September 5th, 2014, 08:38 AM | #1 |
Join Date: Aug 2013 Motorcycle(s): CRF450X, CRF250R/SM, Husky 630 SMS, Ninja 250R Posts: 144
Exhaust clearance issues?
I'm running a Yoshimura tri-oval can / full exhaust, seems to sit higher than the stock can. It's dragging...
Is this common for other brands (Leo, Area P)? p.s. suspension is set to be a bit taller in the back, a few mm above stock with GSXR shock conversion, front has emulators / oil etc. |
September 5th, 2014, 08:52 AM | #2 |
I have the AreaP race system, the only time it will drag is when I am crashing. lol It's been my experience that most race oriented systems will not drag.
Can you post a pic of yours?
September 5th, 2014, 08:56 AM | #3 |
September 5th, 2014, 09:05 AM | #4 |
Wow, that is pretty low. You need to get that mounted up higher, heck it don't look any higher than the stock can. You sure that is a full system on not just a slip-on?
Oh and the Zombie bus is awesome!
September 5th, 2014, 09:08 AM | #5 | |
I'm not sure if I can move it up without getting a new system, so I suppose that's a distinct possibility. |
September 6th, 2014, 11:16 PM | #6 |
Join Date: Jun 2012 Motorcycle(s): 1998 Ninja 250 2007 Yamaha R6 2003 Honda RC51... sold :( Posts: 205
What size tire are you running? That will also change your clearance. So will adding that slider. The shock swap will help if the spring is stiffer or if it is longer, but neither of those will be enough to overcome the weight of the rider if they are a fat ass.
I'd check that exhaust hanger against the stock one and see if it is sitting lower. |
September 7th, 2014, 07:44 AM | #7 | |
P.s. my ass is 170lb so not too bad for 6' tall dude. |
September 7th, 2014, 08:09 AM | #8 | |
September 7th, 2014, 08:11 AM | #9 | |
September 7th, 2014, 08:25 AM | #10 |
What Hans said^^^ but I assumed that it was corrected when he said he was running the rear higher than stock.
September 8th, 2014, 10:52 AM | #11 |
I have shorter dogbones installed. If the shock was ride height adjustable I may have tried to tweak that, I may cut some even shorter linkage bits or get high mount pipe.
September 8th, 2014, 11:17 AM | #12 |
i have that trioval yoshi in SS. it does drag early compared to other exhausts. if you get a smaller bracket you can raise it up an inch or so with the pipe clamps the way they are. the high mount areaP seems to have the best clearance out side of a shorty no-can.
September 8th, 2014, 01:09 PM | #13 |
I guess I missed reading that... Lol my bad
AreaP Exhaust Fitment Issues | DaveTheCanuck | 2013 - 2017 Ninja 300 Tech Talk | 9 | July 29th, 2014 08:03 AM |
Clearance of the Ninja 300 stock exhaust | dino74 | Ninjettes At Speed | 20 | September 1st, 2013 05:05 PM |
Exhaust clearance issues? | pjed | Ninjettes At Speed | 3 | October 16th, 2011 06:59 AM |
Clip-ons Installed, now Clearance Issues | KURT | 2008 - 2012 Ninja 250R Tech Talk | 10 | February 22nd, 2011 10:19 PM |
[superbikeplanet.com] - Clearance Clarence: Suzuki Offers $1000 Off In Clearance Even | Ninjette Newsbot | Motorcycling News | 0 | February 15th, 2011 03:40 PM |
