Old March 30th, 2017, 11:24 AM   #1
skip
skip's Avatar
Motorcycle(s): 2009 250r
no power
Had bike on turned it off, now it won't turn on no lights on the gauges turn on ,battery is good any ideas.taillight turns on blinkers lighting up T
skip is offline   Reply With Quote
Old March 30th, 2017, 11:30 AM   #2
Get out a meter or test light and see how far you have power as you move away from the battery, starting with main fuse.
Old March 30th, 2017, 11:31 AM   #3
Main fuse would be something to check, as would the battery terminal connections.
I'd also check the battery voltage both before and after you turn the ignition on. A battery can sit at a normal voltage until any amount of load is put on it (even just turning on the ignition) and then drop to zero.
Old March 30th, 2017, 11:50 AM   #4
safety switches bro
start with sidestand switch, i bet it's dirty, then make sure your battery terminals are clean and tight
Old March 30th, 2017, 12:45 PM   #5
skip
skip's Avatar
blown fuse
Blown ignition fuse changed it gauge lights came on but didn't crank over then fuse blew again any ideas
Old March 30th, 2017, 01:30 PM   #6
There's something causing excessive current draw. It could be a wire that got its insulation chewed through and is touching the frame, or a defective switch. Once I had a rear brake light switch go bad and randomly blow fuses. I ended up replacing the fuse with a non-auto-reset circuit breaker so at least I didn't have to carry a dozen fuses with me to go for a ride. I eventually found the bad switch when it became obvious that the fuse seemed to blow only when I used the rear brake.
Old March 30th, 2017, 01:46 PM   #7
I'm not sure I follow that, Hernan. The starter motor isn't fused, so it can't be causing fuses to blow.
Old March 30th, 2017, 01:56 PM   #8
I stand corrected.
I believed it was
Previous post deleted.
Thanks
Old March 30th, 2017, 02:07 PM   #9
The starter solenoid is supplied through the main fuse, so if it has a problem it could blow the fuse when attempting to start the engine.
Old March 30th, 2017, 02:37 PM   #10
skip
skip's Avatar
OK now I need to locate the starter and find a place to get another one if it's faulty
Old March 30th, 2017, 02:52 PM   #11
skip
skip's Avatar
If the fuse on the starter solenoid isn't blown does this mean the solenoid OK . I keep popping the 10 amp ignition fuse.
Old March 30th, 2017, 03:05 PM   #12
If you're blowing the 10A fuse, it means something after that is drawing too much current. As I said, look for chewed insulation, a faulty switch, etc..
No need to start a new thread. It'll make your answers spread out in two places.
Old April 12th, 2017, 09:59 AM   #13
sickopsycho
One ugly son of a gun.
Motorcycle(s): 2012 250
My 2012 has a 30amp main fuse. I would check and see if you are really supposed to be using a 10 amp fuse or if it's supposed to be a 30. That could explain why it's popping, if the fuse you are using is too small...
HOWEVER... don't just toss a 30amp fuse in there- if it's supposed to be a 10 amp fuse then it will not offer the protection it was designed for.
sickopsycho is offline   Reply With Quote
[sportrider - latest stories] - New Michelin Pilot Power 3 And Power Supersport Tires Ninjette Newsbot Motorcycling News 0 May 9th, 2013 05:30 PM
[topix.net] - Eco Wave Power developing two new wave-power devices Ninjette Newsbot Motorcycling News 0 January 9th, 2012 06:40 AM
Loss of power on highway (all the power) aldenso 2008 - 2012 Ninja 250R Tech Talk 10 May 7th, 2011 10:27 PM
[motorcyclistonline] - Power to Spare with New Snap-On 12-Outlet Power Strip Ninjette Newsbot Motorcycling News 0 October 1st, 2010 03:40 PM
Power question, powerlet 12v to mini-usb power. karlosdajackal 2008 - 2012 Ninja 250R Tech Talk 1 May 12th, 2010 05:03 AM
