Old April 26th, 2012, 06:07 PM   #1
Boomstick1491
Name: Carlos Spicy Wiener
Motorcycle(s): Too many
Gearshift Lever Sticking on Upshifts
Within the last week, my bike's gearshift lever has started "sticking" during some upshifts. It seemed to only happen when shifting from 2nd into 3rd, but as of this afternoon, it seems to happen in other gears as well (however, peculiar as it may be, this does not happen from 1st to 2nd). Also, I have never had a problem downshifting. Does anyone have any thoughts on what this could be? I read a post that seemed to indicate that changing the oil might help this, but I thought I would get your opinions before I do that.
Before you ask, I have not changed the oil since I picked up the bike a month (~600 miles) ago and I am not 100% sure when the P.O. changed it. It's probably time, but could this really be the reason I am having some trouble getting the gearshift lever to move during upshifts?
Boomstick1491 is offline   Reply With Quote
Old April 26th, 2012, 07:07 PM   #2
How bout when not moving? Put it on a stand and use your hand to run through the gears. Compare how they feel that way.
Changing the oil can stop shifting stickiness, smooth it out and relieve stiffness in the shifter but other times it's just a placebo effect. Lube the shifter linkages as well as change the oil so you know what it's NOT. Adjust the linkage to your boot while your at it. It's cheap and super easy.
I am sure you will get a lazy shifting comment too. Cause it's easy to get lazy.
Let us know how it goes.
Old April 26th, 2012, 08:57 PM   #3
chikenstrips
chikenstrips's Avatar
Motorcycle(s): ninja 250r
is it sticking on the way up or is it sticking up and not coming down easily? could be a shifter mechanism return spring issue
chikenstrips is offline   Reply With Quote
Old April 26th, 2012, 09:41 PM   #4
vkuchhal
vkuchhal's Avatar
Motorcycle(s): ninja 250r -2010
What shift linkages are you talking about..?
and how to clean them.. using diesel or what..
I also have a similar kind of problem when up shifting but it is not always that this happens...
vkuchhal is offline   Reply With Quote
Old April 27th, 2012, 03:19 AM   #5
Boomstick1491
To clarify, I will pull in the clutch and raise my toe to change gears, but the lever seems stuck and so when I let out the clutch, I find I'm in the same old gear. I then try again and it works fine. Does that help explain the problem better?
Old April 27th, 2012, 04:53 AM   #6
Lube all moving parts shown in the picture below. I don't know the history of your bike but if its been down before a part can be bent or scratched causing it to catch/bind.
Oh, check your clutch cable too.
Old April 27th, 2012, 02:50 PM   #7
Boomstick1491
Thanks very much for the annotated picture. That's very helpful. Since we've already established that I am a noob and 2/3 a retard (see prior posts), with what do I lube these components? KY? Cristo? Spit? Thanks for the help.
Old April 27th, 2012, 02:52 PM   #8
Boomstick1491
And yes the bike went down on that side (again, see prior post). I don't think anything was damaged there though. And besides this is a newish phenomenon, whereas the dump happened 1.5 months ago or so.
Old April 27th, 2012, 03:29 PM   #9
I like to use molly grease (around $3) on stuff like this. Other riders may use other products.
Old April 27th, 2012, 03:38 PM   #10
Oh! it can come in a tube too, like toothpaste.
Old April 28th, 2012, 04:20 AM   #11
Boomstick1491
Where can one buy this undoubtedly-delicious flavored toothpaste? My bike's oral hygiene is lacking.
Old April 28th, 2012, 08:05 AM   #12
I got mine at home depot. Try there or lowes, maybe your local hardware store too.
[crash.net - MotoGP] - Full seamless upshifts for Tech 3 Ninjette Newsbot Motorcycling News 0 February 7th, 2015 12:10 AM
Carb sticking 102dalz 2008 - 2012 Ninja 250R Tech Talk 3 November 2nd, 2014 02:37 PM
Front Brake is sticking...Help! skilletmo 2008 - 2012 Ninja 250R Tech Talk 19 October 25th, 2014 05:30 PM
Throttle sticking, need help WiffleBiscuit 2008 - 2012 Ninja 250R Tech Talk 4 September 1st, 2014 05:11 PM
2010 throttle sticking? wtfh4xx 2008 - 2012 Ninja 250R Tech Talk 5 June 1st, 2011 01:14 PM
