April 3rd, 2013, 04:13 PM | #201 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
Why not just leave the stand down, even if its on stands...?
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound |
April 3rd, 2013, 04:21 PM | #202 |
Because then I'll bark my shins on it over the winter. The bike lives in my workshop.
Just one more thing I don't have to think about months after the fact.
April 3rd, 2013, 09:11 PM | #203 |
OK - 3-letter searching works at this point. People can search on "oil" to their heart's content; the problem is it will bring up a million threads.
April 4th, 2013, 06:44 PM | #204 | |
Join Date: Apr 2012 Motorcycle(s): Ninja 250r Posts: 228
They recommended mobile 1 full synthetic and they also had a Honda full synthetic (i did not catch the name). I use the honda GN4 (i think thats it - regular conventional oil currently). I know these oil debates can go on forever and i know remember what you said earlier something along the lines of if your woried about it stick with OEM cause that wont hurt the engine - but i still need some light shed. Disel engine oil is fine for our wet clutch without those JASo and other ratings? Just want to make sure I am not one ruining the bike in anyway shape or form for long term effects and two decreasing performance.
www.SafetyPaws.org |
April 12th, 2013, 02:18 PM | #205 |
Join Date: Apr 2013 Motorcycle(s): 2009 ninja 250 Posts: 15
Synthetic oil?
I just bought a ninja 2009! And I want to switch it to synthetic as of not its conventional. It has about 6300 miles! Please help me in which one should I choose! And what brand and number. I am a newbie. Thank you
April 12th, 2013, 02:22 PM | #206 |
April 12th, 2013, 02:24 PM | #207 |
Que Buenos Son!!!
MOTM - Nov '14
This is what I, and a lot of members here use.
Once I started using this oil I never looked back. I use it in both my bikes and my truck.
April 12th, 2013, 02:24 PM | #208 |
Mobile 1 racingt
Can I use the mobil 1 racing 4t 10w-40? Which one is better?
April 12th, 2013, 02:27 PM | #209 |
Neither here nor there on which is better. However there is huge difference in price.
April 12th, 2013, 02:28 PM | #210 |
Que Buenos Son!!!
MOTM - Nov '14
You can, but for me the extra cost isn't justified. Motorcycle specific oils are mainly used because of the wet clutch on our bikes. Some oils can cause clutch slippage.
Shell Rotella T6 causes no problems with the clutch. It's used by a lot of bikers, not just members here.
April 12th, 2013, 02:40 PM | #211 |
Oh okay thank you! One question, after I drain the old oil out and put in the new synthetic oil! What should I do! Is their a specific way I should ride the bike? Like at high revs? Or keep them low?
April 12th, 2013, 02:46 PM | #212 |
Nope, just ride as you normally would. Some have done oil changes right before track time others just before their normal commute, the result is the 99% the same.
April 12th, 2013, 02:57 PM | #213 |
there's no break-in procedure for oil. Just wait for it to get up to temp then ride like you always do.
Remember: no matter what oil you choose, the most important part is to change regularly and change often. Your bike will thank you. |
April 12th, 2013, 03:27 PM | #215 |
Que Buenos Son!!!
MOTM - Nov '14
There are a lot of myths when it comes to oil, and that's what most of them are "myths".
I found the Mobil 1 faq site to have a lot of useful knowledge. I discovered it after a friend and I were having a heated discussion about "ZDDP".
April 12th, 2013, 04:09 PM | #216 |
Okay thank you! And is it necessary to change the filter also? If so what number should I get? As of now a k and n is installed
April 12th, 2013, 04:13 PM | #217 |
Que Buenos Son!!!
MOTM - Nov '14
Might not be necessary to change the filter, but since they only cost a few bucks there's no reason not to.
I just buy fram filters for my bike. I can get them at most local auto parts stores. Advance Auto Parts is usually where I get them.
April 12th, 2013, 04:23 PM | #218 |
/merged with similar "which synth oil?" thread
April 12th, 2013, 05:01 PM | #219 |
is there a specific size that I should buy? Or are they the same?
April 12th, 2013, 05:10 PM | #220 |
Que Buenos Son!!!
MOTM - Nov '14
Fram: CH6012 But that's for the pre-gen. I dunno if the one for the new bike is the same or not.
Alternatively if you have a local stealership close buy you can get one from there. That's what I did until I learned I could use the Fram one. The Kawasaki on wasn't much more expensive though, plus you would know for sure that it would fit.
April 12th, 2013, 05:57 PM | #221 |
/merged a couple more "which synth oil" threads
April 12th, 2013, 07:05 PM | #222 |
Join Date: Aug 2012 Motorcycle(s): 2012 kawasaki ninja 250r special edition Posts: 255
i personally like amsoil 10w 40 synthetic
April 13th, 2013, 11:12 AM | #223 |
Join Date: Jan 2011 Motorcycle(s): (08 Ninja 250) (07 Suzuki Hayabusa) (08 Suzuki GSXR 1000) (Yamaha dirtbikes) Posts: 33
My local auto stores sells Mobile 1 MC synthetic 10-40 for $8 cheaper per quart.
I have always used Mobile1. I like it. Oil comes out still looking good after 3,000 - 5,000 miles. I change it yearly regardless of miles. I always change the filter as well regardless of miles. |
April 13th, 2013, 11:21 AM | #224 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
You can't judge if an oil is still "good" solely by how it looks.
An oil analysis would provide information in how the engine is wearing and the overall condition of the oil and its protective qualities. |
April 13th, 2013, 11:23 AM | #225 | |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
My bikes use a bike oil made to work for both, which is why I use castrol synthetic 4T oil. Just want make sure someone doesn't misread what you are saying and ruins the bikes clutches.
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
April 13th, 2013, 11:41 AM | #226 |
Que Buenos Son!!!
MOTM - Nov '14
Engine oil for cars is not going to ruin your bikes clutch. It's just not.
April 13th, 2013, 12:29 PM | #227 |
So you mean we are all wrong ? And we should re-write the ninjette wikis?
April 13th, 2013, 01:12 PM | #228 |
Que Buenos Son!!!
MOTM - Nov '14
Show me where it says on a bottle of Shell Rotella T6 that it's made for motorcycles. It's not, it's made for diesel trucks. Yet it's what many members here and on other moto forums use.
I haven't read the wiki here, because the one at n250rc is much better, but I'm guessing it says not to use energy conserving oils because they can cause clutch slippage. You can believe what you want though, and keep spending $10 for a quart of oil while I spend less than $22 for 5 quarts.
April 13th, 2013, 01:21 PM | #229 | |
Join Date: Jan 2013 Motorcycle(s): 03' Ninja 250ex Posts: 333
If the API label says energy conserving it will make your clutch slip. |
April 13th, 2013, 01:51 PM | #230 | |
Bass Master General
Some engine oil has to deal with higher compressions, higher temperatures and greater frictions, motorbikes and diesel engines share the shame conditions, hence why rotella t whatever is often used in bikes. Only exception would be two stroke oil. |
April 13th, 2013, 02:41 PM | #231 |
So, where's the reverse?
Around here, the bottles of Rotella T6 states that it meets JASO MA requirements right on the label. Guess it's riding season again once these oil threads start popping up on the regular
April 13th, 2013, 04:43 PM | #232 |
Apparently riding season needs to start soon before these divas need a snickers bar....
April 13th, 2013, 08:21 PM | #233 |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
In Aussie for shell motorcycle oil
Shell Advance Ultra - 10w40 or 15w50 - full synthetic Shell Advance AX7 - 10w40 or 15w50 - semi synthetic Shell Advance AX5 - 15w40 - mineral Shell Rimula R6 M |
April 13th, 2013, 08:37 PM | #234 | |
You guys can run the engine oil made by rotella as it meets the same standards required by ours bikes manufacturers. However , it's not safe to assume oil is oil except for weight. I'm not going to save a few dollars for some oil when I can buy something formulated just for our bikes. Also lots of new people read these threads and might become confused by misinformation.
April 13th, 2013, 08:43 PM | #235 | |
Congrats on saving a few bucks man. No problems here though either.
April 14th, 2013, 03:24 AM | #236 | |
Bass Master General
I couldn't give a toss what your car uses, and I don't give a damn what trasmission oil, it's not engine oil, the same as light machine oil isn't engine oil, and olive oil isn't engine oil, do you understand what I am saying? Nobody is getting confused, and if anybody is confusing anybody it's you with the drivvel that's spouting from your vacuous mind. So, to phrase this in a manner that I hope you understand, yet sincerely doubt you'll bother to, all engine oil formulated for a four stroke engine, be it diesel, petrol, motorcycle, etc, will work just fine in your bike so long as it's of the correct weighting, to use an anaology, you can wear boots, shoes, loafers, trainers, sneakers, ballet shoes, so long as they fit you. What is infinatly more important then the apparent shock horror, dissmisal and arogance you seem to display at the idea of using diesel oil in a motorcycle is the frequency of which you change said oil. So, thanks for not agreeing with me. |
April 14th, 2013, 08:42 AM | #237 | |
Its ok guy, part of growing up is accepting when you're wrong You cannot use engine oil in a bike that uses the same oil for both engine and transmission. There is a reason there is specific "bike" oil. So in that sense it's not the same as engine oil. Did you grab a snickers yet?
April 14th, 2013, 10:03 AM | #238 |
MOTM - Sep '14
@Joshorilla do they show US candy bar tv commercials in the Channel Islands?
@Bob2010 did you skip breakfast? |
April 14th, 2013, 10:39 AM | #239 |
Lol nah im more of coffee in the morning , steak and beers for dinner kind of guy
As a moderator on other forums, one thing that is truly frowned upon is mis- information. People browse looking for information and if they read the wrong posts, they can be in big trouble fast. Just stick to the facts. I'm sure you could "get away" with other oils but when I read this, I wanted to know the facts. Hence why I joined. The wikis and information here are amazing. I hope to see it continue to provide solid information. Like i perviouslystated, I personally read all the wikis and threads and posts, considered all my options. It took a lot of background research to confirm that engine oil made by rotella was acceptable because it met the same standards and requirements for our bikes. That isn't to say alll engine oils will act the same as long as the weight is correct. Soo in that aspect , what's a few dollars to know to that the castrol 4t oil (insert any other bike oil here) I run was designed with our bikes in mind and not just a generic diesel engine oil? You pay to play. Why cheap out on the one fluid that protects your clutches and engine?
April 14th, 2013, 07:54 PM | #240 |
Join Date: Jul 2011 Motorcycle(s): 2009 Ninja 250R Posts: 86
I don't use synthetics till about 5000 miles, the engine is fully broken in by then. My mechanic is a Ninja 250 expert and he told me so. Clutch plates aren't glazed yet till about 5000 miles, as he said.
Conventional vs synthetic for first oil change? | ally99 | 2013 - 2017 Ninja 300 Tech Talk | 12 | January 20th, 2014 07:44 PM |
Synthetic oil at 300 mile oil change? | anacron | 2013 - 2017 Ninja 300 Tech Talk | 14 | July 29th, 2013 04:58 PM |
When should I change my synthetic oil? | NinjaBoyEddy | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 21st, 2012 04:43 AM |
My oil change to synthetic ester experience | jonthechron | 2008 - 2012 Ninja 250R Tech Talk | 16 | June 3rd, 2010 08:49 AM |
