February 15th, 2010, 11:31 AM | #1 |
Mr. 988
I suppose crashing a mile from home counts as a ride report.
I asphalt surfed on the way to work today. I am ok except for some bruising thanks to ATGATT.
I was coming down a hill toward a large intersection and I noticed that the road seemed damp (it was really hard to tell if it was wet or not) so I slowed slightly. Approaching the intersection, the light went amber then red so I had to make the decision to run the light (really not an option) or slow rapidly. I chose to slow. I eased on a bit of brake to heat the disk and started to squeeze harder; with a bit of rear brake, and then the front end tucked – instant low-side. Looking back, I believe my shunt was caused by the combination of the very slight new moisture on that stretch of road (it was about +-35 degrees out(frost?), the oil on the road near the intersection, a bit too much speed, and cold tires. Also, this was near my house so I was somewhat, should I say conditioned, to that same corner, same speed, same breaking area and that may have also contributed to my accident. I believe my speed was around 35 mph (didn’t look as I was scanning the intersection). I landed on my left side and slid around 25-30 feet. The bike continued about a quarter of the way into the intersection. Funny, but I did try to get up just a bit early at the end of the slide. There is a great urge to get off the street and out of traffic. Some Good Samaritans ran over to see if I was ok and helped me pick up the bike and push it to a nearby gas station. My gear did its job. The outside of my left pants leg is scuffed from hip to ankle. There is a quarter sized hole in the left knee that went through the outside layer and I think partially through the second layer. My jacket is abraded on the left rib area. My gloves held up well and I can tell where I hit and slid on them. The boots slid and did not catch which kept me from tumbling. Injuries to me beside my pride: None really. My ribs hurt a little along with my left hip and the heel of my left hand. I did not hit my head. Damage to bike: Cracked faring, bent clutch lever (maybe a bent left bar), cracked windshield, bent shift lever, and scrapes. I had difficulty getting the bike into neutral and it did not want to start. Kids, wear your gear!!! This happened a mile from my house. If I would have been wearing jeans or non-motorcycle specific gear I would have been in the hospital instead of 15 minutes late to work. I will follow up with some photos later. Ride safe and ATGATT. Jeff Last futzed with by JeffM; February 19th, 2010 at 08:22 AM. Reason: Added the temperature as a factor |
February 15th, 2010, 11:38 AM | #2 |
noob motovlogger
Join Date: Dec 2009 Motorcycle(s): Black 2009 250r Posts: 328
Aw that sucks man. Good to hear you're ok. The front-wheel lockup on water got me too. :P
My Motovlog "Damn, either shimming the needles fixes 90% of any problems with the 250Rs, or kkim owns stock in a washer manufacturer." -DmbShn41 |
February 15th, 2010, 11:45 AM | #3 |
did the front nose-dive have anything to do with the crash?
February 15th, 2010, 12:14 PM | #4 |
Join Date: Dec 2009 Motorcycle(s): 2009 250r green(sold) 2009 zx6r green Posts: 96
Glad that you are okay!
February 15th, 2010, 12:48 PM | #5 | ||
Mr. 988
jeff |
February 15th, 2010, 12:57 PM | #6 |
Join Date: Feb 2009 Motorcycle(s): '09 Candy Thunder Blue Ninja 250R Posts: 618
Glad to hear you're okay, thank goodness no one was moving in the intersection while this happened.
February 15th, 2010, 04:05 PM | #7 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
I'm glad you're OK and didn't get hurt more than bruised, or run over by a car in the intersection.
To try to figure out why the bike went down on the left side, your bars may have been turned steering a little to the left. The cold tires, speed, and slippery road caused you to skid or slide, but maybe you wouldn't have gone down or low-sided if the bars where straight ahead, and maybe then you could have kept the bike upright with your legs out. In retrospect, and I'm not trying to criticize, if you analyze what happened, it may be prevented the next time and we all can learn from it. Hitting the front brake with the wheel turned, on oil, gravel, even dry roads = bike down. Again, glad you're OK. |
February 15th, 2010, 04:13 PM | #8 |
Mr. 988
The road turns a little to the right as it gets to the intersection. I'm sure that I was just bringing the bike up from a slight right turn. A little left countersteer may have pushed it over that way.
It is suprising how fast the bike tucks and there is absolutely no way to correct once it happens. Jeff |
February 15th, 2010, 06:09 PM | #9 |
Join Date: Dec 2009 Motorcycle(s): 2009 Ninja 250r SE green with Monster energy decals!!! Posts: 223
Wearing protective gear really does pay off. I had a guy run me off into a ditch back in June (He did it deliberately). Had it not been for my gear I would of been injured pretty bad. Instead I was able to ride my bike away from that one (very grassy ditch so it only left light scuffs and a one inch crack in my right fairing). I was only going 45 mph and he matched speeds with me and weaved into my lane leaving me the ditch or him hitting me. I chose the ditch. After I got up I saw he had stopped to look back then he sped off as some Good Samaritans came to help. I ended flying off of my bike as it enter the ditch and landed some 6 to 7 feet in some gravel on the other side of the ditch all I had was a scuffed jacket, banged up helmet, scuffed gloves and some bruises.
February 15th, 2010, 06:13 PM | #10 | |
Join Date: Jan 2010 Motorcycle(s): 2009 Kawasaki Ninja 250r Special Edition Posts: 217
February 15th, 2010, 07:10 PM | #11 |
I wanted to but he was long gone by the time I checked my bike out to make sure it was ok.
February 15th, 2010, 07:29 PM | #12 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Glad to hear you are OK Jeff. I'm sure you will have find some lessons to reflect on tomorrow.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
February 15th, 2010, 07:59 PM | #14 |
Mr. 988
More to report
Brought the bike home tonight and it still will not start. I'll need to check the electrical system (kickstand switch or clutch switch might be suspect). A couple of other things I noticed:
My Winter Wings prevented the fairing from being rashed up by melting a bit. My instrument housing is loose from its moorings. I'm also thinking that the forks might be out of alignment. The left rearset and the left handlebar riser and switch cluster are loose. I did not see it happen (concerned about other things while sliding) but after the bike slid on its left side the tires must have hooked up because it ended up on its right side. I'm glad it high-sided without me. Jeff |
February 15th, 2010, 11:59 PM | #15 |
Mr. 988
Photos
Here are some photos of my gear after the slide. The knee only wore through one layer and slightly scuffed the inner layer.
This could have been my kneecap Left front hip Left forearm and hole in front of jacket. I did not see the forearm damage till I got home tonight. I think this is what hit first. Glove that held up really well Now I have to figure out where to get the pants repaired. Jeff |
February 16th, 2010, 06:38 AM | #16 | |
Things do happen really quickly, faster than you can say "Oh ****." |
February 16th, 2010, 06:45 AM | #17 |
Join Date: Aug 2009 Motorcycle(s): 2009 ER-6n 2009 Ninja 250 sold :( Posts: 61
I'm really glad to see your gear held up well and that you were able to walk away and still make it to work even! Hopefully we can get together for a few more rides this summer
"Never argue with an idiot, they will just drag you down to their level and beat you with experience" -Unknown |
February 16th, 2010, 07:47 AM | #18 | |
Mr. 988
Jeff. |
February 16th, 2010, 08:51 AM | #19 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
By the looks of your gear, you faired very well. I'm glad your okay. Let me know if you need help putting it back together. We can get together a couple of weekends and work on it. If there are any tools you don't have let me know, I might have them.
Addicted to anything that has an engine and rolls. |
February 16th, 2010, 09:08 AM | #20 |
Glad to hear you're alright!! It might be worth it to replace the gear instead of trying to have it repaired... An excuse to buy some new stuff. Just food for thought.
February 16th, 2010, 02:03 PM | #21 | |
Mr. 988
February 16th, 2010, 02:04 PM | #22 |
Looks like you took a decent tumble. glad your alright man!
February 18th, 2010, 07:43 AM | #23 |
Sorry to hear about the crash. Glad that you made it through ok.
February 18th, 2010, 07:52 AM | #24 |
If a traffic light going yellow puts me into a situation where Imna have to brake a motorcycle real hard to make the stop (especially if the road surface at the intersection entrance doesn't look good), I usually grab some throttle. I'm less concerned with what is legal than with what's gonna give my ass a more favorable outcome. Why was not going through the light an option?
Glad to read that you're ok!
February 18th, 2010, 08:16 AM | #25 | ||
Mr. 988
I made my choice and tried to stop. Quote:
Jeff |
February 18th, 2010, 08:20 AM | #26 |
February 18th, 2010, 12:08 PM | #27 |
Join Date: Jul 2009 Motorcycle(s): Red 09 Ninja 250r aka Sheila (RIP), Red '10 Ninja 250r aka Sasha (Sold), White '13 Ninja 300 (To be Purchased) Posts: 855
Sorry to hear about the bike but good thing you came out alright
March 21st, 2010, 01:14 PM | #28 |
Can you post up some pictures of the damage to the bike?
March 21st, 2010, 06:58 PM | #29 |
Fastly Slow!!!
Join Date: Feb 2010 Motorcycle(s): 2007 Kawasaki Ninja EX250, 1980 Honda XL125 Posts: 467
S!@# Jeff! I am so Sorry Man. Really glad your ok!!! What is going on here lately? I hope this dropping like flys trend stops now. We are getting kinda crazy here folks. Really glad your OK. Let us know if you need anything.
April 3rd, 2010, 06:48 PM | #30 |
Mr. 988
Tj, not much to see. Besides, I stripped all the body work off right after the crash.
On a side note, she lives I started the bike up today after doing a valve adjustment and new plugs. Had to replace the clutch safety switch and clutch lever - the switch was the culprit that kept the bike from starting. Tj, let me know when you can start painting. I need to start sanding the body work to prep. |
April 5th, 2010, 06:50 AM | #31 |
Ive been back for about five days. I can start painting as soon as you are ready. Just give me a call. I will be able to work on it during Saturday & Sunday mornings so it may take me two weeks since I have to lay some primer down on some of the panels.
April 5th, 2010, 08:43 AM | #32 |
Join Date: Mar 2010 Motorcycle(s): 2008 Ninja TwoFiddy Posts: 162
Glad to hear you are ok and your gear helped. I learned with water to use the rear brake only. I'm surprised here in Central FL how many riders on their bikes wear short, t-shirts and sneakers.
April 5th, 2010, 09:02 AM | #33 |
Mr. 988
Thanks. Still have a sore hand a month and a half later.
Gear is good and I wear all of mine all the time. Regarding other riders, it is their choice not to wear gear but I totally cringe when I see others that are not ATGATT. |
May 6th, 2010, 01:55 PM | #34 |
Join Date: May 2010 Motorcycle(s): 2010 ninja 250r, 2009 650r Posts: 150
happy to see your positive and okay!
[superbikeplanet.com] - Soup's Free Classifieds: Home of the 100 Million Mile Garage | Ninjette Newsbot | Motorcycling News | 0 | May 6th, 2012 07:40 PM |
Since I've already met some of you in person, I suppose I'll meet the rest of you... | Skippii | New Members | 21 | August 17th, 2011 04:17 PM |
[hell for leather] - Crashing a snowmobile looks way worse than crashing a motorcycle | Ninjette Newsbot | Motorcycling News | 0 | May 23rd, 2011 12:40 PM |
[topix.net] - Man Sues Harley-Davidson After Crashing During Test Ride | Ninjette Newsbot | Motorcycling News | 0 | January 28th, 2011 02:50 AM |
[superbikeplanet.com] - After Crashing Out At Qatar, Bautista Heads Home For Spanish | Ninjette Newsbot | Motorcycling News | 0 | April 28th, 2010 11:30 AM |
