Old June 14th, 2015, 07:14 PM   #1
HerpDerp1919
Motorcycle(s): 1989 Kawasaki Ninja 250
Ninja 250 throttle issue
Just picked up a 1989 Ninja 250 that hasnt ran in about 2 years. Went through the carbs at least three times, it has good spark, getting fuel. If I choke it and get it above 5k itll run fine when I give it throtle, but as soon as it gets below 5k if i give it any throttle it dies. Any suggestions?
HerpDerp1919 is offline   Reply With Quote
Old June 14th, 2015, 07:16 PM   #2
Sounds like it needs a 4th time.
Old June 14th, 2015, 07:23 PM   #3
HerpDerp1919
Ther third time I checked EVERYTHING. Made sure every single passageway was clear and free flowing. Anything I should look for? any adjustment recommendations? Im new to bikes and have no manual for this one for adjustments
Old June 14th, 2015, 07:50 PM   #4
This section should give you most of the basics - http://faq.ninja250.org/wiki/Intake
Old June 14th, 2015, 09:55 PM   #5
Ghostt
Ghostt's Avatar
Stupid question time,
Describe exactly what you did cleaning the carburetors.
Did you remove the idle mixture screws? Set float heights? How/what did you use to clean them? Remove all jets and holders? Verify the fuel circuits were clear with an air compressor? Etc...
violente et ignorantia
ZX-2R BLOG
Old June 15th, 2015, 06:50 AM   #6
ducatiman
ducatiman's Avatar
a one-time successful carb clean entails some knowledge, correct equipment,
careful attention to detail, prayer...even voodoo sometimes
Old June 15th, 2015, 03:58 PM   #7
HerpDerp1919
The first time i cleaned them, I took them entirely apart. Fuel mixture screws, jets, needles and seats. If you could remove it, It came off. Soaked the carburetors in parts cleaner/ carb cleaner overnight along with the jets and needles. re-assembled. No fire due to old plugs.
Second time, complete tear down again, sprayed carb cleaner in everything and checked all passageways are clear with an air compressor and blew into them with my mouth as well. Re-assemble. Still a throttle issue.
Third time, I pulled the jets and needle and seat out. Verified there were no clogs in the jets and the needles werent sticking. Re-assemble. Still issue.
The second and third time I had my grandfather alongside who has cleaned many a carbs in his day and he is stumped as well. Ive looked at diagrams to make sure I have everything plumbed correctly and I do. The only thing I cant seem to find is what those big plunger (vacuum) things do in the carb. Theyre the big black plastic things inside the carb up top. Any ideas are appreciated. Were checking the valves tonight. Hopefully. Sorry for a long post
Old June 15th, 2015, 05:41 PM   #8
ducatiman
ducatiman's Avatar
herp-
Double check......a very common assembly error is inserting the needles OVER (and through) the white retainers (the little things with the feet) This is incorrect.
The needle should be inserted first....directly through the slide....the white retainers then get assembled over the needle heads....
Another common error is losing (or forgetting) one or both needle jets which get inserted under the "main jet holder" (aka emulsion tube)
The needle jets should be visible in the venturi as "collars"....the needles stick in them. Easy to see if missing.
Verify this stuff is all present and accounted for....and in correct order!
Old June 15th, 2015, 05:52 PM   #9
HerpDerp1919
Could I get some elaboration on the "little white things with feet?"
I'm 99% sure I assembled that correctly. Just curious on the white thing with feet.
Old June 15th, 2015, 06:17 PM   #10
Ghostt
Ghostt's Avatar
Little white feet Part # 16007
ZX-2R BLOG
Old June 15th, 2015, 07:01 PM   #11
HerpDerp1919
Okay. I have everything installed correctly. It holds 150 psi in both cylinders. However, if you hold your hand over the left carb it will rev up, if you put your hand over the right carb it dies.
Old June 15th, 2015, 08:04 PM   #12
HerpDerp1919
okay, stupid question time. Im digging around for parts for the carbs. I'm looking at the 09-12 carbs and they look pretty much identical. Will the carbs off an 08-12 work on this bike? were thinking its that black plunger thing that is malfunctioning but thats $150 a piece. I found a set of 08-12 carbs for $140.
Old June 15th, 2015, 08:24 PM   #13
Ghostt
Ghostt's Avatar
Contact @ducatiman for your all your carburetor part needs, and yes he has diaphragms.
Check the diaphragm for damage, also make sure it's installed properly, sometimes they can be a PITA, but a little trick is to put them in the freezer overnight, then quickly install them into the carburetors. The rubber will contract and be a bit stiffer, this makes them easier to install.
ZX-2R BLOG
Old June 16th, 2015, 04:07 AM   #14
ducatiman
ducatiman's Avatar
herp-
is it 16126 you are after? Is the diaphragm (rubber) visibly damaged...perforated, ripped, torn, edge pinched?
Old June 16th, 2015, 04:12 AM   #15
HerpDerp1919
16126 seems the likely culprit. I have absolutely no idea what's going on with this carb. There is no visible damage to the diaphragm.
Old June 16th, 2015, 05:39 AM   #16
ducatiman
ducatiman's Avatar
consider my pm.
Old June 16th, 2015, 06:53 AM   #17
What did you set the idle mixture screws at?
Did you confirm the o-ring and washer are in the correct position (assy16014)?
Do the slides rise and fall smoothly (engine off) when you lift them up gently through the rear carb opening?
Old June 16th, 2015, 07:38 AM   #18
HerpDerp1919
I set the idle mixture screws at 2.5 turns. Yeah, it's all in the correct order.
Old June 16th, 2015, 07:49 AM   #19
Good.
How about the slides - moving smoothly?
Old June 16th, 2015, 07:58 AM   #20
Ghostt
Ghostt's Avatar
Personally I set at 3x and then fine tune from there,
Your initial setting should be 3 full turns out from the bottom, remember just slightly tighten them, don't go all Conan on them.
Then warm it up, slowly turn 1 side pilot screw in until the rpms drop, then back out till RPM's peak (and no further)* Twist throttle...see how it reacts...tweak to taste.
Repeat on other side... test ride. You're looking for best throttle response and transition from just cracked to 1/4 throttle opening or so.*
Thats a quickie, 10 cent tutorial on setting pilot screws.**
ZX-2R BLOG
Old June 16th, 2015, 04:49 PM   #21
HerpDerp1919
Okay. Went through the carbs again today and my diaphragms are fully functional. I watched them rise and fall with the throttle. When it gets down about 5k or under and you give it throttle it sucks air and dies. Like maybe it's not getting fuel
Old June 16th, 2015, 05:20 PM   #22
Ghostt
Ghostt's Avatar
Okay stupid question time,
Are you doing all your testing without the airbox hooked up? If so that's not helping.
Why? You ask, here's why,
I would highly recommend that you DO NOT REMOVE THE AIR BOX, the carburetors on the bike are CV type and need to box to function properly, buy a K&N that fits the OEM airbox(K&N KA-2508 Kawasaki High Performance Replacement Air Filter by K&N Amazon.com: K&N KA-2508 Kawasaki High Performance Replacement Air Filter: Automotive Amazon.com: K&N KA-2508 Kawasaki High Performance Replacement Air Filter: Automotive ) that's the short version.
Long boring but important answer, CV carbs stands for "constant velocity". The function of the carbs is dependent on having a calm reservoir (airbox) from which to intake air at said constant velocity. Pods draw from the turbulent, unpredictable air swirling past them as you ride, which is anything but constant. Other carbs work fine with pods. CV's = no bueno, save yourself the headaches.
Now onto jetting, first you need to tune the idle mixture screws first, I recommend 3 full turns out from bottom as a good starting point, then fine tune them afterwards. As far as buying a jet kit, I personally don't have one on either my 250, or 500 ninjas. I did got up one size on my main jets, due to they are lean from the factory, and shimmed the main needles with a small washer.
ZX-2R BLOG
Old June 16th, 2015, 05:43 PM   #23
HerpDerp1919
I never got the factory airbox. So I guess I'll get that as well. Just thinking about putting new jets and seat needles in it.
Old June 16th, 2015, 06:21 PM   #24
Ghostt
Ghostt's Avatar
Well not having the OEM airbox isn't helping that's for sure. As far as other items, I would replace the float needle valves, and set the float height regardless, along with the idle needle o-rings. These are consumable items.
Have you contacted @ducatiman ?
ZX-2R BLOG
Old June 16th, 2015, 06:32 PM   #25
HerpDerp1919
Yeah. We've been back and forth. I might just send him the carbs instead of firing up the parts cannon. He seems very knowledgeable and will know what to look for
Old June 16th, 2015, 06:36 PM   #26
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Carbs are like vaginas, most of us know the basic functions but no one really knows what the hell is going on in there.
Old June 16th, 2015, 06:51 PM   #27
Ghostt
Ghostt's Avatar
I've know him for several years now, and I will personally vouch for him. I would trust him with my carburetors, he's got the proper tools, knowledge, and he believes in craftsmanship, and pride in his workmanship.
He's very well known and respected over at EX-500.com, which is where I know him from.
ZX-2R BLOG
Last futzed with by Ghostt; June 16th, 2015 at 10:44 PM.
Old June 19th, 2015, 06:13 PM   #28
ducatiman
ducatiman's Avatar
^ thank you for above comments, Ghostt (you have PM)
Lotsa work ahead on these, owned by herpderp. A few issues found upon initial teardown.
i'm confident that in the end, we'll have a runner with presentable, decent clean carbs.... inside and out.
Old June 19th, 2015, 08:25 PM   #29
ducatiman
ducatiman's Avatar
and later tonight.....done for the most part, some jetting decisions and changes pending. Innards cleaned, cleared, all circuits confirmed clear....
somebody's going to be mighty surprised i think
Old June 19th, 2015, 10:52 PM   #30
Ghostt
Ghostt's Avatar
Another excellent job @ducatiman, I love the before and after pictures, better than new.
PM replied.
ZX-2R BLOG
Old June 19th, 2015, 11:09 PM   #31
Ghostt
Ghostt's Avatar
Some of us more experienced people do just takes a lot of time, in my case over 30 years, and yes both
Ask all my EX's, that's probably the only thing they never complained about.
ZX-2R BLOG
Old June 20th, 2015, 05:11 AM   #32
HerpDerp1919
The pictures @ducatiman has sent me just blow me away. I'm amazed at the work he has done already. You are definitely a professional.
Old June 20th, 2015, 06:11 AM   #33
ducatiman
ducatiman's Avatar
thanks Tyler, you have PM re jetting decisions. Let me know.
Edit: jetting decisions now made, I'll be wrapping this up today/tonight.
2nd edit: cracked hose under decel valve replaced, final jetting choices installed, fuel levels
set, adjusted, checked via wet testing.
These are DONE.
Here's a peak at the innards after.
Last futzed with by ducatiman; June 20th, 2015 at 01:35 PM.
Old June 24th, 2015, 06:42 AM   #34
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
Any updates?
xXecuterXx2 is offline   Reply With Quote
Old June 24th, 2015, 08:01 AM   #35
HerpDerp1919
Waiting on the carbs to get here yet. Should be here tomorrow.
Old June 25th, 2015, 05:36 PM   #36
HerpDerp1919
Well, got em on the bike tonight. Runs great!! But, I now have discovered a bent front rim so alas, one more thing holding me back from riding
Old June 25th, 2015, 08:23 PM   #37
Ghostt
Ghostt's Avatar
Man you can't catch a break can you? Well at least those are cheap, don't forget new wheel bearings too while your in the neighborhood.
Also how's the forks, brakes,head bearings, etc.... Just something to think about
So I'm guessing your satisfied with @ducatiman work? Pictures?
ZX-2R BLOG
Last futzed with by Ghostt; June 26th, 2015 at 01:05 AM.
bike idle and throttle issue randomwalk101 2008 - 2012 Ninja 250R Tech Talk 5 January 18th, 2015 04:53 PM
Throttle handle issue... drunyon 2008 - 2012 Ninja 250R Tech Talk 49 February 19th, 2013 06:38 AM
Throttle issue HELP plz Shaol1n Monk 2008 - 2012 Ninja 250R Tech Talk 6 July 19th, 2011 08:43 PM
throttle or carb issue!!!!! danjaho 2008 - 2012 Ninja 250R Tech Talk 4 March 23rd, 2011 07:33 PM
