May 2nd, 2013, 12:34 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2010 250r SE (without stupid tribal decals) Posts: 110
No idea how to install LED turn signals
So, I've bought the Diode kit and a new Triton EP34 relay, but I'm stuck at the wiring part. I've already removed the stock turn signals so now there's just the black/yellow and green wires hanging off my bike. I bought two pairs of LEDs, one that has a blue wire and green wire (for the rear), and one that has a black wire and a yellow wire (for the front). Also they have a round connection point instead of the square kind on the stock ones. If some one could tell me were to plug in what and how that would be great.
These were the ones I bought: http://www.ebay.com/itm/Universal-Fi...51030740657%26 http://www.ebay.com/itm/Vader-LED-Mo...00854776399%26 Last futzed with by ChickenRun; May 2nd, 2013 at 12:56 PM. Reason: hit enter by accident, derp. |
May 2nd, 2013, 01:01 PM | #2 | |
Join Date: Dec 2012 Motorcycle(s): 2008 Ninja 250R Posts: 263
Triton EP34: You'll need to wire a grounder to the frame. Turn Signals: First you'll need to figure out which wire belongs where. Just plug in the wires into the connector and test out the signal. Nothing comes on? Switch the wires around. As for getting the right connectors and stuff, just use the wire and connector from the stock signals. Connect your LED wires to the stock wiring and wrap it with electrical tape. Then connect the oem connector to the oem female. If you can get us some pictures of the LED wiring, we can help you get the right connectors for a cleaner setup. But for now, thats what I would do. |
May 2nd, 2013, 01:06 PM | #3 |
I've already installed the Diode kit and relay, here are what the LED wire ends look like.
May 2nd, 2013, 01:51 PM | #4 |
How to install LED front turn signals & relay | CThunder-blue | 2008 - 2012 Ninja 250R Farkles | 56 | August 17th, 2014 02:31 PM |
LED's! (footpeg turn signals, brake light strips, front signals oh my!) | VeX | 2008 - 2012 Ninja 250R Farkles | 16 | June 29th, 2012 12:03 AM |
Are new aftermarket turn signals hard to install? | pucktoplay1 | 2008 - 2012 Ninja 250R Farkles | 13 | June 14th, 2011 09:12 PM |
Are new aftermarket turn signals hard to install? | pucktoplay1 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 8th, 2011 08:29 PM |
