April 26th, 2015, 02:03 PM | #1 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250 09 Posts: 31
Valve Adjustment then bike malfunction.
Ninja 250 2009
37,000 miles, 4th valve adjustment. Shoot for middle adjustment/ on the looser side. Spark plugs new, gapped and look normal. Snorkel off, KN Pod. 2 washers under my needles, 108 main Jet I think. Carbs have been thoroughly cleaned, didnt need it but that was my first move. Fuel mix screws out 2.75 turns out. Synced to the best of my ability using a slack tube with atf. Fuel always premium with some SeA Foam. There was maybe 1 shot glass full of water in the bottom of my tank that I syphoned out. Ok, so I let my bike sit for 2 months before I did my 4th valve adjustment in December. Temps avg around 30 deg in the winter. Had to adjust 2 exhausts and 2 inlets, nothing out of the ordinary. Although I didn't break anything this time. Replaced my battery for the first time as well. Had the bike back together, started up great. Rided great for like 10-15 min and then starts to surge around 8k RPM. (Sometimes the TACH will redline all the way even though I know my RPMS are not that high) Then it will die at stops and wont start or stay running unless I keep it revving....... Now it wont start at all. I havent adjusted the floats in my carb, so thats next on my list. Other then adjusting the floats, does this sound like a problem anyone has had and fixed? Can anyone explain the TACH going berzerk? Thanks Jeff |
April 26th, 2015, 02:11 PM | #2 |
First things first... check the connections to the battery. Many oddities can be associated with loose connections. I am feeling it's not that simple though, but I can hope for you.
April 26th, 2015, 02:33 PM | #3 |
That would be amazing. That is def first on the list. Im not near the bike until after suppah, but I am crossing my fingers until then.
April 26th, 2015, 05:23 PM | #4 | |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Hey Unregistered never go faster than your brakes can be applied... |
April 26th, 2015, 07:32 PM | #5 |
Fishdip, when its redlining in your scenario, the engine will actually be working that hard at 5mph?
Just for clarification, mine would be on the highway and lets say I downshift because traffic is slowing up, and when I accelerate to get back up to speed the tachometer goes crazy and the needle goes past the redline. The tach needle is buried and I am literally flying with airplanes.......OK, so I am not flying, but the needle does bury itself. |
valve adjustment | mauiwowie | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 17th, 2015 08:15 PM |
Valve adjustment and now bike won't stay idle | har0ld | 2008 - 2012 Ninja 250R Tech Talk | 13 | December 16th, 2012 06:16 PM |
Valve Adjustment | fredhsu | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 7th, 2012 03:57 PM |
Valve Adjustment to Come Soon! | gilmorec61 | 2008 - 2012 Ninja 250R Tech Talk | 54 | June 22nd, 2012 03:43 PM |
Valve Adjustment-Really Tight adjustment screw? | mikesova | 1986 - 2007 Ninja 250R Tech Talk | 5 | May 2nd, 2010 04:57 AM |
