Old July 8th, 2013, 10:40 AM   #1
ubxssangz
2009 ninja 250r engine ticking & knocking noise
HI all,
Thank goodness for this forum.
I have a 2009 NINJA 250R, 6K miles, no modifications. I hope to give you as much details as possible.
Service History:
Got the bike used at about 4000 miles.
Flushed and replaced the coolant at about 4500 miles. After i passed the 5500 miles i noticed that i kept on loosing coolant and the heat signal kept on coming on when riding in low speeds . I kept on re-filling the reserve coolant tank up to that point then learned that i had to fill it from the filler neck, which was a little low in coolant. After that i have no problems with the bike heating up.
I have recently used seafoam on the gas tank for the last 2 consecutive fills(6 oz of seafoam with 3 gallons of gasoline).
I have also used seafoam right before an oil change 4 oz of seafoam and rode for about 75 miles. Again, i have used seafoam on the engine oil after the oil change, 4 oz of seafoam and rode for about 150 miles with new oil, then the sound started. Lastly, in order to cancel out problem, after this incident i changed the oil again and have not ridden the bike yet.
I have replaced both, front and rear break fluids 1 week before this noise.
Here is the Story.
I was riding on the highway doing about 90 mph on 90 degrees weather, when all of the sudden i felt that i was losing power followed by a LOUD knocking sound, i pulled the clutch (then the noise stopped when clutch is pulled in) and pulled over. I started the bike again and the knocking sound is there when idled.
I started riding the bike again, yes even with the noise and all the way home for about 25 miles. Both light came on (engine & heat) and when i accelerate both lights turn off. For the first 10 miles i was doing 50-55 mph then the noise started getting louder and it actually died on me then i pulled over again when at that point the bike would not start. I press the ignition switch but it would not start. After about 10 minutes it started again so i rode for another 5 miles and the bike died on me again and it wouldn't start. Let it sit for another 10 minutes and it started again and managed to get home. I changed the oil and filter and have not ridden the bike because the ticking and knocking sound are still there.
Please Help. Here is a link if you want to hear what it sounds like. The garage is closed when i took this video.
http://www.youtube.com/watch?v=bkd37R95wHk
Thanks for the help guys.
Last futzed with by ubxssangz; July 8th, 2013 at 02:01 PM.
ubxssangz is offline   Reply With Quote
Old July 8th, 2013, 10:49 AM   #2
oh dear.... that sounds of bearings.
Old July 8th, 2013, 11:19 AM   #3
cuong-nutz
cuong-nutz's Avatar
Sounds like you have one of the spark plug boots disconnected and arching with one cylinder running.
You know you're not suppose to put seafoam in the oil unless you're trying to clean out the internals and replacing the oil soon afterwards. Seafoam will thin the oil out and you can kiss goodbye to your motor.
I'd check to make sure your oil isn't milky and sludged if you didn't know where your coolant is going.
HalfFast Racing Team
Old July 8th, 2013, 12:14 PM   #4
ubxssangz
I have bought new sparkplugs but i am now missing the stupid spark plug wrench. Have to buy one at a local hardware store. I am also hearing something about the cam chaim???
So, right now i have 2 options:
1) spark plugs.
2) cam chain.
When i replaced the engine oil there wasn't any milky liquid coming out. However, there was milky thick oil on the crankcase/motor oil reservoir.
I also would like to know if you guys are refering to the thicking or knocking noise.
Old July 8th, 2013, 12:30 PM   #5
modded
Motorcycle(s): 2012 Green 250
1) spark plugs.
2) cam chain.
How much Seafoam did you add to your oil?
modded is offline   Reply With Quote
Old July 8th, 2013, 01:06 PM   #6
DaBlue1
Long Time Rider
DaBlue1's Avatar
Like mentioned before, there is really no need for Seafoam or engine flush in a motorcycle engine, especially one with very little mileage like your. That type of treatment is usually reserved for engine that have been sitting for years and the oil has started to turn to a tar like goop. Using Seafoam lowers/thins the viscosity of the oil.
From the sound of you video, it sounds as if you only have one cylinder firing and a spark plug that's loose/broken and arcing.
Do you have any signs of colored smoke coming out of your exhaust?
There's over a dozen things that can be wrong at this point. I'd start with the basics (fuel, plugs, air filter, carbs, battery, loose connections, etc ), then look into other stuff.
Here are a few things that could possibly be the cause of your issues.
Poor Running at Low Speed:
Spark weak:
Battery voltage low
Spark plug dirty, broken, or maladjusted
Spark plug cap or high tension wiring trouble
Spark plug cap shorted or not in good contact
Spark plug incorrect
IC ignitor trouble (a bad one can cause timing and firing issues)
Crankshaft sensor trouble
Ignition coil trouble
Compression low:
Spark plug loose
Cylinder head not sufficiently tightened
No valve clearance
Cylinder, piston worn
Piston ring bad (worn, weak, broken, or sticking)
Piston ring/groove clearance excessive
Cylinder head warped
Cylinder head gasket damaged
Valve spring broken or weak
Valve not seating properly (valve bent, worn, or carbon accumulation on the seating surface)
Look at the Troubleshooting Guide for more potential causes
Old July 8th, 2013, 01:44 PM   #7
ubxssangz
i used 4 oz of seafoam in the engine oil.
I will try to change the sparkplug today and see what happens.
I also forgot to mention, if it means anythng, that as the sound started both lights (engine & heat) cam on and when i press on the accelerator they go off.
Old July 8th, 2013, 04:25 PM   #8
DaBlue1
Long Time Rider
DaBlue1's Avatar
.... the sound started both lights (engine & heat) came on and when i press on the accelerator they go off.
The engine temp/oil pressure light will come on;
1. at start up then turn off within a few seconds of running
2. when the oil pressure is too low ( too low idle speed can cause low oil pressure as well as a bad oil pump)
3. engine oil level is too low
4. engine oil poor quality or incorrect
5. overheating
Old July 8th, 2013, 07:21 PM   #9
ubxssangz
5. overheating
You think is because of leaving the seafoam to reach 150 miles?
I was trying to change the spark plug and one of the end is different on the new one. Take a look at the picture, what should I do?
Argggg, nothing is going right
Old July 8th, 2013, 07:42 PM   #10
cuong-nutz
cuong-nutz's Avatar
Change the oil and DO NOT put sea foam in. Make sure you are using motorcycle specific engine oil.
The spark plug at the bottom of your picture needs the end to be unscrewed to match the one just above it. Motorcycles don't need the end or else the boot what snap onto the plug when installing.
Old July 8th, 2013, 08:20 PM   #11
ubxssangz
I went with my instincts and yes I unscrewed the end and changed the spark plugs, nothing changed. I have also changed the oil, Am I supposed to let the bike run for a while after the oil change for the ticking to hopefully go away? WTFFFFFF
Old July 9th, 2013, 06:06 AM   #12
cuong-nutz
cuong-nutz's Avatar
Did you notice any metal flakes or sediment in any of your oil changes? Does the motor still sound the same since you changed the oil? Is the bike still making power or is it even slower/weaker than prior to power loss? Do a compression test and see what numbers you are getting in each cylinder.
If it's still ticking that loud, than that's not good. Sounds like bearing damage.
Try disconnected one of the spark plug wires while it's running and note any changes in each cylinder. Don't shock yourself too.
Old July 9th, 2013, 06:24 AM   #13
DaBlue1
Long Time Rider
DaBlue1's Avatar
.... I have also changed the oil,
....If it's still ticking that loud, than that's not good. Sounds like bearing damage.
A good place to check to make sure you have evidence of bearing damage, is the oil screen. You probably should have checked there before changing the oil.
Also do not rule out anything in the trouble shooting guide until you have inspected or tested it. Also from what you describe ("...i pulled the clutch (then the noise stopped when clutch is pulled in"), you may just want to have a look at your clutch also.
If you are not too mechanically savvy, have a pro troubleshoot and fix it for you may be your next step.
Old July 9th, 2013, 07:24 AM   #14
ubxssangz
I did not notice any metal particles in the oil. When you say oil screen do you mean the oil filter?
Old July 9th, 2013, 07:59 AM   #15
DaBlue1
Long Time Rider
DaBlue1's Avatar
.... When you say oil screen do you mean the oil filter?
This....
You are looking for metal flakes (brassy or silver looking
...To rule out possibly of this or worse...
Old July 9th, 2013, 01:35 PM   #16
ubxssangz
This....
GREAT PICTURE, Thanks!!
Now what if i have particles and what if i do not see any particles?
Old July 9th, 2013, 01:41 PM   #17
DaBlue1
Long Time Rider
DaBlue1's Avatar
Metal flakes are a good indicator of internal engine damage. If you don't see any that may be a good sign.
Old July 10th, 2013, 07:16 PM   #18
ubxssangz
Had the time today to take out the oil screen and look what i found.
F********ck. what now? Don't even know wtf these parts are?
btw, i left both oil filter and oil screen opening open. Is it ok?
http://youtu.be/UO9Fsuv8S1E
Old July 11th, 2013, 08:16 AM   #19
DaBlue1
Long Time Rider
DaBlue1's Avatar
Not good.
Definitely some internal damage. Maybe cam journals, piston chunk? IDK.
The only thing to do now is open up the engine case and see for sure. Looks like the shop for you.
You can temporarily stuff a rag in the oil filter port or put the screen and cover back on. At this point there's no need to put oil back in it till it's fixed.
Good luck
Old July 11th, 2013, 08:21 AM   #20
LR1914
LR1914's Avatar
What the....
That's a lot more than flakes....
Wow.
LR1914 is offline   Reply With Quote
Old July 11th, 2013, 09:04 AM   #21
ubxssangz
Originally Posted by LR1914 View Post
What the....
Wow.
Alright guys, Thanks for all the help. Will update once i know what really happened.
Old July 11th, 2013, 05:02 PM   #22
ubxssangz
Not good.
Good luck
Any of you know around how much or how many hours it will take to repair?
Old July 12th, 2013, 02:57 AM   #23
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
Don't know about cost, but looks like you will be up for pistons. Hopefully the crank is still ok.
baxtc1 is offline   Reply With Quote
Old July 12th, 2013, 05:39 AM   #24
ubxssangz
Not good.
Good luck
Here is a look at the engine from the oil screen opening.
Is that rust? Should i do anything to it? spray seafoam?
http://youtu.be/aMd6W_BESo8
Old July 12th, 2013, 06:11 AM   #25
parox91
Name: Not Applicable
Motorcycle(s): 2007 Blue Ninja 250
I used to have a ticking sound but after it got really bad I reset my cam chain tensioner and the sound went away... you might've skipped a tooth or something from the cam chain slipping... I would take it to a shop, might charge you a couple hundred or more
parox91 is offline   Reply With Quote
Old July 12th, 2013, 07:10 AM   #26
ubxssangz
How do you reset the cct on a 2009 ninja 250
Old July 12th, 2013, 07:36 AM   #27
parox91
i have a pre-gen, sorry but the procedure should be similar at the least
you have to take off the right side fairing and then follow these directions:
http://faq.ninja250.org/wiki/Cam_cha...sioner_removal
also read the 4th post in this thread: http://www.ninjette.org/forums/showthread.php?t=50930
if your bike already lost overall power you may have skipped a tooth... take it to a shop and hope for the best
Old July 12th, 2013, 07:40 AM   #28
DaBlue1
Long Time Rider
DaBlue1's Avatar
Here is a look at the engine from the oil screen opening. Is that rust? Should i do anything to it? spray seafoam?
Keep some oil in it.
DIY: Cam Chain tensioner rebuild
Not sure why you are concerned about it. You've got bigger problems. The cam chain tensioner will be fixed when the engine is rebuilt as well as any other internal issue.
Old July 12th, 2013, 07:48 AM   #29
parox91
^ this. I just watched the video, you might be better off buying a used motor lol
Old July 12th, 2013, 08:06 AM   #30
ubxssangz
Not really concerned about it, but wanted to know just in case it happens in the future and mess around with it and see if that was the problem for the ticking before i take it to the shop.
Old July 12th, 2013, 08:08 AM   #31
ubxssangz
Are you refering to the oil screen video with the 2 chunks of metal?
Old July 12th, 2013, 08:08 AM   #32
cuong-nutz
cuong-nutz's Avatar
You're better off with a good used motor. Not worth the effort, time, and money to rebuild it and it will end up costing you more. That's rust you see and it looks like water had gotten into the engine where it sat for a while.
Old July 12th, 2013, 08:13 AM   #33
ubxssangz
How many labor hours to put this remove old motor + install new motor?
Old July 12th, 2013, 08:51 AM   #34
parox91
The thought of having rust in my engine makes my stomach turn...
Old July 12th, 2013, 08:57 AM   #35
4 for a talented wrench turner. I did it in about 7ish while taking many pics, looking up stuff, having a few brews and basically enjoying some free time in the garage with the son.
An engine swap is easy, just take pics of everything along the way. Some tape and a marker go a long way to label questionable hoes, bolts and what not. Just stick the tape on and write down what it goes to.
Good luck!
Old July 12th, 2013, 08:58 AM   #36
cuong-nutz
cuong-nutz's Avatar
You're looking at least 3 hours.
I guess my estimation is very optimistic lol
Old July 12th, 2013, 06:47 PM   #37
keeblerkhan
Motorcycle(s): 250J
...anybody notice that this guy used water from a hose to clean his sight glass? I'm thinking he didn't remove the clutch cover before doing that. It would explain the rust and the motor generally hating life.
http://www.ninjette.org/forums/showthread.php?t=139312
When a motor sits for a long time it is possible for water (generally condensation) to collect in it. However, the water usually ends up at the very bottom of things since oil floats. It is usually also only a small amount of water that collects. I'm thinking UBX filled his motor with a substantial amount of water to get rust that high up in the transmission.
keeblerkhan is offline   Reply With Quote
Old July 12th, 2013, 08:51 PM   #38
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
also,
PUT THE SEAFOAM DOWN.....
that is all
Asspire is offline   Reply With Quote
Old July 13th, 2013, 08:44 AM   #39
ubxssangz
Any of you know of a good place where to get a reliable used motor near fort lee, nj?
Old July 13th, 2013, 08:46 AM   #40
ubxssangz
Relax bro, I answered a sarcastic comment with a sarcastic reply.
ticking noise jcsalazar 2008 - 2012 Ninja 250R Tech Talk 5 October 29th, 2014 12:24 PM
Engine knocking noise vinnyirl 2008 - 2012 Ninja 250R Tech Talk 11 March 8th, 2013 12:33 PM
Engine Knocking Noise (w/Video) simmr 1986 - 2007 Ninja 250R Tech Talk 16 July 30th, 2012 01:48 PM
Weird knocking noise... blink 2008 - 2012 Ninja 250R Tech Talk 6 July 3rd, 2012 12:24 PM
knocking or rattling noise tinng321 2008 - 2012 Ninja 250R Tech Talk 12 May 31st, 2009 09:51 AM
