Old October 17th, 2012, 01:38 PM   #1
Redsvt
Gas tank whine or not...at WOT
Now I have read every post there is on the gas tank whinning noise. It has gotten worse, almost like a kettle boiling. It gets really bad when I ride the bike hard, ease off the throttle a bit and there it is, whinning and whistling.
So last night on the way home I put my spare key in the tank, and when it started to whine, I popped open the gas cap. The sound did dissipate and eventually go away. Now with the gas cap open I decided to let er rip, and the whinning and whistling was there again...how can this be? Could this in fact be another problem ? I do not know, and I dont want to do the gas cap mod as I feel in may be in vain, as the sound is still there when the gas cap is open.
What is your advice folks.....I eagerely await your feedback.
Redsvt is offline   Reply With Quote
Old October 18th, 2012, 08:20 AM   #2
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
if in fact its the gas tank....take off the hose under the seat in the front. the gas vapor release tube. i jus ditched mine. i cant even smell any gas vapor. try that.
The King
rabies is offline   Reply With Quote
Old October 18th, 2012, 09:13 AM   #3
Redsvt
I will try that......what else could it be if its not the above suggestion, anyone else have any ideas or even experienced this. Bike is a 2012 with 5k miles on it.
Old October 22nd, 2012, 03:18 PM   #4
Hunsy34
Hunsy34's Avatar
Motorcycle(s): 2009 Ninja 250 2016 Ninja 300 1994 KTM 300 EXC
And if you don't want to take the tube off try cutting it so it's shorter that might help.
Hunsy34 is offline   Reply With Quote
Old November 12th, 2012, 02:55 PM   #5
Redsvt
Well guys I have treid everything...still whinning wheter the engine is hot or cold, or if it sits in the sun in the day or in the garage all night, still whinning and now a gurgle...when slowing down.
Old November 13th, 2012, 12:22 PM   #6
You sure it's the gas tank? Check everything air related with the bike up on stands and your helmet off.
Still have snorkle?
Old November 13th, 2012, 12:40 PM   #7
Redsvt
Still have the snorkle, no mods done to the engine or intake.
Old November 13th, 2012, 12:43 PM   #8
Yea, but that don't mean the problem is not there. Check airbox/filter, snorkle (this is my guess), and carb boots. You know the easiest thing to do to eliminate the gas tank as a source of the problem is to run it a short distance in a straight line with the tank open.
Old November 13th, 2012, 04:44 PM   #9
Redsvt
I have riden it with the cap open...still does it.
Old November 13th, 2012, 04:56 PM   #10
Well that pretty much takes the tank off the list. Next big question is does it happen only while moving or not?
Old November 13th, 2012, 05:36 PM   #11
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
Those would be the next areas I would be checking followed by vacuum lines/fittings.
LoD575 is offline   Reply With Quote
Old November 13th, 2012, 08:26 PM   #12
slowninja
Motorcycle(s): Ninja 250R
I noticed that. It also does that when i balance the bike from the side stand as well. I don't mind that.
slowninja is offline   Reply With Quote
Old November 14th, 2012, 08:06 AM   #13
Redsvt
I have not had chance to dig into any suspect areas yet...but I did notice one thing this morning, I was noticeable as soon as I pulled away this morning, then it went away.....
But I noticed my speedo was not working..it has up until this morning. I am wondering if the cable was binding in the houseing console. Will investigate further. I did have the rubbing at the wheel but fixed that months ago, could it be the speedo connector in the console making all that noise.
Old November 14th, 2012, 08:44 AM   #14
DaBlue1
Long Time Rider
DaBlue1's Avatar
Chances are that if your speedo is now not working, what you were hearing was speedo cable squeal. Sometimes it helps to post a video of the sound. Everybody describes sounds differently, however many are distinguishable, especially the sound difference between speedo cable squeal and tank whine/whistle.
If your bike speed sounded anything like the speedo in this video, it was probably your speedo cable and your cable shaft may now be broken.
Old November 14th, 2012, 09:34 AM   #15
I smell progress!
Old November 14th, 2012, 09:54 AM   #16
Redsvt
Damnnn that is the exact noise...will tear into it this evening
Old November 14th, 2012, 07:38 PM   #17
Redsvt
Well that appears to be the problem. Rode home for 30 miles and not a whine, whimper or murmur. Only problem is no idea how fast how was going...off to the dealer as it is still under warranty.
Old November 15th, 2012, 07:05 AM   #18
Gas Tank Lock stuck? Maintenance for gas cap with pics! Skippii 1986 - 2007 Ninja 250R Tech Talk 35 May 6th, 2021 09:03 PM
DIY: Super-Secure Gas Tank Holder (for when your tank is removed) headshrink 2008 - 2012 Ninja 250R Tech Talk 21 June 16th, 2014 01:20 AM
