Old August 19th, 2014, 06:57 AM   #1
Kags1969
Motorcycle(s): 2007 Ninja 250r / 2012 Honda VT750 Phantom
Best method to break off stock 250 clutch perch
I just purchased a 2006 Ninja with about 7800. I want to put on the EX500 adjustable clutch and perch, but dont want to pull off the bar ends and grips. The FAQ mentions that people just break off the stock clutch perch, what is the best method to do this?
I am thinking about using a dremmel cutoff wheel and scoring the perch then using a screwdriver make the break.
Just looking for some input from someone who has done it successfully.
Kags
Kags1969 is offline   Reply With Quote
Old August 19th, 2014, 08:06 AM   #2
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
score, chisel, hammer
Old August 19th, 2014, 10:37 AM   #3
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Why not take off the grips an bar ends? It takes just a few minutes and it's easy as cake, or pie, or whichever.
Use heat (propane plumber's torch, soldering iron, etc) on the screws to soften the locktite and the screws come right out. Use compressed air through a nozzle to blow under the grip and it slides right off in one second. Installation of the grips with air is just as easy, just blow air between the rubber and the bar and zip, the grips back on.
I run foam grips to eliminate vibration and the weather kills them in a year or so, it takes me just about 5 minutes to change both sides out.
Old August 19th, 2014, 02:49 PM   #4
Ninjinsky
Ninjinsky's Avatar
Best to break it.
That way you can be sure it can't be sold to someone who needs one.
Old August 19th, 2014, 02:51 PM   #5
I know it takes a bit of time, but take it off and save it. If you ever need one, you got it in stock.
Is the stock clutch lever compatible with the ex500 clutch perch? M42 1986 - 2007 Ninja 250R Tech Talk 5 August 21st, 2014 08:24 PM
Dyno Results: Stock 300 vs. Stock 250 vs. Race 250 gt_turbo 2013 - 2017 Ninja 300 General Discussion 26 October 8th, 2012 10:03 PM
Brake/Clutch lever perch bolts Shaol1n Monk Motorcycle-related 0 January 31st, 2012 03:09 PM
