June 11th, 2013, 05:34 PM | #1 |
antiant
MOTM - Oct '14
Riding in the wind... help please.
Last Memorial weekend, I decided to take a small little ride out on the freeway. I did pretty good, but there were a few things that I definitely needed to practice on more. One of my major concerns, was coming back home. I was riding in the fast lane and the wind pushed me into the next lane. Thank goodness there was room for that, so I got sandwiched in between two cars, but I started thinking, "Oh ****, what if I wasn't that lucky and there was a car there?" It was not a windy day at all, just normal wind you would get with riding, I would imagine. Does anyone have any tips for this, so it doesn't happen again?
June 11th, 2013, 05:53 PM | #2 |
Overall you have to be loose on the bars. But.... you have to be fast on the draw to do what is needed to keep yourself in your own lane when a strong gust comes out of nowhere. And tuck down if needed, it helps too. Be weary of semi's and other large vehicles.
Now... prediction. There are clues if you read the cars/trucks ahead of you. They blow in the wind just the same. The trees will also give you warning. Watch with a wide view and you will know and the surprises will be somewhat minimized.
June 11th, 2013, 05:57 PM | #3 |
Que Buenos Son!!!
MOTM - Nov '14
If you're riding in a cross-wind, stick your leg out in the direction against the wind. It may look stupid but it helps.
Other than that just stay loose/relaxed, as you become more experienced wind will become less of an issue. On those really windy days you just gotta grin and bear it.
June 11th, 2013, 06:04 PM | #4 |
Fast-Guy wannabe
MOTM - Jan '13
Dude you have to read the waves.
Serious |
June 11th, 2013, 06:10 PM | #5 |
MOTM - Sep '14
If the wind is blowing harder then 25 mph I think it stops being fun on the freeway. The 300 is much better in the wind then the 250 IMHO
Like has been said already tucking helps a lot stay loose and be quick to lean into the wind. Also be aware that big rigs will block the wind. |
June 11th, 2013, 06:16 PM | #6 |
ninjette.org mafioso
Join Date: Jul 2012 Motorcycle(s): 2009 Ninja 250R Posts: 337
Hold on with legs and stay loose on the bars is the biggest thing for me. Tucking helps a lot too. I live in a windy high desert area and it's a pain.
June 11th, 2013, 06:53 PM | #7 |
MOTM - Jan '18, Sep '13
Basically saying the same thing everyone else has said: tuck and try to relax. If the wind isn't constant, try to anticipate when the gusts blow to lean into it, but don't tense up. Definitely agree that the 300 handles wind a little better than the 250.
June 11th, 2013, 07:12 PM | #8 |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Go faster after you hit about 150 the wind won't mater.
Hey Unregistered never go faster than your brakes can be applied... |
June 11th, 2013, 07:16 PM | #9 |
antiant
MOTM - Oct '14
Ha, thanks all. I did tuck eventually and that was much better, but hmm. I felt I was pretty relaxed, until that happened, then I semi-panicked, but controlled it sort of by tapping on both brakes and pulling in the clutch a little (so I didn't fly into the shoulder).
June 11th, 2013, 07:38 PM | #10 |
Its definitely something you need to get accustomed to. I know the first time I hit relatively mild winds, I was spooked but after riding there almost every day, it stopped being a problem.
June 11th, 2013, 07:57 PM | #11 |
Just react to the wind. On the 300, I'm constantly fighting the wind. The bike appears to be stable to others, but I can feel the way its being pushed in the wind. I've been riding in if I had to guess 25mph winds. Nothing major, but not just a little breeze. I had no issue staying in my lane. You just get used to it and make little adjustments with each wind blast. I actually recorded a video of the 300 on the highway, and it just so happens that that day was the windiest day I've ever been on the road. You'll get it with time.
June 11th, 2013, 08:02 PM | #12 | |
June 11th, 2013, 08:18 PM | #13 |
antiant
MOTM - Oct '14
@Aurodox - I actually saw your video awhile back and picked up a few things there for my own notes (I believe you're blipping the throttle? Etc). It was kind of funny because as soon as I got sandwiched in, I move over to the other lane and I'm like on the shoulder of the highway where the embankment meets. It felt like I was taming Bucephalus from Alexander...
Link to original page on YouTube. |
June 11th, 2013, 08:28 PM | #14 | |
Also, Does that happen to be I-5? Also, also, nice bike. Also x3, That was me attempting to blip the throttle, and it just so happens that I blipped it pretty flawlessly on video! I'm still working on it, and I have a success rate of probably 40%. The majority of the time I probably look like some guy who can't ride cause I try to blip but I give it a bit too much gas causing the bike to jerk forward. It's funny how with over a decade of riding I've never heard of blipping the throttle until I came to this site. Always learning something new! |
June 11th, 2013, 08:37 PM | #15 |
June 11th, 2013, 08:42 PM | #16 | |
antiant
MOTM - Oct '14
No, that's Hwy 168 (it takes you all the way up to Shaver Lake, Huntington Lake, etc). I picked this particular hwy because it's less crowded. I thought the blipping was done pretty smoothly on the video, so I was like "Ohhh that's how it's done, I see." I'm more of a visual person, so seeing things works better for me. I still have a long way to go with making my shifts go smoothly, as it's not that great. |
June 11th, 2013, 11:07 PM | #17 |
Certified looney toon
MOTM Jul '13, Jul '14
Out here, wind is a nightmare. I'm either riding into it or leaning deep into the crosswind.
To add to the rest of the good advice, I always keep an eye on the surrounding terrain. If no cars are around, the trees, bushes, grass, dirt etc will give you a heads up that a puff is coming or you should brace for something. (Comes from sailing a few times and learning to somewhat read the water to know if I have to hold on tighter to the lines so the jib or main sail wouldn't yank my arms off.) If a headwind, tuck down tight and ride it out. If a cross wind, I always try riding on the upwind side of the lane so I have room to be pushed over without worrying about crossing the line. If its a semi, move away and tuck in for a bumpy ride. It's interesting that the wind hit you from both sides. Was the wall causing the wind to come back and hit you from the left?
June 12th, 2013, 01:09 AM | #18 |
June 12th, 2013, 05:49 AM | #19 | ||
antiant
MOTM - Oct '14
June 12th, 2013, 06:10 AM | #20 |
MOTM - Sep '14
June 12th, 2013, 06:21 AM | #21 |
Don't underestimate the force that your body can generate when exposed to the wind. Tuck. It makes a HUGE difference... and not only in keeping the bike from wandering. It also gives you noticeably more available power for passing and boosts your fuel economy too.
Next time you're in your car stick your hand out the window, palm flat on to the wind. Imagine that force multiplied many times (difference in surface area between your hand and your torso, arms and head). Easy to see the rationale here.... From your description you had a pucker-factor moment and stiffened up. Exactly the wrong thing to do, because you just turned yourself into a big kite.
June 12th, 2013, 07:53 AM | #22 |
It comes up with all search methods, but the standard search sometimes brings back too much. This is mainly because it's looking through entire threads for some pretty common words. I tend to get better results by either using the Advanced Search choice, then choosing to search in Titles of threads only, rather than entire thread content. Searching for "Riding in the wind" in titles only comes up with a very small number of threads, that are all right on point. The Google option does a reasonable job most of the time as well. There are limitations to the Google search that it can't search any subforum area here that requires registration, so most of the Forum Info subforums aren't included in the Google search results, but would be included in the standard or advanced searches.
June 12th, 2013, 08:00 AM | #23 | |
As long as your contact patches are gripping, you have steering control to crab and compensate for that lateral force. As others have explained above, you need to be expecting those gusts in cross-wind conditions and need to be quick to reacting with determined and precise counter-steering. You need to be alert once you start seeing: "Large branches in motion. Whistling heard in overhead wires. Umbrella use becomes difficult. Empty plastic bins tip over." http://en.wikipedia.org/wiki/Beaufor...e#Modern_scale
June 12th, 2013, 08:14 AM | #24 |
Naw, Twain describes it better when one must be aware of the wind...
"Still, there were sights to be seen which were not wholly uninteresting to newcomers; for the vast dust-cloud was thickly freckled with things strange to the upper air - things living and dead, that flitted hither and thither, going and coming, appearing and disappearing among the rolling billows of dust - hats, chickens, and parasols sailing in the remote heavens; blankets, tin signs, sage-brush, and shingles a shade lower; door-mats and buffalo-robes lower still; shovels and coal-scuttles on the next grade; glass doors, cats, and little children on the next; disrupted lumber yards, light buggies, and wheelbarrows on the next; and down only thirty or forty feet above ground was a scurrying storm of emigrating roofs and vacant lots." -- Roughing It, Mark Twain
June 12th, 2013, 08:39 AM | #25 |
Jigglin' your Jiglets
MOTM - Apr '13
I don't notice a difference but maybe it's because I have a big ass 140 tire on my 250
June 12th, 2013, 08:48 AM | #26 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
June 12th, 2013, 08:51 AM | #27 |
Yep its all in the tire size
June 12th, 2013, 08:56 AM | #28 |
MOTM - Sep '14
June 12th, 2013, 09:02 AM | #29 |
MOTM - Apr '13
June 12th, 2013, 09:05 AM | #30 |
MOTM - Sep '14
June 12th, 2013, 09:10 AM | #31 |
Fast-Guy wannabe
MOTM - Jan '13
Try getting rid of your stock front tire and get a radial and you'll have more stability in the wind, corners, brakes and anywhere else you can think of. And if you decide to get rid of your OEM rear tire for something sportier I'd be more them willing to take it off you hands hell if you local ill even mount your new tire for free
June 12th, 2013, 09:59 AM | #32 | |
Join Date: Feb 2013 Motorcycle(s): 05 F4i.... Posts: 242
June 12th, 2013, 07:03 PM | #33 | |||
antiant
MOTM - Oct '14
June 12th, 2013, 10:47 PM | #34 | |
June 13th, 2013, 09:46 AM | #35 | |
June 13th, 2013, 10:18 AM | #36 | |
MOTM - Sep '14
June 13th, 2013, 10:22 AM | #37 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Is there any disadvantage to just putting pressure on the bars to crab into the wind? I suppose you can play around with weighting pegs or trying to body english the bike to lean into the wind but what is the advantage of that over simple, direct, and straightforward advice of just countersteering?
June 13th, 2013, 10:36 AM | #38 |
No, bar input is always going to be a part of it. Using the additional techniques, it feels to the rider that less bar input is necessary to keep the bike pointed where desired.
[motorcycle.com] - Riding in the Rain and Wind | Ninjette Newsbot | Motorcycling News | 0 | April 25th, 2013 02:50 PM |
[motorcycle.com] - Riding in the Rain and Wind | Ninjette Newsbot | Motorcycling News | 0 | April 14th, 2013 10:22 AM |
Riding in the wind | Viper-Byte | Riding Skills | 87 | October 28th, 2012 04:45 PM |
riding with the wind to your back | warmpudgy | General Motorcycling Discussion | 7 | October 18th, 2012 05:04 PM |
Looking for advice on riding in the wind...... | SpyderGirl | Riding Skills | 2 | June 30th, 2009 10:59 AM |
