Old November 25th, 2023, 11:41 AM   #1
Exponent
Motorcycle(s): Honda CB550, 04 Ninja 250
Carbs in the ultrasonic
Hi,
Would simply dunking my carbs with bowls off in the ultrasonic for carb cleaning be a bad idea? I would spray them down with compressed air afterwards but I wouldnt disconnect any of the lines once the carbs are off. Anyone done this before?
Exponent is offline   Reply With Quote
Old November 25th, 2023, 11:54 AM   #2
With these carbs, that is not likely to get them completely clean.
https://n4mwd.blogspot.com/2013/10/s...-passages.html
Old November 25th, 2023, 12:08 PM   #3
First off...removal of all internal components required. I prefer splitting the carbset and replacing ALL orings, bowl orings and float valves as well, thereby wet testing and the process of resetting fuel levels are required as well...otherwise known as a REFURB.
Old November 25th, 2023, 12:26 PM   #4
Exponent
Right I didn't think it would, the bike currently runs but not perfectly
Old November 25th, 2023, 12:42 PM   #5
explain how it is running please?
Old November 25th, 2023, 01:24 PM   #6
Exponent
Will start with the choke and throttle but lugs until it warms up a little and can rev up, havent had it running for very long (over 20 mins) before, still gotta get registered so i can do a longer test. Revved to 10k on the longest test I did so not worried about main jet
Old November 25th, 2023, 01:30 PM   #7
Out of spec valves will cause erratic running when the engine is cold. If your valves need adjusting you'll chase carb problems forever.
Old November 25th, 2023, 01:31 PM   #8
you've just acquired the bike, i take it? How long did it sit prior to your purchase? Year and mileage?
Old November 25th, 2023, 01:44 PM   #9
Exponent
Yeah no doubt, its clattering bad too. One thing at a time, I've got plenty of time until its warm again.
Havent checked the valves yet, might take it in for that
08 carbs on 07 sigma44 1986 - 2007 Ninja 250R Tech Talk 10 January 26th, 2015 10:05 AM
Need 08+ Carbs Donnyd21 Items Wanted 2 September 19th, 2014 04:38 PM
ultrasonic cleaners , anyone use them ? Noobman General Motorcycling Discussion 9 June 5th, 2014 01:49 PM
CR Carbs Jiggles 2008 - 2012 Ninja 250R Tech Talk 36 November 27th, 2012 12:50 PM
