March 9th, 2016, 12:27 PM | #41 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
It is not overrated for me. I do what i'm most comfortable with depending in the circumstances. Weather it be a one foot stop of if i put both feet down, like i send i mostly do one foot. its work for me for the past 4ish years.
Thanks for the info though.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
March 10th, 2016, 05:10 AM | #42 |
Clutch cable.. Check. New levers.. Check. Flush mounts.. Come on USPS!!!!!
March 14th, 2016, 06:30 AM | #43 |
Busy weekend!
Pulled the old clutch cable... Just wow... Got the new one on. with the new levers and flush mount lights. Put some new spark plugs in too. And its amazing what a bath can do! Had to shim the brake lever a bit. Just some washers for now. I have power! The phone mount is on too. And took it out for the first ride! So awesome being back on a ninja!
March 14th, 2016, 06:32 AM | #44 |
Oh, and my other half picked these up for me yesterday.
March 14th, 2016, 10:36 AM | #45 |
Private Joker
MOTM - Mar '14
Those 2bros pipes sound ungodly amazing on the pregen. I wish they weren't so fragile or I'd still have them on my frankenstein bike, it changes the entire feel of the bike
March 14th, 2016, 11:26 AM | #46 |
Good to "hear".
Sorry, had to. How are the fragile? In a fall?
March 14th, 2016, 11:37 AM | #47 |
Private Joker
MOTM - Mar '14
The material is alluminum which wears through pretty quick
Mine survived a few low speed offs and a high speed lowside before getting ripped apart in a highside (granted there was extensive damage across the bike but still) so it wasn't too bad I'm just bummed that I don't have it anymore since I liked the sound so much. That said they can only take so much sliding as they are thin as well. Hopefully you never run into that issue
March 14th, 2016, 11:52 AM | #48 |
I hope not!
I should be ok, no immediate plans to track the bike. Maybe in a couple years... After i get the next bike, whatever that may be. Still kicking some ideas around and not in any rush.
March 14th, 2016, 11:57 AM | #49 |
Private Joker
MOTM - Mar '14
I've come to learn over time that track riding isn't a cause of crashes, it's the mentality that people have when they go to the track. So long as you don't go trying to push your limits right out of the box you're much more likely to be fine. Still definitely worth doing a day or two for the learning involved
March 14th, 2016, 12:03 PM | #50 |
I do want to. That hasn't changed. I just don't know when...
March 17th, 2016, 05:11 AM | #51 |
Got the pipes on! Love love love the sound!!
Forgive the knocking, we still need to do the clutch.
March 17th, 2016, 07:41 PM | #52 |
March 17th, 2016, 07:45 PM | #53 |
Really no need to wait for the track. It truly is just like the best ride in the twisties you've ever had, only better.
Knowing you, however slightly, I'm confident that you'd be just fine. When you do get to the track, you'll be kicking yourself for not having done it sooner. I promise.
March 18th, 2016, 04:38 AM | #54 | |
I'm sure i will. I'll admit part of me having to wait is financial. I'll probably be able to sash som $$ aside when the other bike sells. Pluss I would like to drop more weight so i feel more confidant in some leathers . I'm getting there, dropped a pants size since January. That's more why i give it the year or so prediction.
March 18th, 2016, 05:31 PM | #55 |
You're down a pants size? Good job!
March 18th, 2016, 06:04 PM | #56 |
Thank you!
March 19th, 2016, 01:12 PM | #57 |
Next step is jetting... I know it's a lot of guess work getting the correct setup. Any suggestions?
March 19th, 2016, 04:10 PM | #58 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
Raise the needle position up 2-clips to start.. you will likely need to wait longer for warm-up before you'll be able to pull out to ride without choke on.
March 20th, 2016, 06:49 PM | #59 |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
I would probably start off with one size larger mainjet, then get the mixture screws dialed in.
Because Unregistered sucks at riding. |
March 20th, 2016, 07:49 PM | #60 |
I haven't seen any mention of valve adjustment. If you don't have dealer receipts showing the adjustment done within the last 6K miles then you should get that looked at ASAP as riding with tight valves will total the motor. Right now it seems like there's no known record of when that last was done.
On the clutch cable breaking at the nut, that's common because that spot, where the nut pivots in the hole in the lever, rarely gets lubed with a good high-pressure waterproof grease. The nut sticks in the hole and forces the cable to bend and flex as the lever is pulled, and that causes fatigue fracturing in the strands. I went through two cables in the first 20K miles on my '06 before I figured that out, and since then I've dipped that nut in grease ever 5K miles. My last cable has lasted over 50K miles so far. FWIW, the right front and left rear signal stalks are identical except for the mounting base on the fronts. The same for the other pair of corners. Definitely rejet and retune your carbs for those new mufflers, otherwise you can burn your exhaust valves due to excessively lean mixtures. Also, there's another accessory power lead set up under the front fairing just like the pair you found under the side cover by the panel. There's not a lot of extra power available from the alternator on the EX250, but there should be enough for something like a phone charger or GPS. |
March 21st, 2016, 05:46 AM | #61 |
More just looking to see what size jets others went with. Trying not to rip it apart over and over.
As for valves, that's on the list too. we are probably going to check them when we pull the carb off.
March 21st, 2016, 05:58 AM | #62 |
For the stock airbox and aftermarket exhaust on the pregen you should be close to Keihn 100's with one or two washers, and 2.75 turns out on the mixture screws. With POD filters and an aftermarket exhaust on the pregen you should be near 114 Keihn main jets, 2-3 washers under the needle, and 3 turns out on the mixture screws. Every bike, exhaust, pod filter, and atmosphere would be different though.
March 21st, 2016, 06:33 AM | #63 |
Teri: Do yourself some favors when you do the carbs:
1) If the pregen is anything like the newgen, go ahead and take the tank off first. Makes getting at them a whole lot easier. 2) Buy a JIS screwdriver before you mangle the carb cap screws. Vessel makes one that is also has an impact driver action to it... just the thing for unsticking the cap screws on the carbs. 3) Replace those screws with socket head screws.
I am NOT an adrenaline junkie, I'm a skill junkie. - csmith12 Nam et ipsa scientia potestas est. Heri historia. Cras mysterium. Hodie donum est. Carpe diem. Last futzed with by adouglas; March 21st, 2016 at 06:39 AM. Reason: flippin' autocorrect |
March 21st, 2016, 07:35 AM | #64 |
Thanks guys. I know there's lots of combinations to try. I will fully admit i know nothing about the adjustments. My other half is doing them and just wanted a good starting point.
Looking at the jetting threads is like trying to read greek to me.
April 18th, 2016, 05:06 AM | #65 |
Ok, overdue for an update. 2 weekends ago he got the carb off and we found part of the idle issue. Had some kind of obstruction in there. Not sure what.. By the time he had the time to get it all back together it was late in the week (and i had been sick) so we didn't get to test it. then he got sick.
So just got on it yesterday and... needs more work. He's going to change the jets around tonight or tomorrow. Did get a new battery though. It's so cute! 20160416_194103.jpg
April 18th, 2016, 08:19 AM | #66 | |
Here's a pretty clear schematic. Fuel gets into the engine via two routes. One is the slow (idle or pilot) jet, which allows a little fuel past the throttle plate (which is what actually moves when you twist the grip) even when it's fully closed. The other is the main jet, which is below the needle. How all this works is pretty cool. As you open the throttle, the engine sucks more air through the carb. This creates low pressure in the throat (because Bernoulli). See the little hole labeled 7? Air from above the diaphragm gets sucked through that hole because of the low pressure in the throat, which creates a vacuum in the chamber above (where the spring is). This sucks the carb slide up, opening up the throat. The slide movement also pulls the needle out of the main jet, allowing more fuel to flow... which it does, again because of the low pressure in the throat that sucks it up through the main jet. vrooommmm.... So what are you doing when you adjust jetting? Short answer is you're changing the mixture, generally in the direction of making it richer. Once your intake and exhaust mods are done, the amount of air flowing through the carb is pretty much set. By changing the jets and moving the needle, you're changing how much fuel flows for a given twist of the throttle, relative to the amount of air. (Notice that the needle is tapered. The farther it gets pulled out, the more fuel can flow. What you're doing when you add shims is changing the amount of fuel that gets by when the slide moves.) So think about the whole picture. Bigger jets, higher needle all add up to more fuel. But you can go too far and make the mixture too rich, which is just like riding around with your choke on all the time. So you need to get the right combination of jets, needle position, idle screw adjustment for your particular bike. All this stuff varies by altitude and specific bike mods, which is why there is no one "best" answer. So why do we need to rejet in the first place? For one thing, the bikes come set pretty lean for emissions. Rejetting and/or adding clips to the needles gives you a little extra power even if you don't do anything else. But you might as well go ahead and make the engine breathe easier. Snorkel delete, Kleen Air delete, K&N filter, freeer-flowing exhaust all add up to less restriction to air flow, which means more air and a leaner mixture if you don't compensate. So we rejet to rebalance the fuel/air mixture. The cool part is that now there's more fuel AND more air, and that adds up to moar powah.
I am NOT an adrenaline junkie, I'm a skill junkie. - csmith12 Nam et ipsa scientia potestas est. Heri historia. Cras mysterium. Hodie donum est. Carpe diem. Last futzed with by adouglas; April 18th, 2016 at 11:54 AM. |
April 18th, 2016, 10:59 AM | #67 |
Your awsome! That's what he was trying to teach me but seeing the diagram helps a lot!!
Ok so it's still too lean. He said we need to put a bigger main jet in and maybe mess with the needle. Once he's happy with that he's going to tackle the mixture screws to get the idle happy. I've seen the Snorkel delete and Kleen Air delete mentioned befor. I'll have to look more into them. One is removing the airbox i think? that one worries me if i get stuck in the rain. I tend to do that a lot. He also was looking at the EFI kits and really wants to do that to the bike at some point. The just cost so much. The ones i've see cost as much as the bike did.
April 18th, 2016, 11:52 AM | #68 |
Snorkel delete is not the same as removing the air box. The snorkel is a tube that's jammed into the box. You just pull it out... no worries with rain.
Kleen Air requires removing some hoses and capping some fittings. That's all. Both can be done in about an hour if you take your time. There's nothing in the world wrong with carbs. They're elegant pieces of machinery. All EFI really buys you is easier tweaking (since it can be done with software) and not having to use the choke at startup. Big whoop.
April 18th, 2016, 12:43 PM | #69 |
Ah! Ok, that may be something we do then.
I'm more a fan of FI over carbureted. In part for what you just mentioned. Though it's (obviously) not a deal breaker for me. So if we can find a EFI kit for ~$500 or so we'll probably give it a go.
April 18th, 2016, 02:11 PM | #70 |
Entrons kit is $500-$600
April 18th, 2016, 02:31 PM | #71 |
Vintage Screwball
MOTM - Mar '16
Jetting should be done from idle on up, not the other way around.
Jet for idle and low end, then jet for middle and top end. The jets and passages used at idle are also giving fuel throughout the entire RPM range. Start at the bottom and work your way up.
Goin' fast on slow bikes! |
April 18th, 2016, 02:32 PM | #72 |
Couldn't disagree more. Get the bike to run first. Then find the right main, then needle, then pilot, then mixture screws.
April 18th, 2016, 04:32 PM | #73 |
That would be sweet! I'll look that one up.
April 18th, 2016, 04:40 PM | #74 |
vampire
Pregen's jetting is pretty much spot-on from factory, there isn't much performance gain unless you want to change the powerband.
Seems to me the bike just needs to be ridden a few tankful of Seafoam and fresh fuel, rev thru the range to get the carbs cleaned out that way. Of course the aftermarket exhaust doesn't help.. put the OEM exhaust back on and just ride the thing. |
0 out of 1 members found this post helpful. |
April 18th, 2016, 04:44 PM | #75 |
No. I like it so we will make it work.
No offense but please stop telling me what to do with my bike. I do appreciate the information but you are coming off to strong.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... Last futzed with by LittleRedNinjette; April 19th, 2016 at 05:36 PM. |
April 19th, 2016, 05:38 PM | #76 |
Almost there! He wants to do one more tweak and with any luck Pikachu will be running perfect!
I'll post up what we went with when it's done.
April 19th, 2016, 05:46 PM | #77 |
I'll post what I decided was the best if it helps any. (Pods and yoshinurs full exhaust on a pregen). DJ 114 mains, needles in the third clip position, size 40 keihn pilots, mixture screws 2 ⅝ turns out.
April 22nd, 2016, 05:08 PM | #78 |
Join Date: Jan 2016 Motorcycle(s): 2007 Ninja 250 Posts: 96
Beauty! Looks pretty clean too.
I got the same model in red. How much did you get it for? |
April 22nd, 2016, 05:59 PM | #79 |
$1k
Relatively good deal. Had some gremlins we worked out but overall very pleased with it.
April 22nd, 2016, 06:01 PM | #80 |
Did your SO ever get the jetting dialed in?
Meet: The Hoonicorn! | choneofakind | Videos | 2 | January 2nd, 2015 07:48 PM |
Meet my NEW BOYFRIEND!!! <3 | SSANGHA | Pictures | 35 | November 16th, 2012 08:04 PM |
Not the best way to meet a new neighbor. | Bassman | !%@*#$%!)@#&!%@ I crashed! | 10 | October 31st, 2012 08:46 PM |
Meet up -- Yonkers NY | iSpeed | Group Rides and Local Events | 4 | July 17th, 2012 06:13 PM |
I'm just here to meet girlZ! | oroboros | Off-Topic | 13 | April 5th, 2011 05:10 PM |
