Old November 30th, 2020, 09:17 PM   #8321
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
I was over-due on valve adjustment. ( by almost 2000 miles) finally tackled it.( My first time on this Ninja) I dont think prior owner, EVER got its valve service done! ....those exhaust clearances were way, WAY...WAAAAAY too tight.
Then re-tackled the carbs ( initially thats what I thought was causing the poor performance, was taking way too long to start/ run.)
Runs spanktastic now. So crisp, and caffienated!
GAU-8 is offline   Reply With Quote
Old December 1st, 2020, 03:54 PM   #8322
pjed
pjed's Avatar
Motorcycle(s): 1999 Kawasaki ZRX1100, 2006 Yamaha R1, 2006 Kawasaki ZZR600, 2009 Kawasaki Ninja 250R, 2017 Kawasaki Z900
Installed a K&N air filter. Had to clean up after some of the tenants moved out of the air box.
pjed is offline   Reply With Quote
Old December 3rd, 2020, 07:09 PM   #8323
pjed
pjed's Avatar
Replaced the stock can that had some rash with another clean one, removed the front wheel so I can get a tire mounted, then did some cleaning including removing the left fork and scraping a state inspection sticker...thanks Virginia!
Old December 4th, 2020, 10:10 AM   #8324
NinjaPony
New rider
NinjaPony's Avatar
Motorcycle(s): 2021 Ninja 400 (abs), 2004 NinjaEx (2007 motor)
ok I am about to take the carburetor off AGAIN, and see why my 2004 ninjaEX with 2007 motor lol only stays on with choke and then even dies after a while like something is clogging. shes almost done
NinjaPony is offline   Reply With Quote
Old December 5th, 2020, 08:34 PM   #8325
pjed
pjed's Avatar
Replaced the front and rear sprockets. I've had the worst luck with front sprockets lately being very tough to remove. This time, I had to use a piece of my bicycle stand as a cheater bar on my breaker bar.
Old December 6th, 2020, 06:15 PM   #8326
pjed
pjed's Avatar
Installed a set of Shogun frame sliders.
Old December 7th, 2020, 06:59 PM   #8327
Apex
Livin' the Minimoto Life
Apex's Avatar
I miss my ninjette. With the KLR, I haven't done any mods yet. I've been debating on them and if I want to actually spend the money as money is still tight.
However, I did snag some tubes and tire levers for my bike. I also got a cool gadget called a SnapJack. I can jack up my bike on the side of the road and change a tube with no issues with this thing. Downside to having a tubed bike, some of your storage is tubes. Okay, a lot of it because tubes take up so much room. Still, loving my bike. If they'd just make a KLR with a solid and fairly modern engine, then it would be perfect. Oh, and a better seat
Old December 10th, 2020, 05:19 PM   #8328
pjed
pjed's Avatar
Slapped it back together. Next up is an oil change then the first ride.
Old December 10th, 2020, 06:09 PM   #8329
Woohoo!!! Always so satisfying to complete project!
Old December 10th, 2020, 06:28 PM   #8330
pjed
pjed's Avatar
Thanks. This is just temporary as current plan is for this to be a track bike.
Old December 20th, 2020, 03:48 PM   #8331
NinjaPony
New rider
NinjaPony's Avatar
some minor modifications
Today I cut off the box license and rear light holder,.. kind of regret it, it looked more nostalgic but I still like the look. I discovered that Kawasaki left what appeared to be light holes in the rear break compartment for your rear stock lights. YUP! They fit right in the brake light left and right compartments, they are empty and I believe made for this purpose, they fit perfectly perfect. I found an L bracket and put my plate up diagonally. My K&N filter came in the mail finally so I installed that, Ha Ha I kind of man handled the filter and crimped it, should work fine. I tightened up loose bolts and gave her a wipe down.
Old December 20th, 2020, 03:52 PM   #8332
NinjaPony
New rider
NinjaPony's Avatar
Old December 20th, 2020, 04:30 PM   #8333
GAU-8
GAU-8's Avatar
Got tired of my go-pro clone cameras batteries, either dying within 45 minutes-ish..and then they just became DEAD- unuseable.
Found out a few companies make USB plugs, that connect to your battery. ( charging cel phones what not) i purchased two, of the USB ports, then drilled and cut into the watertight housings, so the cameras power supply can fit. Then, I changed setting on the camera to " auto" this means when its connected to direct power , it starts recording on its own.
So I have 1 camera low on the windscreen, and the other camera on my helmet. ( this does mean i am now attatched to the bike via a cord to helmet, but thats fine, ive made areas for some slack/movement, without dangly cords everywhere). As soon as Im ready to ride, i connect both USB to camera cords, start recording, and ready to go!
This way im only limited to the size of memory card, and not changing out batteries, or having a bulk supply of them. The ONLY downside ( to me) is that I MUST remember to disconnect the USB cords, or I'll be recording all night/drain battery. So far, no issues.
Old December 21st, 2020, 04:03 AM   #8334
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
In Japan those lights are orange indicators. In UK the ZZR has the same setup, but not far enough apart for EU regulations, so they were painted out to match to body work. I discovered this, so removed the covers & rubbed the paint off then treated them
To a couple of coats of gloss varnish to restore the surface. Looks much better like it was intended.
Old December 22nd, 2020, 11:41 AM   #8335
pjed
pjed's Avatar
After I changed the oil, I took the bike out for its maiden voyage...it was rough. Carbs were stuttering real bad at the beginning and the forks felt like there was no oil in them. Carbs got a bit better after a couple miles but the forks are awful. Time to clean carbs, install jet kit and full Area-P (wish it was race mount). Also going to start looking for fork springs and preload adjusters.
Old December 22nd, 2020, 08:04 PM   #8336
pjed
pjed's Avatar
Took the carbs off, cleaned them, installed a DJ jet kit and did the Kleen delete mod. Man, it sucks getting old...I installed the same jet kit on a new gen ten years ago and this time I was having a hard time seeing the notches on the needles.
Old December 27th, 2020, 05:34 PM   #8337
GAU-8
GAU-8's Avatar
Rather than a work related commute, I finally put about 100 miles in today. Felt a little off, being 50 miles away, and not on the bike for commuting..( or just putting along my 3 or 4 mile radius local ride)
I think this is slighly how a prisoner ( or military personel) feels, when released? . Almost didnt know what to do with my life.
Old December 29th, 2020, 11:08 AM   #8338
Ducati999
Looks great
Old December 29th, 2020, 05:29 PM   #8339
GAU-8
GAU-8's Avatar
I got some custom made stickers, in the same font/size, of a local Houston rider website, and some more, advertizing the MSF school I work for.
Now to get some ninjette.org stickers!
Old December 31st, 2020, 10:31 AM   #8340
GAU-8
GAU-8's Avatar
Rode to work. Happy rain day!
Old December 31st, 2020, 10:39 AM   #8341
Got Ninjette wet and muddy yesterday going to office. Rained slightly in morning with drizzle throughout day. Took northern route back past Sears Point Raceway because I know of a nice little dirt frontage-road that would be nice and slick after rains!
Spooned on some of these last week:
Old December 31st, 2020, 11:37 AM   #8342
GAU-8
GAU-8's Avatar
Got any dirty pics?
( I mean the bike )
Old December 31st, 2020, 02:15 PM   #8343
Heh, heh... all cleaned up for now!
I'll probably head back in next week.
Will get some dirty pics then!
Old December 31st, 2020, 05:28 PM   #8344
GAU-8
GAU-8's Avatar
Cool shot of the bay. How are the streets? To me they look like a commuters nightmare, by way of all the dense buildings.
Old January 1st, 2021, 07:21 PM   #8345
BigturboMax
BigturboMax's Avatar
Motorcycle(s): Fz07, ex250f
After getting all my panels back on finally, I set sag for my fat butt. Had to crank rear preload ring quite a bit and cut new spacers for the front forks. Started with 64/44mm sag front to rear. Ended up with 38/35mm sag front to rear. Seat height went from 29.3 to 29.9 inches. Way more comfortable for me to stand at 5'10. I already re-upholstered my seat...but I'll prolly go back into it and add some more foam. Still want a little bit higher seat. Will help with leg comfort. Got some different pegs in the mail right now without rubber tops. They should lower peg top about 1/4 inch, further improving seat to peg ratio.
BigturboMax is offline   Reply With Quote
Old January 1st, 2021, 08:09 PM   #8346
From afar; it does look quite dense. But on city-streets, there's enough room to maneuver. Worse things to watch out for are pedestrians/tourists and bus-drivers.
Here's video of me leaving office:
and one heading in...
https://www.youtube.com/watch?v=UhBqCN1VE8M#t=21m39s
Nice sunrise over Bay Bridge. You can see transition between new Bay Bridge and old double-decker Bay Bridge
Old January 1st, 2021, 08:50 PM   #8347
GAU-8
GAU-8's Avatar
Nice commute!
But I see your frustration with the pedestrians, and car dartings.
Old January 3rd, 2021, 11:50 AM   #8348
NinjaPony
New rider
NinjaPony's Avatar
This would be a late post. Yesterday I received an LED for my bike, friend came by with his Harley to hang out, I took the original halogen out for brighter light, looks nice. Also received Carburetors in the mail repaired from Ducatiman! I slapped em' back on and she was ready to go! The bike runs cleaner and has a beautiful idol. I had purchased wrong Jet sizes and didn't realize it. This is the man you go to for your Carburetor services, Thank you again!
Valve Maintenance is next..
Old January 3rd, 2021, 02:02 PM   #8349
Woohoo !! 🙌🏼 ducatiman saves the day again!!
Old January 3rd, 2021, 02:52 PM   #8350
just lucky I guess
and just for NinjaPony........
Old January 3rd, 2021, 04:43 PM   #8351
NinjaPony
New rider
NinjaPony's Avatar
HaHa nice Ty Ty, Happy New Year everyone!!
Old January 3rd, 2021, 05:40 PM   #8352
GAU-8
GAU-8's Avatar
fixed it for you.
The bike runs cleaner and IS a beautiful idol.
she is pretty
Unless you meant has a beautiful "idle".
Either way, both are looking good!
Old January 4th, 2021, 11:57 PM   #8353
NinjaPony
New rider
NinjaPony's Avatar
haha I didn't realize it, thank you sir! The Idle is the beauty.
Old January 17th, 2021, 03:41 PM   #8354
Moto-Kafe
Motorcycle(s): ex250, 500R, zrx, GPz1100, vstrom
Fire in the hole....!!!!
She turned over a "new leaf" today......new owner (me), 2 months of work done (I work at a very slow pace), and she fired right up.....!!!! She's a happy little teenager bike......
Moto-Kafe is offline   Reply With Quote
Old January 17th, 2021, 06:34 PM   #8355
GAU-8
GAU-8's Avatar
Lookin' real good!
Old February 5th, 2021, 08:46 AM   #8356
Topaz
Topaz's Avatar
Hello, I will be doing the brake upgrade on my N300 with SVRacing adapter plate for a CBR600 caliper and steel lines.
I already have the steel lines, Galfer.
For the caliper, I will try to get one from a CBR600. I think being the CBR very popular, I will have more options for pads, rebuild kits and getting a good condition caliper. I assume only the right side caliper works fine.
Will I be able to re use my banjo bolts?
Not sure yet if change the MC too. If I do, I was thinking in getting one from a ZX6R or ZX10R. I want to keep my bike street legal, so I will need the brake light switch. Hopefully MC's coming from those kawis will have the same connector for the switch?
Any other option? Not going to expensive stuff like brembo.
Anything else I will need? Any tips?
Old February 5th, 2021, 08:55 AM   #8357
Yes, you can re-use banjo-bolts.
Don't use MC from dual-brake system, you'll have 1/2 hydraulic leverage. Yes, lever will feel solid, but you'll have to squeeze it really hard. Twice as hard for same braking-force.
Old February 5th, 2021, 09:20 AM   #8358
Topaz
Topaz's Avatar
Thanks Danno! So I'd better keep the stock MC?
Old February 5th, 2021, 10:03 AM   #8359
yeah, stock MC should work fine. I need to calculate the MC-to-caliper ratios, looking at similar upgrade myself. Someone posted that 310mm rotor from some other bike that fits, gotta track that down
Old March 16th, 2021, 07:19 AM   #8360
Based12
Motorcycle(s): 2010 Kawasaki Ninja 250R,
Snapped a tool trying to loosen the camshaft guard bolts (heating, hammering, cooling, wd40 and even vice grips didnīt work at all, 8mm socket goes upward when applying force, already rounded 3 sockets) and the bit that snapped fell through the paper towel i put on the chain hole and got stuck between the chain and wall, couldnīt fish it with a magnetic finger so i gently pushed it down and it fell, so Iīm going to take out the clutch cover and look for it(after buying a third 8mm socket that is)
Based12 is offline   Reply With Quote
Except where otherwise noted, all site contents are Đ Copyright 2022 ninjette.org, All rights reserved.
