Old April 23rd, 2014, 04:24 PM   #1
skip
skip's Avatar
Motorcycle(s): 2009 250r
advice: sprockets
Are car bon steel sprockets reliable also how many teeth should the sprockets be
skip is offline   Reply With Quote
Old April 23rd, 2014, 04:33 PM   #2
cuong-nutz
cuong-nutz's Avatar
Majority of sprockets are made of carbon steel unless of course you go with Aluminum.
Stock front sprocket is 14t and rear is 45t. Most folks get a 15t front sprocket to reduce overall rpms so the bike is not so buzzy from high cruising speeds.
HalfFast Racing Team
Old April 23rd, 2014, 05:36 PM   #3
carbon steel is good, but hydrogen steel is sooo much lighter!
Old April 23rd, 2014, 05:42 PM   #4
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
So is car born dioxide.
Old April 23rd, 2014, 05:44 PM   #5
skip
skip's Avatar
How about a good chain and what's the length.if I go 15 on the front sprocket do I have to go bigger or smaller on the rear sprocket
Old April 23rd, 2014, 05:45 PM   #6
D.I.D. makes good chains. about the length, i'd say about 3 feet or so.
Old April 24th, 2014, 11:49 AM   #7
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
Stock is 106 links. It will fit 15/45 setup.
broilmebk is offline   Reply With Quote
Old April 24th, 2014, 01:43 PM   #8
skip
skip's Avatar
So if I go 15t front sprocket what do I go for rear sprocket
Old April 24th, 2014, 01:46 PM   #9
Many people leave the rear at 45 teeth, and only change the front from 14 to the 15. Some people have gone for taller gearing by using a few less teeth on the rear, but it's not as common.
Old April 24th, 2014, 01:47 PM   #10
skip
skip's Avatar
chain
Dies any one have trouble adjusting da chain every time I loosen da axle the bracket with the marks moves how do I get it adjusted properly
Old April 24th, 2014, 01:50 PM   #11
skip
skip's Avatar
Originally Posted by Alex View Post
Many people leave the rear at 45 teeth, and only change the front from 14 to the 15. Some people have gone for even taller gearing by using a few less teeth on the rear, but it's not as common.
Thank you very much which would you recommend for the front 14 or 15t
Old April 24th, 2014, 01:51 PM   #12
Make sure to check out the sticky thread at the top of the tech section:
Directory of all 250R DIY threads on Ninjette.org
There's a pretty decent chain adjustment / wheel alignment thread there:
DIY- Chain Adjustment and Rear Wheel Alignment
The pics are borked in the first few posts, but if you scroll down there are more pics and instructions to clarify if things are fuzzy about the first post.
Old April 24th, 2014, 01:52 PM   #13
I'd probably go with a 15 if I was changing the sprocket out. I wouldn't change a perfectly functioning 14 out for a 15 for the performance difference, but if it was worn and I needed a new one anyway I'd likely go with the 15.
Old April 24th, 2014, 03:45 PM   #14
broilmebk
broilmebk's Avatar
I went down to 44 in the rear.
15/44 vs 15/45
I find the 15x44 is a good compromise, and it's perfect for 70-80mph riding. I have 2 bikes - One is 15x45 and the other 15x44. The 15x45 is (very marginally) quicker through the gears, pulls harder in top gear at terminal speed / has a higher top speed, but the trade-off is higher rpm on the highway. Either works just fine for me. I run the higher gear on the bike which I use for touring. However, I've also done local club rides (all 600cc+) in the twisties using the 15x44 bike and had no problems whatsoever (the trick to club rides on an underpowered bike is to stay as close to the front as possible to avoid the inchworm effect).
That thing is useless.
Old April 24th, 2014, 05:31 PM   #15
stubshaft
Rode with the Dinosaurs..
stubshaft's Avatar
Motorcycle(s): '08 Ninja 250
15/43 worked for me and I can use the stock chain.
Fortune favors the brave!
stubshaft is offline   Reply With Quote
Old April 28th, 2014, 07:41 PM   #16
skip
skip's Avatar
If I go 15 do I keep the rear sprocket 45 and will the stock chain fit and will this raise my mpg
Old April 28th, 2014, 08:02 PM   #17
skip
skip's Avatar
Cool advice
Will A 15t Sprocket And A Rear 45t Raise My mpg AAnd what Chain Will fit
Old April 28th, 2014, 08:42 PM   #18
The stock 106 link chain will fit and will it give you some mpg? Maybe or maybe not, depends on your wrist. Some riders have reported an increase, I myself... didn't notice squat.
sprockets jcsalazar 2008 - 2012 Ninja 250R Tech Talk 10 July 29th, 2013 03:57 PM
Where to get sprockets? Graugaard 2008 - 2012 Ninja 250R Tech Talk 8 February 21st, 2013 07:38 PM
Sprockets, sprockets, ahhh sprockets?!?! shelei09 General Motorcycling Discussion 10 January 23rd, 2013 09:47 PM
how do my sprockets look reaperw 2008 - 2012 Ninja 250R Tech Talk 4 December 29th, 2011 10:20 AM
Right Sprockets? billybobjoeiv 1986 - 2007 Ninja 250R Tech Talk 10 May 30th, 2010 04:59 PM
