Old January 20th, 2014, 01:32 PM   #81
............When moving at a really slow pace such as a u-turn, what else can help fill the void of 2 missing gyroscopes?
Great question !!!
Don't know the right answer, but ................ we still have some bubble levels inside our heads:
http://www.livestrong.com/article/38...ional-vertigo/
"The semi-circular canals in the inner ear contain fluid -- think of the bubble on a level. The fluid acts much the same way, sending signals to the brain that help you maintain your balance."
Old January 20th, 2014, 01:36 PM   #82
It's a super simple question guys
Hint: There are only 3 things on a bike that spin.
Old January 20th, 2014, 01:41 PM   #83
front wheel
back wheel
crank shaft
transmission input shaft and clutch wheels
transmission counter shaft
oil pump
water pump
... i count 7.
edit: ****, how could i forget the camshafts!!!
Old January 20th, 2014, 01:57 PM   #84
front wheel
back wheel
crank shaft
oil pump
water pump
... i count 7.
All that can be summed up by just saying "the engine", but I feel ya.
If you listen to the throttle control of the guy in Motofool's vid, you will notice something majorly different than Crash's video. The guy keeps a steady medium rpm. So he is controlling speed with the clutch and brakes.
2 ways of doing the same thing. I am not saying it's better or worse, I am just saying that keeping your rpms up is another tool for slow speed turns, such as u-turns.
Method 1: Steady clutch
Put clutch in friction zone and hold mostly steady
Modulate throttle
Drag rear brake if you need
Method 2: Steady throttle
Put rpms at a medium level via throttle and hold steady (something that feels comfortable)
Modulate clutch to vary speed (the modulation is very very tiny and doesn't fully leave the friction zone)
My method is a combination of the two.
Old January 20th, 2014, 02:28 PM   #85
i donno i personally think 90% of low speed maneuvering is in the front handle bars and the rest in the rear brake. since that stupid "superman" post i've been sitting up on the pegs at lights now. stupid i know but i can't help myself. large adjustments can be made on the bars in a relatively short amount of space and you can control exactly how much of that large movement is going through to affect the bikes angle with the rear brake controlling the gas... you know, being able to turn hard one direction and give just a couple inches of power and it tilts the bike back up the other way... sometimes you have to go back and forth around the balance point but you can affect it by moving your body weight around if you're close to the balance point. doing a quick little spurt to get your motion angling over from one side of the balance point to the other isn't that hard either. especially on a nice and low CG bike like that scooter in the video. and while you're rocking over the balance point you can turn the front wheel any way you want, so you can easily turn it to set up for the following turn
Old January 20th, 2014, 02:36 PM   #86
Sure, those cats on the stunt supermoto's balance at 0mph for long periods of time with just weight management and bar movements. I tried it once on my dirt bike and have come to realize that I suck at it terribly. I am sure those cats can do things differently than your average everyday rider.
Old January 20th, 2014, 02:50 PM   #87
Old January 20th, 2014, 03:16 PM   #88
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
Modulate throttle
Good post! The rear brake is hugely helpful in U-turns as is modulating the clutch. I have found second gear to be slightly smoother when doing Uies, especially on the 300. It also it helps to look way over your shoulder at your end point as you begin your turn, though it's counter-intuitive as you're nearly looking backwards briefly. Pushing the bike up from under you and TRUSTING that it can easily handle a U-turn with the bars fully locked will get you turning nice and tight.
Postwhores are COOL! ~Allyson
Old January 23rd, 2014, 03:56 AM   #89
ninja250r81
ninja250r81's Avatar
this might help bad u-turner's
This is one of the skills that you have to learn for your provisional license?????
http://www.wheel-skills.com.au/RTA-m...st-MOST#u-turn
Old January 23rd, 2014, 09:21 AM   #90
ally99
Ninja chick
ally99's Avatar
The three most common mistakes in U-turning, I think, are:
1) Not trusting the bike. (Most U-turns don't even require you to actually lock your bars. Doing smooth figure-8s at full-lock will give you a new trust in your bike's performance at low-speeds.)
2) Not staying smooth and light on the bars.
3) Not looking at your end point.
Mastering the whole trust thing is crucial to reach numbers 2 and 3. Staying stiff on the bars makes U-ies nearly impossible. Trust it, relax your arms, and look where you want to end up.
Edit: Another thing, some folks avoid their fears. Instead, seek out low-traffic opportunities to practice U-turns in the real world. It's the only way you'll get better at 'em!
Old January 25th, 2014, 11:58 AM   #91
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
best method
  1. Come to a complete stop
  2. Put bike in neutral
  3. Kickstand down
  4. Dismount
  5. Lift both wheels off the ground supporting the weight on the kickstand
  6. spin the bike around
  7. get back on
  8. pop wheelie in your new direction
seriously though, 2nd gear to smooth out the throttle jerkiness that 1st has just steer and go with as smooth throttle as possible and you're fine. Luckily the msf box was one of the things that I decided to revisit after I got my 250 and practicing figure 8s for a few hours does wonders to your ability to U-turn with a smooth throttle, as well as your control at low speeds in general.
Old February 20th, 2014, 06:20 AM   #92
mgentz
Board Member
I too love u-turns and all slow speed maneuvers. On my db I can drag the pegs through a 10 ft diameter never ending series of circles! IT IS ALL ABOUT PRACTICE!
I'm an MSF instructor on weekends and my students always have trouble with the U-turn, but as others have noted, they have no issue with going fast in a straight line. Get to the box and they are jerky, slow, run wide, fall over, wheelie, burnout, crash, put their feet down, stop, forget where they are....the list goes on. Turn your head like a damn owl and look where you want to go!!! From there, it is all about counter-weighting and throttle/clutch control. If you get in a situation, use the REAR brake.
Old October 15th, 2014, 08:04 PM   #93
Old October 15th, 2014, 08:47 PM   #94
Roark
Roark's Avatar
Motorcycle(s): 2007 Ninjette
@csmith12, you mention the combination of brake, throttle, and clutch. Do you account for counter weighting? On cruiser bikes, I can figure 8 with low throttle, no brake, and no clutch just by really planting the opposite foot. On my Ninja, it takes a solid amount of rear brake.
What say you?
"That's what" -she
Roark is offline   Reply With Quote
Old October 15th, 2014, 08:53 PM   #95
Roark
Roark's Avatar
Originally Posted by Motofool View Post
I feel like I just played Pokemon with that soundtrack! Awesome video, though!
"That's what" -she
Old October 15th, 2014, 09:48 PM   #96
What say you?
Well of course. see post #86. Some riders can do it with nothing but their "body english", I am not sure that is average talent though. There is a thread about "superman balancing" at stoplights, so maybe many ninjette riders have the skillz.
Old October 15th, 2014, 09:51 PM   #97
Roark
Roark's Avatar
Oh, gotcha. I didn't know if that was thrown into the mix with your other variables.
All good
"That's what" -she
Old October 16th, 2014, 11:34 PM   #98
buhsray
Motorcycle(s): Ninja 250R
^ very nice videos up there
buhsray is offline   Reply With Quote
Old November 22nd, 2014, 02:00 PM   #99
Old November 22nd, 2014, 02:06 PM   #100
ally99
Ninja chick
ally99's Avatar
Holy hell, that, kids, us an example of a U-turn saving someone's life.
Old December 21st, 2014, 12:53 AM   #101
worker1
Motorcycle(s): Ninja 300, FZ-09
A uturn at an already green light is tough because the driver behind you won't be expecting it. I liked the video with all the alternatives. Uturns when the red turns green are easy because of the low speed of the driver behind you.
worker1 is offline   Reply With Quote
Old December 21st, 2014, 10:59 AM   #102
Very good point!
You can always abort the U-turn and keep going with a regular left turn if everyone is moving too fast and things look dangerous.
Total awareness before reaching the light will let you know if you can slow down the car following you by keeping constant deceleration for some distance before reaching the turning point.
Driving a car or riding a motorcycle, it is just wrong and dangerous to accelerate along the turning lane just to slam on brakes at the end of it.
Better annoying that driver than getting hit by his vehicle.
Like for every traffic situation, we must be predictable even to the dumbest of drivers.
The direction of your head just before reaching that point should indicate your intentions as well.
Getting close to the left of your lane will give that following car some chance to avoid you.
All the above presumes that the driver following you is attentive, which is not always certain.
I like watching the eyes and face of the drivers behind me in order to have an idea of what to expect as more probable.
Old December 22nd, 2014, 12:38 PM   #103
Worldtraveller
Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F
Like this:
Doesn't everyone?
Worldtraveller is offline   Reply With Quote
Old March 3rd, 2015, 04:16 PM   #104
A practical application of quick and tight U-turns under pressure:
https://www.ninjette.org/forums/showthread.php?t=218727
Old March 3rd, 2015, 04:19 PM   #105
ally99
Ninja chick
ally99's Avatar
Once you get comfortable with U-turns, you find them kind of fun! They're only not fun (to me, personally) when on wet pavement, but that's a mental thing for me. There's still probably plenty of traffic on wet pavement to execute a perfect U-ie. Hell, people drag knee in twisties in the rain!
Awesome video, Hernan! Cool ****!
Old March 3rd, 2015, 10:07 PM   #106
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
U-Turn's:
1) Stop Bike
2) put in nuetral
3) kickstand down
4) get off
5) rotate bike on kickstand
Reverse steps above!!!
Never crashin in a u-turn...... PRICELESS!!!!!
My replies are intended for street riding only, plz do not provide track only replies.
Visit my new MotoVlog Channel !!
Old March 4th, 2015, 01:30 AM   #107
liberpolly
Motorcycle(s): 1999 Triumph Legend "Arwen", 2006 Ninja 650 "Matsuo Hotaru". 2010 Ninja 250 "Firefly" - sold.
I just drag rear brake a little, works like a charm.
Screw the inscrutable, eff the ineffable.
liberpolly is offline   Reply With Quote
Old March 4th, 2015, 02:10 PM   #108
fry1024
fry1024's Avatar
Motorcycle(s): 2008 Ninja 650R & 2007 Buell Blast
+1
fry1024 is offline   Reply With Quote
Old March 7th, 2015, 03:02 AM   #109
asdfman
٩(͡๏̯͡๏)۶
asdfman's Avatar
Motorcycle(s): 09 Ninja 250 held together by duct tape and zip ties
Rear brake definitely helps for sharp turns. I learned this the hard way. Went into a downhill hairpin turn with rear brake, then released the brake midturn because I thought I didn't need it. I was wrong, went wide, then landed in a pile of leaves on the side. This happened 6 months ago and I'm still finding leaves in my bike to this day.
asdfman is offline   Reply With Quote
Old March 11th, 2015, 03:11 PM   #110
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
so I found a great example just now, just use a shopping mall
Old March 11th, 2015, 03:20 PM   #111
^^^ how to piss off 100 people in 1:39 seconds....
Old March 11th, 2015, 03:21 PM   #112
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Note the name of the video "idiot"
Old March 11th, 2015, 04:47 PM   #113
ally99
Ninja chick
ally99's Avatar
Why were you using rear brake in a turn? On the street, your best strategy is to get all your braking done before you start your lean.
Rear brake helps for low-speed turns such as U-turns or figure-8s, but at high speed, be careful...as you learned.
[crash.net - MotoGP] - Crutchlow 'fell at turn one, nearly landed at turn two' Ninjette Newsbot Motorcycling News 0 November 12th, 2014 11:40 AM
Turn it up!!! Desmoluci Videos 5 November 6th, 2014 06:05 AM
Electrical Issue - Turn signals turn to emergency blinkers. tgoff 1986 - 2007 Ninja 250R Farkles 6 July 6th, 2012 09:07 AM
Rear turn signals don't blink, front turn signals don't turn on andyuc88 2008 - 2012 Ninja 250R Tech Talk 3 March 23rd, 2012 02:47 PM
