June 16th, 2014, 05:18 AM | #1 |
Biker Noob
Join Date: Apr 2014 Motorcycle(s): 2004 Honda Shadow 750 Aero Posts: 176
A good way to get off cigarettes
I am using this to quit smoking cigarettes.
Riding as I stole it. |
June 16th, 2014, 07:40 AM | #2 |
MOTM - Mar '13, Jun '14
Looks like a pen. Good luck getting the ink off your teeth.
June 16th, 2014, 07:41 AM | #3 |
Biker Noob
It's a e-cigarette not a pen.
June 16th, 2014, 08:09 AM | #4 |
Join Date: Jun 2014 Motorcycle(s): '82 Honda Ascot 500 (sold) '09 Suzuki SV650 (Totaled by deer) Posts: 28
When you are really ready to quit, cold turkey is the only way. I quit multiple times with gum, patches, etc. only time it stuck was cold turkey.
Faster you get the nicotine out of your system, the faster the cravings go away. If you can make it the first two weeks you are home free. |
June 17th, 2014, 03:40 PM | #5 | |
I thought it was called "Wild Turkey"!
June 17th, 2014, 04:02 PM | #6 | |
i've have been off cigarettes for a little while now. probably 2 years. every now and then i'll have a puff off someones e-cig if they're clean (no nicotine) and its nice to play with smoke but it definitely doesn't make me want a cigarette.
June 17th, 2014, 04:03 PM | #7 |
no no no, that's the name of the STD that hooker from puerto rico gave you.
June 17th, 2014, 04:21 PM | #8 |
Then again... you could just.... uh.... quit.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
June 17th, 2014, 04:38 PM | #9 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
New vaper in the house... Sweet
Best of luck |
June 17th, 2014, 04:42 PM | #10 |
sounds like words from someone who doesn't know much about physical dependence?
June 17th, 2014, 05:08 PM | #11 |
Good lord I wish I didn't know all about physical dependence.
I never understood the games and the back and the forth and the conditions and the rewards and the semantics of addiction management. If you're going to be addicted to something, go right ahead and play it to the hilt. If you want to quit -- cut it off. Strength. Force of will is incomparable to any other force in this world, man-made or otherwise.
June 17th, 2014, 05:12 PM | #12 |
Let me also add from a SCIENTIFIC standpoint -- the half life of nicotine is right around two hours unless I'm mistaken -- which means after two hours there are ZERO physical withdrawal symptoms. The are purely psychological, and the body manifests the symptoms as you believe in them.
Don't get me wrong, it sure feels like your skin is crawling, but if you look at it under a microscope... it's certainly not moving.
0 out of 1 members found this post helpful. |
June 18th, 2014, 04:43 PM | #13 | |
Join Date: Dec 2013 Motorcycle(s): 2011 250R SE Posts: 326
There's a documentary I saw on SEAL training Hell week. The summation was that the purpose of Hell week was to find out who had the Will to make it through. Skills could be taught and muscles can be grown but the Will to do something no matter how hard it is couldn't be trained or engrained. You either have it or you don't I never gave nicotine a chance, but his buddy caffeine is another story. |
June 18th, 2014, 05:19 PM | #14 |
I respectfully disagree.
Force of will is a skill, just like anything else. Some people aren't just "born" with big muscles. They lift heavy weights and DO WORK and that's how the body reacts -- it becomes stronger. Some people aren't just "born" to be intelligent -- They study, read, learn, ask questions, and TEACH THEM SELF how to be intelligent. Ever been afraid of doing something? You have two options -- do it, face the fear, realize it's just mental and it's an irrational belief that you hold for whatever arbitrary reason --- OR --- not do it, let the fear become more powerful, and probably rationalize why you shouldn't do it, why you can't do it, or maybe even convince yourself that you're just incapable of doing it, that way you don't have to face the very real fact that you are, in fact, WEAK. This is the same argument with obesity and fat people. I should bite my lip because I hold some very unpopular viewpoints that happen to TRUE. "I'm fat and it's not my fault. I'm fat because of genetics, thyroid problem, I'm unable to exercise because I have to work. I'm fat because one million ufcking reasons that have nothing to do with me and are totally out of my control. It's not my fault." Being fat is not complicated. Carbs in, carbs out. Thermodynamics. You consume more energy than you use, therefore your body stores it. That's the scientific method of action behind being fat. Given, we all process that energy and some of us store more of it than others -- but this is ENTIRELY inconsequential in the face of absolute FACT --- You are fat because you are weak. You lack the self control/force-of-will to control your calorie intake. But things can be justified and rationalized however a human pleases. That is human nature. (Don't get me wrong, I'm not perfect. I can do some things that terrify others without hesitation -- but other things frighten me just as much as the next person.) Force of will is just like a muscle -- taking 'right action' -- the more you do it, that which you know to be correct, the stronger your ability becomes. Over time, hesitation vanishes, because you simply do what you know to be correct. Picture firefighters running into a burning building to save a family... Personally I'd rather do something other than running into a burning building, but over time, they have learned that skill and how to perform it without hesitation. Force of will is a skill that is consciously created, practiced, and strengthened.
June 18th, 2014, 05:22 PM | #15 |
And to anyone quitting cigarettes, good for you! If you don't succeed, try again!
The key is to pick yourself up exactly ONE more time than you have fallen down.
July 9th, 2014, 09:49 PM | #16 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
Nice, what tank is that? I'm trying to figure out what I want to use, I'm just doing clearomizers right now
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
July 9th, 2014, 10:23 PM | #17 |
Join Date: Dec 2010 Motorcycle(s): 1965 Honda S90 , 2010 Ninja 250,2012 Vespa LX 150(Yes,a vespa!) Posts: 177
Replacing 1 dependency with another,i don see the point but thats me,smoke or not.
20 years of smoking 30-40 p/day & its 11 months smoke free & it feels great. Mentally strong,lucky or just too busy i dont know but even having the shittiest day i dont ever think about it. Good luck giving up. |
July 10th, 2014, 02:05 PM | #18 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
Here's how to do it
1 pick a couple of days when you won't be socializing to launch. 2 Buy an unopened pack of ten and put them in your pocket. 3 Throw any opened cigs away in a public bin (ie beyond recovery) 4 If you suffer a stress that you can't handle or really cannot resist you have my permission to open the pack and have one But you MUST post on here that you have done that. 5 Six months time throw the unopened pack away |
July 10th, 2014, 05:05 PM | #19 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
I quit cold turkey in 05 and have not had one since, yes it sucked for a short time, but some things in life are worth suffering through to live a better life.
July 11th, 2014, 09:25 AM | #20 | |
July 11th, 2014, 02:56 PM | #21 |
I wish I could stop smoking but fact is, I know deep down, I don't want to. I tried once and failed. The cost of the damn things would pay for my track time each month.
July 11th, 2014, 03:00 PM | #22 |
Inline 4!!!
I have an addiction to sour candy, gummy worms, etc. I don't think this will help me stop
July 11th, 2014, 03:01 PM | #23 | |
Inline 4!!!
Of course it will be hard as hell, but it's worth it man. Nothing worth having in life is easy. "I tried once and failed" this is just not true... you quit smoking every single day. The second you are not smoking you quit. I learned this in my philosophy class. As soon as you stop, you "quit" it's only until you smoke again when you spot "quitting".
July 11th, 2014, 03:05 PM | #24 | |
Inline 4!!!
July 11th, 2014, 03:14 PM | #25 |
Agreed Danny, and thanks for the push in the right direction. I WILL quit one day, it's just a question of when and at what cost. Here is my biggest beef with quitting...
I aint claiming to be some guru of this stuff, but nearly every person I know, aside of my dad who has quit smoking is more sick now than they were before quitting. Being straight honest here, I aint got time to be sick right now. My tolerance for common ailments is above average yes, but I can't take chances right now. Maybe it is a temp thing as the lungs clear up, But one thing I do know, is my great grandfather lived to be a 102 while smoking. Us Smith's are hard to kill off, our worst injuries are ALWAYS self inflicted. hahahahahahh
July 11th, 2014, 03:35 PM | #26 | |
too many people do not understand that your brain is like a computer. it can be wrong and believe that it is correct. when it is broken it does not come up with the correct answer. you don't just "will" yourself out of a mental disease most of the time. do you know how many homeless crackheads want to kick it? it is a surprising amount. making light of a serious issue does nothing but degrade the national opinion of mental illness. did you know that more than half of homeless crack addicts are in such poor health that quitting without proper medical supervision would actually probably kill them on the street? have you ever heard of amy winehouse? addiction and mental illness is not something to joke about. cigarettes are addictive, but they are one of the milder addictions people deal with every day. it is very disrespectful to belittle people dealing with addiction as weak and unwilling to deal with their issues when you don't understand what they are going through.
July 11th, 2014, 03:36 PM | #27 |
And you won't actually quit until you do, it's the whole horse and water thing. If and when you decide that there's more pros to quitting than cons then you'll quit.
I say do what ever makes you happy as long as it isn't affecting others in a negative way. Drink, smoke, do drugs... just don't drink and drive or smoke around kids or steal to get your fix. |
July 11th, 2014, 04:00 PM | #28 | |
Inline 4!!!
July 11th, 2014, 04:05 PM | #29 | |
Inline 4!!!
July 11th, 2014, 04:42 PM | #30 |
Why bother?
July 11th, 2014, 04:55 PM | #31 |
Why? Because there is a chance, and as human nature has always proven.... a chance (hope) is all you need.
July 11th, 2014, 05:26 PM | #32 | |
For a scientist you don't know much about half life do you? 1/2, 1/4, 1/8, 1/16, 1/32, 1/64... every 2 hours it drops by half Then we get into that nicotine is a stimulant, it dials up your dopamine production & release to the point your body becomes dependant on it for normal function and it dials down it's response, when you drop below the active dose is when the withdrawal begins. Your normal neurotransmitter & hormone responses are skewed, your body tries to keep it on an even keel, responses are dialled up to compensate for others that are dialled down, in response others get dialled down to compensate for the ones dialled up |
July 11th, 2014, 08:12 PM | #34 |
Um haha... That is all
[hell for leather] - Ask RideApart: When it comes to gear, how good is good enough? | Ninjette Newsbot | Motorcycling News | 0 | August 12th, 2013 02:50 PM |
[crash.net - MotoGP] - MotoGP Le Mans: 'Good for Ducati, really good for me' - Dovi | Ninjette Newsbot | Motorcycling News | 0 | May 15th, 2013 05:00 AM |
Good school for UK riders and good safety tips for the rest of us | Motofool | Riding Skills | 5 | November 3rd, 2012 08:47 PM |
[topix.net] - Haslam: Two good starts, two good finishes | Ninjette Newsbot | Motorcycling News | 0 | March 28th, 2010 09:40 PM |
[crash.net - WSBK] - Haslam: Two good starts, two good finishes | Ninjette Newsbot | Motorcycling News | 0 | March 27th, 2010 01:30 PM |
