March 29th, 2016, 04:28 PM | #1 |
Join Date: Mar 2016 Motorcycle(s): Honda Elite 50S, Suzuki DR350S, Honda XR100R, Kawasaki Ninja 250R Posts: 30
New member in Maryland
Hi all, I'm no stranger to forums but I just bought a 2007 ninja 250 that was too good a deal to pass up so here I am. The clymer manual is on the way and I've started to look into what its going to take to pass inspection. Forums like these have been invaluable to me in the past, alerting me to common problems like a failed fuel petcock that can ruin a DR350 so I'm glad I found this.
March 29th, 2016, 04:34 PM | #2 |
MOTM - Sep '18, Feb '16
Welcome
The petcock can fail in these also. But no a common problem. The only advice I would give to a new ninja owner is to make sure you don't put the long fairing screw into the tank. It is fairly common to punch a hole in the tank with the wrong screw.
March 29th, 2016, 04:34 PM | #3 |
Welcome Travis!
March 29th, 2016, 04:36 PM | #4 |
sammich maker
MOTM - Apr '15
Welcome
https://www.brocksperformance.com/VZ...0035+C450.aspx |
March 29th, 2016, 04:47 PM | #5 |
thank you! I'll keep that in mind. I have the fairing bolts laid out with the pieces they go with. I got one bent clip on and I see them selling bent ones all over ebay lol. I'm considering just buying a new oem for 50$ I got the key code figured out today because of this site and ordered 2 keys, so Ninjette is already saving me money!
March 30th, 2016, 09:12 AM | #6 |
Welcome!
March 30th, 2016, 09:16 AM | #7 |
MOTM - Sep '14
Travis
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
March 30th, 2016, 03:55 PM | #8 |
Thanks all! I was cleaning up some stuff and putting my triple tree back together and I thought to myself, "I should make sure this goes through all the gears" I can't start it right now because I don't have the key yet and started to freak out when I saw it wouldn't go into 2nd. Then I googled it and found out it won't shift except 1st and neutral when the engine isn't running. And I found it out on Ninjette
March 30th, 2016, 04:53 PM | #9 |
MOTM - Sep '14
The engine running has nothing to do with it. The back wheel just needs to be moving. If you ever need to bump start it, second is the gear you want.
March 31st, 2016, 01:49 PM | #10 |
My point is, unlike the other 7 bikes I've had, you can't put this bike on the center stand and rock the rear wheel back and forth by hand with the engine off and work the gear shift through all the gears. Its a completely different animal. Because of the positive neutral finder. And that was very disconcerting at first.
March 31st, 2016, 01:54 PM | #11 | |
MOTM - Sep '14
April 2nd, 2016, 07:24 AM | #12 |
Hello and welcome!
New Here from Maryland | britx303 | New Members | 19 | July 30th, 2015 06:11 PM |
Sup from Maryland | ViggyVig | New Members | 14 | August 5th, 2012 07:37 PM |
Hello hello from Maryland | Nekomata | New Members | 11 | August 5th, 2012 07:30 PM |
New member from Maryland | Old Lemon | New Members | 25 | April 28th, 2012 10:48 PM |
New Member from Maryland | m_curtin52 | New Members | 20 | April 12th, 2012 08:08 AM |
