates to go higher ! Any idea what could be the cause?
April 5th, 2013, 02:28 PM | #7 |
Join Date: Feb 2011 Motorcycle(s): 2010 250 ninja Posts: 21
Put choke on full, start the bike
revs are going to start to climb. once they are at or over 3k start turning the choke off slowly (millimeters at at time). revs will drop then start climbing again, repeat until choke is off. If the bike is cold it will hesitate when you rev it. |
April 5th, 2013, 02:34 PM | #8 |
how to start the bike:
start the bike. did it start? no? is it cold? turn the choke on and try it again. turn the choke back off once it will run.
April 5th, 2013, 03:28 PM | #9 | |
Boring is my middle name.
Join Date: Aug 2011 Motorcycle(s): '09 Ninja 250r Posts: 258
When does the bike die? When you apply throttle? |
April 5th, 2013, 03:33 PM | #10 | |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
April 5th, 2013, 03:54 PM | #11 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
Ahhh, I absolutely do not miss having a carb bike.
April 6th, 2013, 07:03 PM | #12 |
Help
Today I tried riding but after 2 minutes of riding the bike died or stalled on me! What did I do wrong? Do I hAve to wait more to warm it up?
April 6th, 2013, 07:47 PM | #13 |
How long had the bike been sitting before you bought it? It's starting to sound like gummed up carbs.
April 7th, 2013, 12:08 AM | #14 |
sail away
Did you follow the procedure? Please give more information in order to get an informative answer. The bike takes a bit of time to warm up. It is a cold blooded bike.
April 7th, 2013, 08:18 AM | #15 |
Join Date: Feb 2012 Motorcycle(s): 2007 ninja ex250 Posts: 56
Here's my startup procedure. I put on about half choke and start the bike. Once the bike is running I add or subtract choke to get the bike to 3k rpm's. If at any point durring the warm up the engine speed goes above 3k, remove a little choke to get it back to 3k. Wait about 30 seconds then rev the engine (about a quarter twist on the throttle). If the engine bogs I wait another 30 seconds and repeat until it doesn't bog. Once the throttle response is right (meaning the engine doesn't bog) , I take off with the choke still on. At stop signs and red lights I check the engine speed and temp. Over 3k remove a little choke. Once the engine temp reaches the first line above the cold line ( or maybe just passed it ) turn the choke off. If you can't run with out choke, you have a problem.
NOTE: My bike is an 07 so a little different. Still worth a try. I live in Philly. PM me if you want me to come by. |
How do I use the shock adjustments properly? | Monkeytofu | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 17th, 2012 06:41 PM |
Bike dies with choke after not storing properly... | seamuswh | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 15th, 2012 10:47 PM |
Bike dies after start up | mohns6062 | 1986 - 2007 Ninja 250R Tech Talk | 26 | July 10th, 2011 07:48 PM |
cold start-bike dies??? | fiberoptx | 1986 - 2007 Ninja 250R Tech Talk | 17 | October 31st, 2009 11:51 AM |
HELP! Bike will start but once put in gear dies | TreyE | 1986 - 2007 Ninja 250R Tech Talk | 6 | September 3rd, 2009 12:45 PM |
